Question about Polaroid i737 Digital Camera
Camera freezes after startup
I have a Polaroid t1031 that I have owned for less than 6 months. It has recently started to freeze after it is turned on. This happens immediately after the extension of the zoom lens, which seems to be making an abnormally loud whirring/soft grinding noise. To the best of my knowledge, this camera has never been dropped, damaged or mistreated, and I did fortunately purchase an extended warranty. Can this be fixed, or do I just need to send in for a replacement?
  • 3 Answers
If you added an external memory card, try removing that first. I put an 8 gig mem in mine and it would just error out because it didn't support that much. Otherwise I would send it in.
Posted on May 29, 2009
Hi I've just got a Polaroid iE3035 and it won't turn Off it turns on up comes the Polaroid start up screen and it freezes, it was fitted with New batteries and a new ad card. Can u help or should I just...
If removing of the batteries, for a few moments, (that will reset the camera) and reinserting them won't change the startup, I'm afraid you have a defect in the camera. Make sure you have the correct batteries, as described in the manual. If nothing can bring the camera to work correct, or if the same error keeps coming back, please return the camera and ask for an other one.
Dec 26, 2014 | Cameras
How to change the iso on my polaroid t1031 camera
To change the ISO on your Polaroid t1031, please do the following:
  1. Turn your camera on
  2. Press the FUNC (Function) button (right button on bottom right of device next to the LCD)
  3. Use the Up/Down, Left/Right buttons to move through the menu.
  4. Scroll down to the option that reads ISO AUTO and press the SET button (located in the middle of the arrow buttons) to bring up the different ISO options available to you (see Fig 1 below)
  5. Use the arrow keys to navigate the different ISO options and press the SET button to confirm your selection.
  6. If the menu does not close on its own after making your selection, press the FUNC button to close.
  7. Thats it! Your ISO setting has been changed.
Fig 1
Mar 14, 2011 | Polaroid t1031 Digital Camera
I get an USB error when I connect my t1031 to my computer... happens everytime? My pc does not recognize the camera... this just started happening recently and it happens on every computer
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
Feb 03, 2011 | Polaroid t1031 Digital Camera
My Polaroid t1031 digital camera doesn't stay on when turned on, please help
Hello. When a digital camera will not stay on, it is a sign that the battery is low or that the battery is bad. Put the charger on the battery and see if this cures the problem. If it does not, you will have to purchase a new battery. J.
Jun 09, 2010 | Polaroid t1031 Digital Camera
Battery
One possible source is http://www.batteriesplus.com/product/36770-RAYKLIC7001-Battery/551-0/4927-Digital-Camera-Batteries/142827-Polaroid/t1031.aspx
May 15, 2010 | Polaroid t1031 Digital Camera
Battery
Here's one possible source: http://www.batteriesplus.com/products/551-0/4927-Digital-Camera-Batteries/142827-Polaroid/t1031/1.aspx
Mar 29, 2010 | Polaroid t1031 Digital Camera
I can't get my t1031 digital camera to turn on. Battery is fully charged. Please help! I've had the camera for a year but it hasn't worked for at least 6 months of that time.
Your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, your batteries may need to be replaced, or the camera may have a problem that requires professional repair.
If this response helps, please take a moment to post a rating for me. "Very Helpful" would be appreciated.
Nov 27, 2009 | Polaroid t1031 Digital Camera
File error/polaroid camera polaroid t1031
I have the same camera and that happens to mine sometimes. That happens when something wasn't right when you took the picture. If you press the delete button while it has the "file error" on the screen, it will delete the file and then you can continue use with your camera. Sometimes when this happens it freezes the camera so you have to turn it off and back on, then try deleting it. I hope this helps you!!
May 27, 2009 | Polaroid i733LP Digital Camera
Fuji FinePix S1000fd Digital Camera, freezes!
We have the same problem. Less than 6 months after using it the flash seems to lockup the camera and the only way to free it up is to remove the batteries.
Hopefully someone has a solution or answer.
Jan 16, 2009 | Fuji FinePix S1000FD Digital Camera
Polaroid i737 Digital Camera Logo
170 people viewed this question
Top Polaroid Cameras Experts
Steven Wander
Steven Wander
Are you a Polaroid Camera Expert? Answer questions, earn points and help others
