Question about Samsung RFG237AARS Bottom Freezer French Door Refrigerator
Samsung rfg 237 water leaking
Water is leaking under the drawers in the refrigerator
  • 65 Answers
SOURCE: samsung RFG 297 series... contro panel reads 88 88
This is technical unit an they can be pretty touchy with power outages sometimes. It may be in a display mode. If you havent already try unplugging the unit for a minute or two and plug it back in. This doesnt reset its programming try holding Energy Saver Key + Lighting Key for 8 seconds and let the unit run thru a self diagnstic test and hopefully it will reset. If neither works its going to have the main board replaced.
Posted on Jan 23, 2010
Testimonial: "It worked! Thank you so much!"
localwonder
  • 6784 Answers
SOURCE: We have started to notice a puddle of water on the
Your refrigerator has a drain that leads to the exterior drain pan beneath the refrigerator. Occasionally this drain can become clogged resulting in standing water inside your refrigerator. A similar drain exists in the freezer, which when clogged results in ice build up on the floor of the freezer.
The drain is located either on the floor of the refrigerator, beneath the vegetable crisper, or in the wall behind a drain funnel.
Clear the drain by forcing a solution of water and bleach or water and baking soda into it with a basting syringe. If the solution will not flow through, slide a length of ¼ inch flexible tubing into the drain tube to push the clog through to the drain pan. Remove the tubing after clearing the clog.
NOTE-(This may be a leveling issue as well)
It is important for the refrigerator to be level. If it is not level, doors may not open or close properly and may not seal tightly. Also, drainage from the defrost cycle might be impaired as might the ice making cycle. The appliance was engineered based on it being installed in a level position. While there may be some tolerance for out-of-level installation, the appliance will operate at its best when properly leveled.
Place a level on top of the refrigerator near the front. Do not put it on the door because the door may not be aligned with the refrigerator case. Check that the refrigerator is level from side to side. Next turn the level to check that it is level from front to back.
If it is not level, adjust one or more of the adjustable leveling feet until it is level. The feet are bolts that can be turned to raise or lower the refrigerator. If they cannot be adjusted with your fingers, use a crescent wrench or pliers.
If you have an ice-maker, it should also be checked for level after first leveling the refrigerator. An ice maker that is out of level will spill water into the ice bin or into the freezer. It can be repositioned by loosening the mounting screws, adjusting it for level and then re tightening the screws.
Posted on Feb 01, 2010
  • 117 Answers
SOURCE: I have a Samsung French
this may be of some help
Posted on Sep 28, 2010
  • 354 Answers
SOURCE: water filter on my side
Well first thing shut the water off,drain water out by removing filter ,check the o-ring on filter and if you recently changed the filter you possibly pinched it when reinstalling and now you need a new. If not it could have a flat spot on it and wore out either way you need a new on.Appliance store (get model # or take with to match up) or even at times a hardware store that sells o-rings.
Posted on Mar 27, 2011
  • 5370 Answers
SOURCE: Water is pooling under vegetable/deli
Its a defrost problem.Click this link below and follow the troubleshooting:--- http://technoanswers.blogspot.com/2011/07/water-is-pooling-under-vegetabledeli.html ---------- This should help.Thanks.Helpmech.
Posted on Jul 08, 2011
I have Samsung RF263BEAESR with water collecting under drawer. I changed the defroster clip that's been suggested, but now the water is still there but freezing solid under drawer. What should I do?
you do have a leak, air is getting in and causing humidity to build up
Try putting a toilet paper roll in there and see if it get the moisture issue solved.
Tony
Dec 13, 2017 | Samsung Refrigerators
Samsung rf265 series french door with freezer drawer on the bottom: Water collects under the veg drawers in the refrigerator part. What might be wrong?
I have the same problem!!! We need a class action lawsuit against Samsung for this problem on their French Door fridge. Instead of fixing it they want the consumer to pay for repair. NO MORE SAMSUNG PRODUCTS FOR ME!!!!!
Sep 04, 2011 | Samsung RF265AA Bottom Freezer French Door...
Samsung RFG 297 has ice build up under the Cool Select drawer in the fresh food section. What is the cause/solution?
• Check if the set temperature on the digital display is too low.
• Try setting the refrigerator to a warmer temperature.
• Is the temperature in the room too low? Set the refrigerator warmer.
• Did you store the food which is juicy in the coldest part of the refrigerator? Try moving those items
to the other shelves in the fridge instead of keeping them in the colder areas or bins.
• Is the air vent blocked? Remove any obstructions so air can circulate freely.
• Allow sufficient space between the stored foods for efficient air circulation.
• Is the freezer drawer closed properly?
There is a ton of information regarding your fridge at the link below, including asking Samsung support questions and getting responses and assistance from their techs:
http://www.samsung.com/us/support/owners/product/RFG297HDBP/XAA#
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Jun 05, 2011 | Samsung RFG297AARS (285 cu ft) Bottom...
The fridge turned off today due to a power outage and now it only shows a green bar on the display and is not cooling!
What kind of refrigerator, and whats the model number? Green bar flashing I'm going to guess a Samsung. If so, then hold down two buttons at the same time on the display, It depends on the model number as to which two, but in most cases its the power freeze and ref buttons. If you can get the brand and model # to me I could describe more for you.
Mar 22, 2011 | Refrigerators
We have a slow water leak in our fridge. The water pools under the bottom 2 produce drawers.
On most newer fridges, there is a very shallow 'V' shaped collection channel at the back of the fridge just above the bottom drawers, this is for condensate collection. In the middle of this channel there should be a hole, this quite often gets clogged, and over flows, hence the water at the bottom of the produce drawers, clear the hole and it should cure your leak, worth checking every couple of months.
Mar 22, 2011 | Samsung RM255LASH Side by Side...
Samsung rs21wcns has a leak
I found my leak, after checking all lines, connectors, couplers, behind the second to bottom drawer from what appears to be a cooling resevoir. It appears the seams are slightly leaking on both sides. I found water pooling under the bottom drawer and then leaking out the front and followed it back. My Samsung is model RS2556SH
Jul 04, 2008 | Samsung RB2155SH Bottom Freezer...
Samsung RS253BASB leak at bottom veggie drawer
I had the same problem. I called tech support and they were no help. Being a handy man I dove into the problem myself and discovered the problem. If you want this solution, I have pictures and information. Simply email patmcclain@charter.net and I will send you this infomation.
Jun 07, 2008 | Frigidaire FRT15G4B Top Freezer...
Samsung RFG237AARS Bottom Freezer French Door Refrigerator Logo
314 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
