Question about Mr. Dudley Pepper mill
How to refil Mr Dudley acrylic Salt and Pepper Grinder
Salt and pepper grinders how to clean
warm soapy water, you can put some soapy water in the grinder, shaker and shake it vigorously to remove any pepper or salt that is stubborn, but hot water will dissolve the salt and loosen the pepper.
Sep 29, 2014 | Cuisinart Salt and Pepper Grinder,...
How do I fill with pepper
On most pepper mills, some part of the upper half usually unscrews, and the 'top' and 'bottom' can be separated. The bottom part will have a 'reservoir' in which the peppercorns should be placed, to eventually be ground.
Apr 05, 2014 | Bodum The Furniture Store Bistro Automatic...
How to load peppercorns into trudeau 0716840
I found the following webpage on your grinder: www.shoptrudeau.com/v/vspfiles/images/instructions/0716840.pdf
Just in case the link doesn't work, it looks like the top (salt) part just pulls off the bottom, pepper grinder part. With the top off, there's a hole to pour the peppercorns into.
Jan 20, 2013 | Trudeau 0716840 Click Combo Pepper Mill...
Stupid question but how do you refill the pepper grinder of the Octo Combo? I don't consider this an appliance since it doesn't use electricity or batteries but couldn't figure out another category for...
Hi, from the photos I see on the web, it looks like you hold the salt chamber and then unscrew the nut on the top of the unit. I would say that you need to then pour out the salt into a small container, and then grasp the bottom (pepper chamber) and pull up on the salt chamber to separate it from the bottom chamber. Fill the pepper chamber and then replace the salt chamber and fill with salt, replace salt cover and then replace nut. I hope this helps.
Jan 02, 2011 | Vacuums
Ran out of salt refilled and it is not softening
Don't you get it? Salt is required for the softener to work. Pepper is not a replacement.
Aug 05, 2009 | Culligan Under Sink Water Filter
Mr. Dudley Pepper mill Logo
292 people viewed this question
Top Mr. Dudley Saws Experts
Tom Chichester
ray gallant
Are you a Mr. Dudley Saw Expert? Answer questions, earn points and help others
