How do I install batteries to a Craftsman LED 34-93687 flashlight
Has no instructions. Has 3 screws holding it together but it won't come apart. Tried using a flat head screwdriver but don't want to damage it.
  • James OConnor III
    James OConnor III Jan 12, 2014
    With the light bulb end of the flashlight facing away from you, turn the end cap counterclockwise and it will easily open to install the batteries. You do NOT need to remove screws or pry it open!! Flashlight should come with instructions since it is not intuitively obvious how to open it.
noone
  • 105 Answers
SOURCE: Any tips on openong the 917s case?
Front and back of most LCDs shap together. Must be gently pryed apart.
Some KDS LCDs that have screws on the edge need to slide the front cover up a half inch to release from the back cover.
Monitor Mike
Posted on Feb 17, 2009
Krazytech
  • 725 Answers
SOURCE: Error code E21
you need a phillps screwdriver remove the top . control panel then the front... hope it helps
Posted on Aug 24, 2008
SOURCE: how do you take apart a gateway zx4800-06 all in
You don't need to take apart all the back cover. Only the small rectangule part where the back support is located. The hard drive is located under the small cover.
Posted on Sep 25, 2011
  • 22 Answers
SOURCE: 3 D mag flashlight diagram
Parts diagram is at: http://maglitesales.com/maglitestore/index.php/cPath/12_13
Gary
Posted on Oct 17, 2011
SOURCE: how do you change batteries
The unit is 3 individual flash lights. Pull one of the flashlights by the head (the light part) it will come out easily once you know what you are doing. The other two may be pulled out in the same manner. The bottom will then unscrew where you will be able to replace the AA batteries. Each flashlight will then go back into place very easily. Hint...test each individual flashlight before putting back together to make sure you have your batteries in the proper place and that they are useable batteries.
Posted on Nov 25, 2011
Repair for Innova GT 3 led, 3 AA battery flashlight.
Before doing serious damage, check for a poor ground to the case. I have worked on a couple of these and some of the manufacturers seem to believe a solder connection to an anodized aluminum case is going to work. Use a tool with a sharp point to scratch through the anodized layer to expose a clean metal ground. You may have to repeat this from time to time as the light fails.
Aug 26, 2016 | Camping, Backpacking & Hiking
Tip
How to replace the lamp in a Mini Maglite
The Mini Maglite is a durable, compact flashlight. If your Mini Maglite stopped working, check or replace its two AA batteries first, and if that doesn't fix it, you'll probably need to replace the lamp. You can order replacement lamps in packs of two online, or you may be able to find them locally in a hardware store.
To replace the lamp in a Mini Maglite:
1. Unscrew the bottom of the flashlight. (Hold the flashlight with the head facing down so that the batteries don't fall out.)
2. Remove the batteries.
3. Unscrew the flashlight head from the barrel.
4. The lamp is mounted into the flashlight on two prongs; gently pull up on the lamp to remove it.
5. Install the new lamp by lining the prongs up with the two holes and slowly inserting it fully.
6. Screw the flashlight head back on.
7. Reinsert the batteries.
8. Screw the base back on.
When you've finished, turn the flashlight on (by turning the lens cover or the head counter-clockwise) to verify that the new lamp works. If the light doesn't come on, take the flashlight apart again and check to make sure the lamp is installed correctly and fully. Since the lamps come in packs of two, if you can't get the first lamp to work, try the second lamp in the pack. If that lamp doesn't work either, check your batteries and make sure the lens cover and head are both screwed on all the way.
on Jan 12, 2011 | Kitchen Appliances - Others
My new flashlight wont stay on
Flashlights of this type are notorious for poor design. I had one where the contact spring at the top broke its connection. Others break the ground wire when the top is unscrewed. Another design flaw is trying to solder a ground connection to the anodized aluminum case - doesn't work. I am replacing the broken ground wires with longer, more flexible ones but that's not a permanent solution. Some LED board case grounds have been repaired by scraping the solder-to-case joint although in one case I had to replace the joint by wedging in a piece of bare copper wire. Hope these tips help.
Jun 09, 2017 | Energizer Camping, Backpacking & Hiking
My craftsman 22" self propelled
Your problem is at other end . Engagement problem is probably due to a loose belt. Make adjustment in that area of mower. GOOD LUCK.
Jun 16, 2011 | Craftsman Garden
Model: KP028 It doesn't work no matter how long I tried to charge it. I haven't used it for a few months though. Is there anyway that I can make it work again?
the batteries are gone . it carries 3 small 1.2volts battery 1 1/8" long and 3/8" in diameter soldered together making it 3.6 volts why couldnt duracel used aaa instead .couldnt find these batteries online. batteries are nickel metal hydride type 300mah.
Dec 30, 2010 | Duracell Crank Light 3 In 1, 3 Led...
How do you change batteries stanley 3 in 1 tripod led flashlight
Dec 08, 2010 | Stanley 3in1 Tripod LED Flashlight 95155
I have a craftsman driver light #41993. Its
I know this is an old post but noticed there are 385 people that have viewed the post that like me were searching for a fix to their Craftsman 41993 lighted driver. The fix I found resulted in a better light than the original but being a Craftsman purist I also found a way to fix the original as well even though I put it away and use the new fix. I just wanted the original to work again. I'll start with repairing the original. The usual problem with the original is caused by corrosion from leaky batteries that ends up corroding through the metal strip connecting the + and - ends. I tore apart a new freebie led flashlight from Harbor Freight and used the guts to replace the metal strip and spring that was corroded beyond repair on my light. All it took was a little bending and snipping to make it identical to what my Craftsman had. You will notice the guts of the HF light have a nearly identical metal strip with spring attached. I cleaned the 41993 parts thoroughly & reassembled it using the remaining parts and the new metal strip and spring that I fabricated from the Harbor Freight light. It worked like a charm and my light works like it did when it was new. Now for the best part because my upgrade takes this light to a whole new level. Remove the old light and store it in a safe place. Then get another 3 1/2" Mini Flashlight from Harbor Freight item #69052 for free if you have a coupon since this item is often the freebie given away with any other purchase. I have a half dozen lying around myself so I know this to be fact. Remove the small lanyard and circular clip from the light and toss it since you will no longer need it. Pick up one super thin O-ring from a hardware store that will fit over the end of the flashlight and place it over the end of the light with the push button until it rests in the first groove. I can't give you a size since I sifted through several until I found one that fit snug with a little stretching to get it over the end of the light. Then slide the light into the 41993 and work the o-ring into handle with a small jewelers screwdriver as you gently press the light in place. This doesn't take too much pressure unless you chose a thicker o-ring. You don't absolutely have to use an o-ring but I like the professional appearance of the o-ring and the fact that it serves as a moisture barrier. The new replacement light fits so well that it looks like it was made for the 41993. The plus is that it has 9 LED's and illuminates the 41993 like the sun. Trust me that you will never again use the original once you install the new upgrade. Hope this helps another Craftsman tool junkie like me.
Dec 16, 2009 | Hammer Hand Tools
Will not hold a charge...Looking for a replacement battery? Any Ideas?
http://cgi.ebay.com/VECTOR-1-MILLION-CANDLE-POWER-SPOTLIGHT-FLUORESCENT-NEW_W0QQitemZ220469526499QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item335501ffe3&_trksid=p3286.c0.m14
Aug 31, 2009 | Vector 1 Million Rechargeable Spotlight
Computers & Internet Logo
386 people viewed this question
David Payne
David Payne
