Question about Bosch WFL 2063 Front Load Washer
Washing machine is not draining
Cleared all water from the drain tap and cleared pump cap.
water seens not able to drain out externally?
    Problem Solver:
  • 9 Answers
Your drain pump is probably dead. Advice: do not believe anyone who tells you that it is a pain to replace on BOSCH! I just did it myself in less than 45 minutes and thereby saved about $200.
You need to order the part-> go to the BOSCH website and identify the exact model and part number for your machine. I ordered mine from www.appliancepartspros.com/Bosch-Parts.aspx.
The part arrived at my home this morning-it took 2 business days. I called to double check I had the right part and the CS person was very nice and helpful.
Then, beating the odds I did the following with just a pair of pliers and a screw driver:
1- unplug the washing machine (of course)
2- drain any water that could be left in it using the small black drain hose located behind the front bottom door (probably on the right)
3- lie your washing machine on its back-put a piece of wood long enough to cross the width of your machine and it will save your fingers- you will need some thigh and **** muscles as it is a little heavy (but I am a woman and did it without help)
4- remove the bottom front panel of your washer (2 screws)
5- remove the screw holding your pump (above the filter)
6- lying down on the floor, unplug the wires at the back of the pump"s motor
7- using your pliers loosen the braces that hold each of the 2 hoses, and slide them down along the hoses (easier this way)
8- take out the hoses- the pump will drop into your hand
9- place the new unit by screwing it to the front of the machine's casing
10- plug back the wires
11- reposition the hoses making sure that the braces are tightened around the hose + each of the 2 plastic tubes that stick from the pump
12- tilt your machine back up
13- plug your machine
14- you are ready for your first load adn have saved $200 :-)!
Posted on Jul 27, 2009
F & S GWL15 would not drain. Replaced pump & it drained for a while. Removed diverter, found a dime & some lint, cleaned it out and installed it. Still would not drain, water is on floor, do not see leak....
Have you tried reverse flushing the drain hose?
If you can get the outlet/drain hose to the washtub cold tap
wrap a towel around the hose and tap to stop water going everywhere whilst slowly turning up the water pressure
from the tap.
(Any leaks STOP and check your hose clamps/connections are all tight.)
Water should now be flowing into the machine bowl, and
hopefully turned the pump, and cleared any blockages.
Hope it helps
Sep 15, 2013 | Fisher Paykel EcoSmart GWL15
Spin cycle isnt not working
The spin cycle is reliant on the drain pump removing water from the tub.
It is a common ocurrance of objects (ie hair pins, pegs, coins etc) to be mistakenly washed through the cycle. Washing machines will often flush these objects down through the drain pump, and get caught in the little propeller of the pump.
So, it is imperative that you inspect the drain pump first and remove any obstruction within the drain pump cavity.
Turn machine power OFF at the wall and remove the power plug.
i) place an empty bucket on the floor
ii) lower the drain HOSE into the bucket - gravity will cause the water to drain into the bucket. Empty the bucket. Perform this procedure until all water has been emptied from the bowl.
iii) move the washing machine out from the wall, to gain access to the drain pump (usually a large screwcap). Place a large towel on the floor, under the screwcap - this will catch any remaining water that escapes.
iv) unscrew the drain pump cap and withdraw the cap. This cap may also contain a filter, so remove any lint/objects from this filter.
v) with the pump cap/filter removed, look inside the pump cavity and remove any visible obstruction from the impellar (little propeller thing). Then, with your finger, turn the little impellar in both directions - if you feel a 'rubber band' like resistance, then the drain pump may be ok at this point.
vi) remove all wet clothes from the machine bowl.
vii) re-assemble the drain pump cap/filter and secure it in place. Install drain hose back into your laundry tub. Plug machine back into power.
viii) fill the bucket with water and pour water back into your machine's bowl. Repeat with a 2nd bucket of water.
ix) manually select and operate SPIN cycle on the machine. Observe if drain pump functions correctly and empties water from the bowl. If yes, then you have resolved the problem.
If your pump has been cleared of all obtstructions but your machine will still not empty water from the bowl, then a full diagnostic will need to be carried out by an authorised service agent to determine which component has failed.
Let me know how you get on.....
Good Luck..
Oct 31, 2011 | GE Washing Machines
Will not drain water it might be clogged with lint
Most likely lint, or paper lodged in the drain pump. The pump is easily accessible at the base of the machine. After unplugging the machine, put down a towel or blanket and tilt the machine forward so it rests on the front. You will see the drain hose connected with a solid clamp. Remove the clamp and pull the hose off. You should see another "mounting" screw that holds the drain pump in place. Unscrewing this screw should allow you to remove the drain pump for inspection.
Once out, most debris can be cleared with a small flathead screwdriver. Once you are sure the pump is clear, reassemble and turn the machine on. In almost every case, the machine will function normally again.
NOTE: If the drain pump is clear, the problem may be either a clog in the relief tube (where the hose empties the waste water to) or a bad drain pump all together.
Sep 06, 2011 | Fisher and Paykel Washing Machines
Washing machine Airturbo stops at 17 minutes and 7 minutes and error code SE appears. what is to be done washing nachine is one year old only
  1. Open the filter-cover near the bottom of the machine. Unscrew emergency drain cap by turning it to the left and drain off all the water. Unscrew the filter cap and take it out. Wash any dirt or other material from the filter. Make sure the drain pump propeller behind the filter is not blocked. Replace the filter cap. Replace the filter-cover.
