Question about Refrigerators
Whirlpool Refrigerator Model GD22DFXFW02 Bottom of freezer is building up a small 'glacier' of ice. Periodically it partially melts, causing a pool of water to run out onto the floor. What might be the cause? What are best steps to troubleshoot to identify root cause?
    President:
  • 2,559 Answers
The defrost timer or defrost thermostat,Since it does attempt to thaw,This would indicate the defrost element is still working and there for would indicate the defrost timer or defrost thermostat is malfunctioning,you can see a diagram at this link to help with break down.
Please rate this a fixya.
Posted on May 17, 2009
Whirlpool refrigerator #ER2CHMXPL02 I think I have two separate problems. 1st one is a water leak that fills the bottom bins daily! The freezer does not seem to be defrosting, everything in there looks...
Could be that the freezer is too full with foodstuff and there is no air circulation, therefor, some places in the freezer build ice. The defroster is working and melting the ice that drips to the bottom bins.
I suggest you remove everything from the freezer. unplug the frigde. Let all ice build ups melt. Remove ice from the foodstuff and put back in. Make sure that vents in the freezer and fridge are not blocked.
Oct 18, 2013 | Whirlpool 21.0 cu. ft. Top Freezer...
Water leaking from whirlpool gold refrigerator
When refrigerators leak water it usally is a sign that the defrost drain found inside the rear of freezer and behind the rear panel of freezer has become clogged with ice or gunk. Sometimes the pan below refrigerator has a crack and allows water to leak onto floor. Please click here=> Leaking Refrigerators Just What may Be HappeningYou will at times see water build up inside freezer bottom especially on bottom freezer refrigerators. This will take a little reading over to understand what may be happening. Click Here=> Leaking Refrigerators
I will be here should you have questions, Thanks Sea Breeze
Feb 16, 2012 | Whirlpool GX5FHTXVA Bottom Freezer French...
I have a whirlpool refrigerator model #GT15HTYMQ81
The refrigerator is supposed to self-defrost approximately four times in every 24 hour period. If one of the components in the self-defrosting system fails, the refrigerator continues to try to cool. Eventually, though, so much frost builds up on the evaporator coils that the circulating fan can't draw air over the coils. There may still be a small amount of cooling because the coils are icy, but with no air flow over the coils, cooling in the refrigerator compartment is quite limited. Here's an inexpensive, though inconvenient, way to determine if the problem is with the self-defrosting system. Remove all of the perishable food from the refrigerator and freezer, turn the thermostat in the refrigerator to Off, and leave the doors open for 24 to 48 hours. (Be sure to have several towels ready in case the melting frost and ice causes the drip pan to overflow). This allows the refrigerator to defrost "manually." When the frost and ice build-up has completely melted away, turn the thermostat back to a normal setting. If the refrigerator then cools properly, it indicates a problem with one of three components in the self-defrosting system: Poor cooling is often the result of a heavy frost build-up on the evaporator coils. You can't see these coils without removing a panel on the inside of your freezer. A sure sign that there is a build-up is the presence of any frost or ice build-up on the inside walls, floor, or ceiling of the freezer. Such a frost build-up usually indicates a problem in the self-defrosting system or damaged door gaskets. The defrost timer The defrost thermostat (also called the bi-metal switch)
Aug 21, 2011 | Whirlpool GT1SHTXM Top Freezer...
Ice build up in the bottom of the freezer compartment to the point that it will flow under the gasket like a glacier and melt. There is not an icemaker hooked up. No free water is piped to the unit and...
You have a common problem of a clogged drain, in the back bottom of the freezer, behind the shelf and drawers, you will find a drain pan that has frozen completely over with a ice sheet. This has caused defrost water to run forward and collect under your racks in the freezer. I would advice you to turn off unit, and remove all the ice collected in the freezer, clear the pan with warm water, then restart your unit back up.
Once the pan and drain tube is clear, your unit should be fine.
I hope this helps
Aug 02, 2011 | Whirlpool 24.8 Cu. Ft. Side-by-Side...
I have water pooling under my vegetable drawers, what could be causing this?
The drain tube in the freezer may be partially clogged or melting ice build up on the floor of the freezer may be dripping into the fresh food compartment. Most freezers are frost free but there may be some problems beginning in yours (a faulty defrost timer, terminator, etc.).
You could remove the contents of the freezer and the plastic tray on the floor of the freezer. If you find ice there, remove it by thawing and remove the water. Check to make sure that the drain tube in the back hasn't become clogged with any debris, etc.
Reassemble and pay close attention to the temperature of both your fresh food compartment (34 deg) and freezer (0 deg) to see if it is getting warmer but the fridge continues to run. If so, if might be time to call a pro for repair.
Mar 12, 2010 | Whirlpool GR2SHWXPB 21.7 cu.ft. Top Mount...
Melting/refreezing ice in the ice makes
If the ice is the only item that appears to be melting or defrosting. I would believe the most possible issue. The icemaker is leaking intermittantly into the bin and freezing the cubes inplace.
Ric
Mar 09, 2010 | Amana ABB2527DES Stainless Steel Bottom...
In side by side whirlpool refrigerator freezer ice cubes stick
if they are hollow and stuck together then u are not getting enough water..check the supply.
Jun 09, 2009 | Refrigerators
Ice build up under the freezer drawer
drain is blocked. remove back panel inside freezer and melt the ice off at the bottom with a hairdryer then follow up with hot water till drain flows freely. if fault reoccurs, then you may have a fault with the defrost system
Jul 06, 2008 | Whirlpool GB2SHKXL Bottom Freezer...
WATER pooling in bottom of fridge
did you try to remove the 2 ***** in freezer floor???. if not remove the floor and check for ice build up underthere, if so:
you have a clogged defrost drain tube. removing back panel of freezer will give you acess to drain trough, melt away the ice with a hair dryer, youll find a drain hole under there somwhere,pouring boiling water down the drain will clear it pretty quickly( i use a steam machine purchased from the infomercials works awesome, after you clear it and all water drain down tube wrap a piece of solid copper wirearound the heater( black calrod heater right above the drain trough) and stick it in the whole maybe an inch or so. now everythime the heater comes on to defrost it will prevent the hole from freezing over
Mar 12, 2008 | Whirlpool ET8RHMXKQ Top Freezer...
Refrigerators Logo
46 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
