Question about Quinny Freestyle 3 XL Dusk Jogger
I need help to replace cover that I removed to clean it
I can't figure out how to get cover back on after removing covers
3 Suggested Answers
SOURCE: How do I replace the Quinny Zap cover on the
Hi, there is an instruction manual for the Quinny Buzz over at the following link:
http://www.freebabymanuals.com/quinny/prams/Page-2
Hope that offers a solution.
Posted on Jun 05, 2010
  • 223 Answers
SOURCE: I need to remove my Quinny seat cover
Hi under foot part of seat is velcro, undo this. At the sides it is like a a hard seam this is in a tube so you need to start to pull the seat upwards, once you have got it half way, you should be able to take to top of it off this is the same but across the top, slide it out the carry on with the sides. You can then either put that 1 back or put the xl seat cover on the same way. It can be fiddly.
Posted on Aug 07, 2010
Changing the fuser for a CM1415fnw
If your capable of searching google, you may want to grab the service manual for this, heres the procedure to change it out but as you can see there are even more procedures along the way...
Fuser 1. Remove the following components: ? Right cover. See Right cover on page 17. ? Right-front cover-1 and cover-2. See Right-front cover-1 and cover-2 on page 20. ? Control panel. See Control panel on page 22. ? Left cover. See Left cover on page 25. ? Document-feeder and scanner assembly. See Document-feeder and scanner assembly on page 28. ? Rear-center cover. See Rear-center cover on page 30. ? Rear-upper cover. See Rear-upper cover on page 31. ? Speaker. See Speaker on page 33. ? Top cover. See Top cover on page 34. ? Rear door and rear-lower cover. See Rear door and rear-lower cover on page 41. 2. Remove two screws (callout 1) and the black plastic cover (callout 2). Figure 1-117 Remove the fuser (1 of 4) 1 2 80 Chapter 1 Removal and replacement ENWW 3. Disconnect five wire-harness connectors (callout 1). Remove the wire harness from the guides (callout 2 and callout 3) and one retainer (callout 4). Figure 1-118 Remove the fuser (2 of 4) 2 1 3 4 4. Remove four screws (callout 1). Figure 1-119 Remove the fuser (3 of 4) 1 ENWW Removal and replacement procedures 81 5. Remove the fuser. CAUTION: Handle the fuser carefully. The sensors that are mounted to the output side of the fuser can be easily dislodged. When the fuser is reinstalled, make sure that the sensors are present, and correctly fastened to the fuser assembly. Figure 1-120 Remove the fuser Hope this helps...
Feb 16, 2014 | HEWLETT-PACKARD CM1415fnw AllInOne Laser...
Ink jet print head
Unseating and reseating the cartridge
Turn the unit on and open the lid or top cover.
Remove the cartridges.
Re-insert the cartridges.
Close the unit’s lid or top cover.
Cycle the power to the device by turning the printer off for a few seconds.
Turn the printer back on.
Print a test page. If this does not solve the problem, proceed to the next section.
Wiping the cartridge contacts
Using a clean, dry lint-free cloth (a coffee filter works well), wipe the cartridge contacts, from the top to the bottom (see Figure 1). The contact area of the cartridge should be rubbed briskly to remove the waxy lubricant material from the gold contacts.
Figure 1: Cleaning the cartridge contacts
The contacts inside the printer may also require cleaning. Using a clean, dry, lint-free cloth, gently wipe the contacts, from the top to the bottom (see Figure 2).
Figure 2: Cleaning contacts inside the printer
Re-insert the cartridges and close the printer’s top cover.
Print a test page. If the problem persists, perform a hard reset as described in the next section.
Performing a hard reset on the unit
When the printing unit detects an issue with the cartridge, a software flag is set inside the device. This flag may not reset until performing a hard reset on the device.
HP Deskjet and Photosmart printers
Verify that the unit is switched on.
Open printer and remove both cartridges.
Unplug the power cord from the printer.
Wait 30 seconds.
Plug the power cord back into the printer.
Open the top cover and reinsert both cartridges.
Turn the unit on.
Print a test page. If the problem persists, the cartridge should be replaced.
HP Officejet and PSC all-in-one
Remove the power cable from the back of the machine.
Wait 30 seconds.
Press and hold the POWER button on the front panel.
Reinsert the power cable in the backside of the unit.
Jul 25, 2008 | HP PSC 750 All-In-One InkJet Printer
I have a clogged fuel line (filter?) I do I remove the bushing without damaging it?
FUEL FILTER
(For 40/55/60/70/110/115/155/165 Models
Only)
1. Remove side cover screws using 5/16" nutdriver.
2. Remove side cover.
3. Pull upper fuel line off fuel filter neck (see
Figure 15 or 16).
4. Carefully pry bushing, fuel filter, and lower
fuel line (110/115/155/165 Models only) out
of fuel tank (see Figure 16).
5. Wash fuel filter with clean fuel and replace in tank.
6. Attach upper fuel line to fuel filter neck.
7. Replace side cover.
Jan 20, 2012 | Reddy Heater-70,000 BTU Kerosene w/T'stat
Can't figure out how to get battery to come out of back compartment so I can replace, What is the trick? 1987 Honda TRX400 foreman 4x4 ATV
All you should have to do is remove the seat (lift the lever on the back right side of the seat and slide it off toward the back of the ATV). There should be a "pop off" cover behind the battery - Use a Phillips screwdriver to remove the "button" tabs and then remove the cover. You can now remove the battery hold down strap and remove the battery.
1) Make sure the ignition switch is OFF
2) Remove the seat
3) Remove the rear fender lid by removing the clips
4) Release the rings and remove the rubber band
5) Disconnect the negative terminal lead from the battery first, then remove the positive terminal lead
6) Remove the battery
7) Clean the batter box before replacing with the new battery
Install in reverse order of removal.