  2. The Water Drain error can be cleared by turning POWER SW OFF and back ON.
  3. If the water only trickles out of the draining hose, pause the washer and blow air down the hose, you should hear the water inside the unit bubble a few times. If you don't hear bubbles, the hose is still blocked.
  4. Drain the load, empty the washer of clothes and try running a rinse & spin cycle. You should repeat this until the water runs clear from the drain hose.
  5. If the machine still fails to drain, you may need to replace your Drain pump.
Feb 26, 2011 | Samsung Washing Machines
Problem with the Samsung Washing Machines The machine keeps coming up with the message HEI 10x
Here is a list of errors for your machine.
I hope they help you.
SAMSUNG WASHING MACHINES, ERROR FUNCTIONS
When an error occurs, the alarm noise will sound and the error code displayed in the program window. Listed below is a series of error codes you may or may not see for your model of Samsng Washing Machine. The errors are shown as blinking in O.5 second intervals until the error status has cleared. In this case, all the driving devices are turned off until the error is cleared.
1. WATER SUPPLY ERROR - Display shows 4E.
Water Supply Error occurs when water level frequency does not show changes more than 100Hz or water is not supplied up to the preset water level after 10 Minutes or more at the time of initial water supply. The error status can be cleared by turning the POWER switch OFF and back ON.
2. WATER DRAIN ERROR - Display shows 5E.
5E is displayed if the water level frequency detected is 25 KHz or less in the initial phase of the UNB -detecting cycle. The Water Drain error can be cleared by turning POWER SW OFF and back ON.
3. OVER-FLOW ERROR - Display shows oE.
Over-Flow error occurs when the water level is too high. It can be cleared by turning POWER switch OFF. Water is drained prior to POWER switch OFF. The tub is drained for 2 minutes if a frequency of more than 25 KHz is detected.
4. UNBALANCE ERROR - Display shows UE.
Laundry load is unbalanced, manually loosen any tangled laundry.
If only one item of clothing needs washing, such as a bathrobe or jeans, the final spin result might be unsatisfactory and an UE error message will be shown in the display. Unbalance error is cleared by POWER switch OFF and back ON.
5. WATER HEATER ERROR - Display shows HE, HE1.
HE, HE1 is displayed if the water temperature rises by 7 C or more in 1 Min or by 2 C or less 20 Min after heating process has started. The error can be cleared by turning POWER switch OFF.
6. WATER PRESSURE SWITCH ERROR - Display shows 1 E.
* Generated Frequency Signal of WATER LEVEL (WIL) SIW (KHz)
Normal Level = Abnormal W/L Frequency
Low Level = 30.00 Khz
High Level = 15.00 Khz
If the same signal is detected for more than 5 seconds, it is a PRESSURE SWITCH Error. When this error occurs the drain pump will operate for 3 min. and the display will show 1 E indicating a pressure switch error.
7. ABNORMAL WATER TEMPERATURE ERROR- Display shows cE.
e.g. If the water temperature is 50 C or more, during a Delicate or Wool cycle.
At the time of initial water supply, if the water temperature is not appropriate, the display will show cE. This error can be cleared by POWER SWITCH OFF.
8. WATER LEAKAGE ERROR - Display shows 11 E.
Water Leakage error occurs when the water drains naturally, (by leakage) after the washing program starts.
9. THERMISTOR ERROR - Display shows tE
Nov 21, 2010 | Washing Machines
Water will not drain. Wash programme runs normally to this point. There is a louder than normal noise when machine is attempting to drain
Basically, the drain pump is jambed due to an obstruction in the impellar. Dont retry untill pump is cleared or it will burn out.
Aug 05, 2010 | Zanussi IZ12 Front Load Washer
Zanussi ZWF1437W E23
E23 indicates Drain pump faulty; Wiring faulty; PCB faulty.
The service information also says it should stop with the door open.
Unplug the appliance and manually remove the water via the filter or front drain point if it's fitted.
Drain it into a shallow dish, tighten the filter when you need to stop the water (or plug the hose if draining via a hose) while you empty the container.
Once empty, try the door again.
Take the filter out and clean out any debris in it.
Plug the appliance in and put the machine on a drain programe.
Listen/look at the open filter to check that the drain pump is running.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 27, 2009 | Washing Machines
Clogged pump on Affinity Washer
Exactly the same problem. Washed a small area rug that appeared to have pretty much disintegrated. Machine would not drain. Got the same e 20 code. Checked the drain hose, and it was fine. Reamed the house drain just to be sure. Drum appears to have drained, but now the motor runs, and no water enters the machine. Both water hoses are flowing. No further error codes. Nada.
Apr 20, 2008 | Frigidaire ATF6000ES Front Load Washer
Washer will not leave the drain cycle
Press PAUSE/CANCEL twice to clear the display then
  • Check the drain hose and make sure it is not plugged or kinked.
  • Check the electrical connections at the pump and make sure the pump is running.
  • Check the drain pump filter for foreign objects.
  • If the above does not correct the problem, replace the pump.
It's because of a Long Drain condition. If the drain time exceeds 8 minutes, the water valves are turned off the code is flashed.
But Note: After 4 minutes the "Sud" error is usually displayed, then 4 minutes later the error code is displayed.
Jan 14, 2008 | Whirlpool Duet GHW9150P Front Load Washer
E20 During Drying Cycle
if the wash cycle runs ok then unlikely to be the drain pump or hoses. put drain hose into a bucket and check waster comes out during dry - it wont be large amounts of water. can you hear the drain pump running during the dry cycle?
Mar 08, 2007 | AEG Lavamat 16810 Front Load Washer/Dryer
Bosch WFL 2063 Front Load Washer Logo
184 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
