Question about FUJIFILM FinePix AV200 / AV205 Digital Camera
Read error please check card format
Auto on and off and flash problem sometimes
    Problem Solver:
  • 8 Answers
The card you have in it may be too large. Many cameras have a limit as to size. Check manual
Posted on Jan 26, 2014
I got cannon power shot sx130 is it reads memory card error the memory card is not locked but the eject button is not working how to fix this problem. thanks
Try to switch off the Camera and restart it gain. Again, Sometimes, its due to some auto-run software running in the card which prevents that from ejection. You can try to even format the card in the camera itself. That may work also.
As a last resort, check up your camera and get that memory card removed out of your Camera.
Feb 16, 2015 | Canon Powershot SX130IS Black Digital...
Respected Sir, I have bought SanDisk MicroSD memory before 2 months it has worked for 45 days and now it is not working it is showing in my motorola L7i mobile when i do format it is coming error...
Hi
Memory drives can develop read/wite errors.
You do not say if you have tried to format it in a PC. If you have no PC or your PC has no card deader, then try a friend's PC or an internet cafe that has a workstation with a card reader
Try wiping the metal elements gently with a slightly damp cloth.
If you or any friend of your has a computer running linux you can sometimes use Linux diagnostic and recovery tools to recover data from corrupted flash drives.
I hope this helps.
Aug 28, 2011 | SanDisk 2GB microSD Memory Card
I downloaded photos on computer ,now I get card not initialized ? what do I do? Its a fujifilm camera..
Insert the memory card into the camera to format it if you are receiving error messages such as "Card Error" or "Card Not Initialized." Press the "Menu/OK" button then press the left/right directional button to select the "SET" option. Press the up or down direction button then press "Set Up" and press the "Menu/OK" to access the setup screen.
Press the down directional button to select "Option 1" and scroll down to the "Format" option. Press the right directional button to select the format option. Press the "Menu/OK" button to start the format process.
Move away from the target or brighten the lights if the auto focus does not work. Rotate the scenery mode dial at the top of the camera to the "Auto" mode. Press the "Flash" button to enable the flash mode to provide additional lighting if necessary.Manually set up the Fuji E500 camera with your computer if the computer does not automatically detect it. Connect the camera to the computer using the supplied USB cable and power on the camera. Click the "Start" button then click on the "Computer" option and select the FinePix Icon. Choose next on the download wizard to start the download process.
  • 2 Press the down directional button to select "Option 1" and scroll down to the "Format" option. Press the right directional button to select the format option. Press the "Menu/OK" button to start the format process.
  • 3 Move away from the target or brighten the lights if the auto focus does not work. Rotate the scenery mode dial at the top of the camera to the "Auto" mode. Press the "Flash" button to enable the flash mode to provide additional lighting if necessary.
  • 4 Manually set up the Fuji E500 camera with your computer if the computer does not automatically detect it. Connect the camera to the computer using the supplied USB cable and power on the camera. Click the "Start" button then click on the "Computer" option and select the FinePix Icon. Choose next on the download wizard to start the download process.
  • Read more: How to Troubleshoot a Fuji E500 Digital Camera ' eHow.com http://www.ehow.com/how_7636592_troubleshoot-fuji-e500-digital-camera.html#ixzz1OOyWsAIU
    May 31, 2011 | PNY Optima Pro 2GB Secure Digital Memory...
    Unable to format the cruser pendrive
    Far too often these little things have an almost invisible read/write protect button on them. Look carefully, over the entire surface of the USB Flash Drive. You might have this switch turned to Write Protect, which means there is nothing you can do, until you turn it the other way, and allow the device to be written to.
    Cheers!
    -a.
    May 22, 2009 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
    Read error
    Try formatting the card in the camera using the setting in the camera's menu.
    Some makes of xd or sd cards do not work correctly in fuji camera's. Sometimes even formatting them in the camera does not have any effect.
    Mar 25, 2009 | Fuji FinePix F470 Digital Camera
    Can't format 2Gb Extreme III SD card in Canon G9 camera
    bad card trash it and get new one changeing formats will cause errors most camera's use their own format if u cange it from one to the other so many time it burns card out
    Dec 28, 2008 | SanDisk Memory Media
    Card Error
    !. Formating any card in a PC makes it unsuitable for camera use.
    2.The camera model may not support 8Gig.
    In each case tghe remedy is READY THE BLOODY MANUAL.
    Mar 30, 2008 | Samsung Digimax A7 Digital Camera
    Can't read or format mini-sd card
    lots of times when this happens the table of contents of the drive gets messed up. try using windows management options to fix the problem.
    go to your desktop, right click on my computer, and click the manage button.
    Click the storage option on the left, then right click the removable drive your card is in. this usually for me gives a more comprehensive format and will sometimes fix problems that other formats will not.
    Jan 02, 2008 | Transcend (589307) Media
    My SanDisk will not unlock
    unfortunutly this happens sometimes with all Flash bases memory cards.
    if the computer won't read the card anymore, try formatting the memory card. Unfortunutly you will loose your pictures that were on the card, but that should get the card back working so you can continue using it.
    Dec 26, 2007 | SanDisk Memory Media
    FUJIFILM FinePix AV200 / AV205 Digital Camera Logo
    22 people viewed this question
    Top FUJIFILM Cameras Experts
    Tony
    Piyal Perera
    Piyal Perera
    Are you a FUJIFILM Camera Expert? Answer questions, earn points and help others