Regards,
Oz
Jan 09, 2011 | Honda Fusion Motorcycles
How remove DVD From desktop Compaq Presario
have to be a little more clear with the question depends on where you want them removed if the computer oh intalar system for a non-dvd if the system goes to control panel and look for oction says oh add remove program
if you want to put a DVD without need only to plug the computer and remove the cable and put the other one wants to
Oct 17, 2010 | HP Compaq Presario Media Center SR1750NX...
How to remove valve cover to replace valve cover gasket
REMOVAL & INSTALLATION
1C-LTC and 2CL-TC Engines
(see Figures 1 and 2)
  1. Disconnect the negative battery cable. Remove and label all electrical wiring, connectors and vacuum hoses necessary to gain removal clearance.
Fig. 1: Loosen and remove the cylinder head cover retaining nuts
  1. Disconnect the PCV hose.
  2. Remove the six nuts and seal washers from the cylinder head cover. Loosen them in a crisscross pattern.
  3. Remove the cylinder head cover and the cover gasket from the cylinder head. Discard the gasket and replace with a new one.
To install:
  1. With a wire brush or gasket scraper, remove all the old gasket material from the cylinder head and the cylinder head cover gasket surfaces.
  2. When the cylinder head surfaces are free and clean, apply beads of sealant to the cylinder head in the locations shown in the accompanying illustration.
Fig. 2: Be sure to apply sealant on the cylinder head prior to cover installation
  1. Install the new gasket in the cover. Make sure that the gasket seats evenly.
  2. Place the cover with the gasket onto the cylinder head.
  3. Install the six nuts and seal washers. Tighten the nuts to 65 inch lbs. (8 Nm).
  4. Connect the PCV hose. Connect all removed vacuum hoses, connectors and electrical wiring. Connect the negative battery cable.
  5. Start the engine and inspect for oil leaks. Repair any leaks as necessary.
Hope this help (remember comment and rated this).
Apr 16, 2010 | 1990 Toyota Camry
How to change the vavle cover gasket on a 2006 Kawasaki ZX-10R
Remove the petrol tank and air box to get access,then remove the cover bolts ,allways try to put the bolts back in the same holes .the valve cover may require a small tap around the edge with a rubber mallet to break the seal. Remove the old seal ,it may need scraping ,use a piece of copper or hard wood with edge,clean the mating surfaces to a shine then gently scrub the mating surfaces with wet and dry p240 ,dont get grit in the engine so go slowly and clean often ,lightly grease the gasket and put in place ,put the cover back on,put bolts back in finger tight,then bit by bit tighten in a figure of eight pattern untill allmost tight. Then finally use a torque wrench set at proper torque setting,call your local kwak dealer .and finally tighten in same figure of eight pattern,
Mar 11, 2010 | 2006 kawasaki ZX-10R
Replacement drum for Q3964a
HP Color LaserJet 2820 and 2840 AiO Series Products - How to Replace the Imaging Drum Replace the imaging drum
  1. Push the scanner-release button to open the scanner assembly. Figure 1: Example of scanner release button location c00364331.gif
  2. Open the top cover. Figure 2: Example of top cover being opened c00364332.gif
  3. Grasp the imaging drum handle, and then rotate the drum until the handle is at the top.
    NOTE: The drum may be a snug fit. If needed, gently apply some force while rotating and removing the drum. Figure 3: Example of imaging drum rotation c00364333.gif
  4. Lift the imaging drum straight up to remove it from the device. Figure 4: Example of imaging drum removal c00364334.gif
  5. Remove the new imaging drum from its packaging.
  6. Place the imaging drum on a firm surface, and then pull the orange rings to remove the shipping pins. Figure 5: Example of shipping pin locations c00364335.gif
  7. Remove the orange shipping lock on each end of the imaging drum, and remove the two orange shipping spacers. Figure 6: Example of shipping lock and spacer locations c00364336.gif
  8. Remove the orange cover from the imaging drum. Figure 7: Example of orange cover location c00364337.gif CAUTION: Do not touch the surface of the roller or expose the roller to light for an extended period of time. Doing so could cause print-quality issues.
  9. Align the arrows on the side of the imaging drum with the arrows inside the printer. Figure 8: Example of arrow location c00364338.gif
  10. Lower the imaging drum into the printer, and then press it firmly into place. Figure 9: Example of imaging drum installation c00364339.gif
  11. Close the top cover and the scanner assembly.
Feb 27, 2009 | HP LaserJet 2840 All-In-One Printer
How to change air conditioning filter chrysler crossfire 2005
I found a chrysler blog. Pull back carpet on passenger foot well, remove white styrofoam computer protector. Remove cardboard cover (remove two screws) from bottom of glove box. On Left side see a slot with plastic cover and two sliding latches. Open and remove and replace filter. Follow reverse to finish up. It is tight fit and hard to get to for normal sized man.
Nov 22, 2008 | 2005 Chrysler Crossfire
Hitachi 53UDX 10B 53in Rear Projection
Steve, easier and safer to remove back panels, remove bottom back cover then remove top back cover, be advised the top cover has a giant mirror on the inside so it will be heavy and easy to break, use 2 people to remove it, this way you can get at the inside and clean the mirror at the same time, hope this helps and Happy New Year, BMW Rider
Dec 28, 2007 | Hitachi 53UDX10B 53" Rear Projection...
Quinny Freestyle 3 XL Dusk Jogger Logo
Top Quinny Baby Gear Experts
Dorel UK
Dorel UK
Jennifer Rock
Jennifer Rock
Michael Vincent Cruz
Are you a Quinny Baby Gear Expert? Answer questions, earn points and help others
