Question about Nike Wr0139001 Triax Fury 100 Regular Watch for Men
How to change battery in nike vg01-0010 watch?
3 Suggested Answers
Coachphil
  • 347 Answers
SOURCE: I have a Triax Speed
You can't change it yourself without doing damage. You will need to send into Nike or more accurately an authorized nike watch repair center that is close to you hopefully.
Nike customer service or a google search for authorized nike watch repair in XXX-city will get one close to you.
Posted on Dec 27, 2010
escapement
  • 2334 Answers
SOURCE: Just change the battery on
If you changed battery yourself, you've lost the tiny spring without noticing it. Carefully check around the place where you changed the battery. The spring itself is very, very tiny, so, be as concentrated as much as you can. That spring (coilspring named by watchmakers) transmits the signal from watch movement to the watch back cover where the sound membrane is located. In case if you find it, open the watch and insert that spring with the bent out end first in to the desired hole in watch movement (should be named COIL SPRING). After that re-assemble watch and the sound should work.
Posted on Jun 02, 2011
Flashing time display
Nike Triax Fury 100 Super
You need to replace the battery. I had the same problem. Replaced the battery on mine and everything is fine now.
Sep 08, 2012 | Nike Wr0139001 Triax Fury 100 Regular...
Stop screen flashing on nike trax fury
Yes you need to replace the battery. I had the same problem. Replaced the battery on mine and everything is fine now.
Nov 29, 2011 | Nike Triax Watches
Just change the battery on my Nike Anvil WC0020 watch and the alarm won't sound for the timer as well as the two alarm settings.
Jun 02, 2011 | Nike Mettle Anvil Super Watch Obsidian...
I have a Triax Speed 50 Nike watch and the local jewelry store would not change the battery because the possibilty of damaging the wrist band that needs to be removed. Any instructions on how I can change...
Dec 27, 2010 | Nike Timing Triax V10 Watch
Change battery
if you watch a notch in the middle of the watch back then all you do is slip a large coin and twist off the capsule top by pushing down and turning counter clock wise. If the back of your Nike has a plate with 4 screws in the corner then y ou need a precision screw driver and unscrew all 4 screws on the back to access battery back.
Oct 17, 2010 | Nike WC0021 001 Mettle Hammer watch
How do you change the battery?
Thank you for contacting FIxYa.
I would read the NIKE support site before deciding to do any battery changes on your own. As a retail jeweler/watch service tech I would HIGHLY recommend you doing what they suggest:
http://www.nike.com/timing/
Best regards. Jewel
Sep 02, 2010 | Nike WC0021 001 Mettle Hammer watch
Nike triax speed WR0082 regular
You must Re-Link the SDM pod to the watch after changing the battery. Go to the link below, It's not the exact model, but, should work, if not, go to www.nike.com and download the manual for your model.
GOOD LUCK
http://www.nike.com/timing/extranet/product/triax_elite/elite_manual_eng.pdf
Aug 25, 2007 | Nike Triax Speed WR0085 wristwatch
Triax CV10
Nike Triax CV10 - Successful HRM reset 7 November 2008
I had real problems too. Even after repeatedly following the known reset steps everyone else is posting up. Here’s how I got mine going, please forgive the mind bogglingly tedious detail…
First make sure you’re using new good quality batteries. I used Maxell’s, bought in 10’s from Hong Kong on ebay – no problem.
Second, and this is the ESSENTIAL bit…move right away from the computer and any other electromagnetic sources before carrying out the known reset…
Third, follow the known reset steps below, adjusted to what worked for me…
If you press all four buttons of your Nike HRM it will reset. Next time you go to "RUN" mode, it will show "HRM LINK" error. You will now need to "hard reset" the unit.
Nike made a late change to add a "hard reset" to the chest strap. To re-link (re-initialise) the watch you'll need to open the battery door on the chest strap, and use a paper clip (or the equivalent) to push the small gold button in the battery area. There should be a small sticker in the battery compartment that points to the reset button.
The re-initialisation steps for the Nike C10 and CV10 digital HRM's is:
(1) reset the watch
(2) open the battery door on the chest strap
(3) move the watch to RUN mode
(4) press the reset button in the chest strap battery area without removing the battery
Tip - I agree with the suggestion to use a pin or needle and definitely do it with the battery in the hrm.
Tip – Thumb holds battery to stop it from pinging out, other hand performs jiggle with pin until the link is made (it links straightaway if you jiggle it just right!)
(5) replace chest strap battery cover…and smile!
Nov 30, 2006 | Nike Triax CV10 Wrist Watch
Nike Wr0139001 Triax Fury 100 Regular Watch for Men Logo
105 people viewed this question
Top Nike Watches Experts
Jimmy Accardi
Electro Med Services...
Are you a Nike Watch Expert? Answer questions, earn points and help others
