Question about LG DLG5988 Gas Dryer
My lg tromm dlg5988w dryer is making a loud noise
  • 4 Answers
SOURCE: lg tromm front load dryer dlg5988w
dryer has two fuses check both circuit breakers one is for heating the other is for the plug this fixed my front load lg this gives you the heat that you need to dry your clothes
Posted on Feb 23, 2009
  • 32 Answers
SOURCE: LG DLG5988W Gas Dryer (NO HEAT)
I'm pretty sure that the cooling light is always on and blinks when it is cooling. I look at my brother's and he has the EQ bar and it acts the same.
Posted on Sep 01, 2009
  • 66 Answers
SOURCE: Where can I get an online manual for my lg tromm
You can go to diplodocs.com. You can do a search for both of them there. If they don't have them, it has links to other sites to help you find them. Hope this helps you.
Posted on Oct 29, 2009
cherylogle
SOURCE: lg tromm dryer electric cooling light staying on
I called LG after seeing this light as well and they say it's supposed to stay on and should "blink" at the end of the cycle. I've never remembered this light staying on in all the years of owning this machine but she (LG rep) said it was normal. Otherwise, if you've checked everything and it's not drying clothes, you may need to have your dryer serviced. :(
Posted on Dec 14, 2009
PSITECHNICAL
  • 71 Answers
SOURCE: check filter light wont shut off and setting.lg tromm dryer
You might need to check the exhaust on the rear of the Dryer, or the blower motor iether one has lint inside, restricting the air flow
Posted on Dec 23, 2009
LG Tromm electric dryer model DLE5977B is making an extremely loud humming noise.
Humming is caused when the slow start capacitor on the motor fails. Better to buy a new dryer as the motor is usually around $160. Yours is $145. I suggest you take professional advice on such a high outlay rather than risking the advice of someone who hasn't physically checked the machine. I have two pro dryers in my hotel fail, and they buzzed.
LG Dryer Model DLE5977B Parts
Feb 02, 2017 | LG Dryers
Why is my LG TROMM frontloader dryer making a loud noise when running?
If the washer is making a loud noise the rear drum with bearing might need to be replaced. On this washer the bearing might not be sold separately, the entire rear drum might have to be replaced. This is a very involved repair and will require disassembling most of the washer. However, the problem is going to get worse very quickly and so either the drum and bearing will need to be replaced or the washing machine.
Sep 02, 2014 | LG 4925ER1015B 4924ER1010 Used Frontload...
Lg tromm wm1812cw dum makes load noise when spinning
LOUD NOISES IN MACHINE;
LOT OF THINGS TO CHECK, THE BELT LOOSE OR WORN, THE CLUTCH, THE TRANNY, THE BEARINGS BOTH TUB SEAL AND BEARING, THE REAR DRUM BEARING,
THE DRIVE PULLEY- If the washer is making a loud noise the drive pulley might be worn out, cracked, loose or bent. Remove the drive pulley and inspect it carefully. If it is damaged or defective replace it.
THE TRANSMISSION, THE MOTOR COUPLER, THE MOTOR DRIVE BEARINGS,
THE DRIVE MOTOR- If the washer is making a loud noise the drive motor bearings may have worn out. Washer motors are normally almost silent when they run. If the motor is run without a belt hooked up to it and it's loud it will have to be replaced.
Jun 15, 2014 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Loud banding noise in my LG Tromm DLE7177
Manually turn the motor and drum and listen for the noise, if so the motor bearings, the drum agitator shaft and fittings must be checked. Also the suspensions which include the shock absorbers and springs, the body clamps must be checked to be in correct alignment and not changed in position. Tightening of the mounting is also very important. Finally in most cases a drop of OIL or smear of grease on the moving parts cane solve most issues.
Check this link :
http://www.espares.co.uk/advice/washing-machines/a/7/1210/wobbly-washing-machine-or-tumble-dryer.html
Feb 11, 2013 | LG Tromm Electric Dryer
Does my lg tromm dlg5988w gas dryer have a pilot light that stay on all the time or only when u start it
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 09, 2011 | LG DLG5988 Gas Dryer
My LG Tromm dlg5988w dryer won't heat. I am trying to reset the heat sensor but can't find it. I have removed the front cover but not sure exactly what I'm looking for.
Make sure you have 240 Volts going to the dryer. The motor runs on 120 Volts, but the element needs 240 Volts. If that checks out, you would need to trace the wiring using the wiring schematic. That could be fun.
Aug 09, 2011 | Dryers
I have a LG dlg5988w drying that just started making a banging sound. Are there rollers that need replaced?
yes the belt has a tensioner with a bearing and a roller surrounding the bearing
the bearing can be locked up which will put flat spots in the roller m,aking the banging noise
Sound horrifying at times doesn't it?
Mar 07, 2010 | LG DLG5988 Gas Dryer
Lg dryer tromm dlg5988w flashes filter code will not dry
Check your filter, your vent and clean them well. Shut down the power and let it reset itself.
Jun 09, 2009 | Dryers
My LG dryer will not power up
You may have a broken door switch.  That would be the most likely source of your problem since the machine will not work if the computer senses that the door isn't closed.
Mar 15, 2008 | LG DLG5932W Gas Dryer
Lg tromm front load dryer dlg5988w
Mar 01, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
LG DLG5988 Gas Dryer Logo
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a LG Dryer Expert? Answer questions, earn points and help others
