Question about Refrigerators
Kfxs25ryms4 how to remove freezer drawers top and bottom
  • 125 Answers
SOURCE: Admiral Side by Side Fridge is warm at top, cold at bottom
CHECK TO SEE IF THE EVAPORATOR FAN MOTOR IS RUNNING, ITS IN THE BACK OF THE FREEZER SIDE, MOTOR MAY BE BAD OR SOMETHING COULD BE BLOCKING IT...
Posted on Feb 07, 2008
SOURCE: removing freezer drawer
my son fixed it - thx. problem solved
Posted on Nov 24, 2008
  • 128 Answers
SOURCE: how do i remove the bottom freezer drawer
You should be able to pull the bottom drawer out, lift and pull all the way out.
Becareful it doesn't drop on your foot.
Posted on Dec 31, 2009
jmgldsmth
  • 2005 Answers
SOURCE: TOP FREEZER REFRIGERATOR WITHOUT ICEMAKER LEAKS
the condensate drain hose is blocked.
remove the plastic rear cover in the freezer; locate the drain opening;
it's about 1/2 inch in diameter; it drains into a pan at the bottom of the refrigerator. using a funnel and, a small pan, pour hot water through the blocked hose until water flows into the drain pan again.
remove the condensate pan pour the water out and, reinstall the pan.
Posted on Jul 02, 2010
SOURCE: Is there a way to remove the drawer in the bottom freezer?
Pull the drawer all the way out until it stops. Then lift the front of the freezer drawer (a couple of inches), and pull out further (4-6"). The front will then lower to the floor. Lift the back of the drawer upward and slid the entire drawer forward. You may want to protect your floor. I did the above with the freezer drawer full and scratched my floor a little...
Posted on Jul 08, 2010
Freezer not cold
See if you can
change the thermastat so it also freezws the bottom drawer.
Sep 16, 2013 | Zanussi ZRB834NW (865 cu. ft.) Bottom...
Removing samsung freezer drawers
There are 3 bolts that hold the bottom of the freezer door in place, if you remove them the door will fall to the floor then youmcan pull it off then you can access the drawer
Sep 07, 2012 | Samsung RFG237AARS Bottom Freezer French...
I just bought a house with a Kenmore stainless steel bottom drawer freezer. The freezer drawer does not close completely and large amounts of snow and ice accumulate inside. I have taken the drawer out,...
Check top see if the arms of the drawer are fully seated into the rails which support it and extend from inside the freezer when the drawer is opened. On most french door refrig's, there are hooks on the back side and tabs on the front side which are sometimes hard to get back in. Then the door is locked into the rail with a screw at the point where the rail meets the freezer door.
Aug 21, 2010 | Kenmore 73503 Stainless Steel Bottom...
Jun 27, 2010 | Sub-Zero 650 / O Bottom Freezer...
Mod# RFG297AA:Need to remove the freezer section or handle/latch
there are two screws on each side of the bottom freezer unit you need to remove. they can be removed after de-installing the front bin with the two plastic sleeves on the right and left. Then you can remove the bottom drawer door and the bins inside. next, open both top doors and angle the fridge with one door inside the door frame, then "walk" the fridge over the doorstoop, turning towards the inside door as you push. Follow thru with the rest of the unit, then re-attach the bottom drawer.
Apr 08, 2010 | Samsung RF265AA Bottom Freezer French Door...
We have the bottom drawer freezer, top french doors, 3 months old, freezer will not shut all the way and now after door open beep has gone off for an hour the whole unit has gone dark
Make sure nothing has fallen behind the freezer drawer or is hitting the top of the freezer to prevent it from closing. Also check that the tilt open front is in the closed position. If nothing is blocking the drawer the gear wheels that support it may not be in the right position. See Owners Manual for instructions about removing/reinstalling the drawer. When you get the drawer to close you may have to unplug the power cord for 30+ seconds to get the unit to reset and restart.
Aug 11, 2009 | KitchenAid KBFA25ER Bottom Freezer French...
Removing freezer drawer
Nov 23, 2008 | Pds GE Profile Bottom-Freezer Drawer...
Hotpoint freezer fza54 frost free, high temp light on
Power off the freezer.
Remove all freezer drawers.
Remove the four screws retaining the ducting at the back of the freezer compartment. Top at the top, two at the bottom
Carefully pull the ducting out - it's located in the guide slots for the freezer drawers, and should pull out without too much drama.
This exposes the air circulating fan, and the evaporator coil (the bit that gets chilled).
In my case, despite a defrost of the frost-free section, the evaporator section was one massive chunk of ice. If you have similar, carefully defrost this, and check the drain hole at the bottom of the cavity.
Re-assemble, as reverse of above.
Mine's been trouble-free since doing this.
Jun 28, 2008 | Refrigerators
Hotpoint FFA70
Remove the plastic venting box which feeds cold air over the top of the freezer drawers,There are 4 hexagon headed self tapping screws,two at top.and two bottom.Now defrost all ice off rear of freezer and back of vent box.Now replace and door will shut with draws in.Make sure no ice left round fan housing.
Jan 21, 2008 | Hotpoint FFA70 Bottom Freezer Refrigerator
Refrigerators Logo
47 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
