Question about Watches
How to set time weipeng pocket watch - Watches
2 Suggested Answers
SOURCE: how to set the time on relic watches
I had to go to the Sears counter to fix mine. The sales person had to use TWEEZERS to pull the serrated knob up. He had to really work at it. Once it is pulled up you can twist the knob to set the time and then push the knob back down. What a stupid design.
Posted on Mar 13, 2009
How do I set a Danbury pocket watch with date display
If it is this pocket watch, then the crown (the bit you turn to wind the watch) has 3 positions. Position 1 is when the crown is pushed in all the way. Position 3 is when the crown is pulled out as far as it will go. In between position 1 and position 3 is a place where the crown will stop, this is position 2.
To set the day of the week, pull the crown out to position 3 to set the time. When you set the time, the bottom dial with also turn to set the hour on the 24 hour clock, if you turn the crown enough to cycle through a whole day the day of the week dial will also turn. Keep turning the crown until the time is set on the proper day of the week.
To set the date, pull the crown out to position 2, and turn it clockwise until the hand on the date dial points to the correct date.
Hope this helps!
Sep 01, 2012 | Watches
How do you set the time on a Relic ZR85049 pocket watch?
the crown in the top of 12 o'clock must be pulled. and turn it to adjust the time.
Jul 23, 2011 | Relic ZR85049 Pocket Watch for Men
How do I set the time on an old Regina pocket watch. I can wind it and it runs well. The piece to wind the watch does not pull in or out to set the hands.
If you can wind your pocket watch using the crown, but you cannot see any way of setting the watch, you probably have a "lever-set" movement, though it's possible you might also have a "pin-set" movement. Do you see a little button you can push in, either at 1-2:00 or 10-11:00 on the watch case? If you, you have a pin set watch. Push and hold that little button in while you twist the winding crown, and that will let you set the time. End of problem.
Setting the time on a lever-set watch is a bit more complicated and will require taking off the front bezel of your pocket watch--the metal ring that holds the watch crystal in place. Pocket watch cases of this time are usually made in 3 pieces: the bezel, the main case body, and the back. The procedure used to remove your bezel depends on the type of watch case you have.
Take a close look at the front of your pocket watch. Do you see any hinges at the bottom (that is, below 6:00 and where the bezel meets the main case body)? I suspect that you won't, as double-hinged cases are usually associated with an older style of pocket watch, but it's worth checking. If you do see little hinges for the FRONT (it's more likely that the back will be hinged), then look for a little lip on the bezel that's used to pry open the front. Pull on that to open the case.
If you don't see hinges, which is what I expect, your front bezel unscrews. You can try to do this with your bare hands, but it's a lot easier if you have a bit of "gripping" rubber so your hands don't slip so badly. I have a small rectangle of shelf non-slip stuff that works perfectly for this. Turn the bezel counterclockwise. It may resist a little bit at first due to accumulated dirt, but then it should easily screw off.
Once you have the bezel away from the face, look closely at about 2:00 on the watch dial. Just at the edge of the dial, you should see a little lever or button. GENTLY pull this away from the watch face until it stops. Now, when you turn the winding crown, you should be able to set the time. Once the time is set, gently push the lever back to its prior position. Now, you should be able to wind the watch without changing the time.
Be very careful when screwing the bezel back onto the watch body. These parts typically have very fine threads, and it's easy to cross-thread the pieces. Don't force the two pieces together; once the threads catch properly, the front bezel will screw on easily without resistance.
An older style of pocket watch required the use of a little key to set the time from the back of the pocket watch movement. However, these watches were also wound by the same key, so the fact that you're able to wind this watch with a crown suggests to me that your watch doesn't use this system.
May 27, 2011 | Watches
I can't get my hamilton watch to open. I pulled out the wind knob and heard the click, but can't find any hinge or any other way to get it open. What am I doing wrong? Thanks
If your watches case does not have a hinge then pulling the crown out won't do anything but allow you to set the time if it is a stem set watch. If it is a lever set watch then the lever which is under the bezel will need to be pulled out before you can set the time.
On a pocket watch without a hinge the case back and or bezel will unscrew from the case.
Hope this helps,
Ken
Yellowstone Watch Inc.
www.yellowstonewatch.com
Nov 01, 2009 | Sterling J3E Hamilton Antique Pocket Watch
My watch has stopped working
mcdevito75 here, Unless you have a good knowledge of takeing apart, even just the back off your watch / pocket watch it"s best to look for a small watch repair shop in your area, but here is what you can do to possibly start your watch / pocket watch. If your watch / pocket watch hasn"t been wound in some time and that time varies from watch to watch, the oil in the watch can become a bit thick so as to not allow the mechanism to work smoothly, leave the watch / pocket watch in a warm place, window sill in the sunlight wrapped in a paper towel for anywhere between a few minutes to 1/2 hour, after the watch / pocket watch has been warmed up hopefully the oil in the mechanism has liquified enough to allow the movement to start working. You can also give the movement a little boost, after the watch /pocket watch is warm, pull out the stem as if to set the time of day, move the stem and hands, sometimes this action will get the watch ticking again. If this fails, BEST BET specially if this is an expebsive or keepsake watch, look for a small watch repair shop in your area for serviveing. approx. $45.00
Mar 19, 2009 | Colibri Mechanical Collection Pocket...
Trying to figure out how to adjust time
You have broken or displaced setting lever in your pocket watch.
That's why it is not possible to set the time. No matter in what position the winder is, the setting gear are not engaged from the clutch wheel and the time adjustment can not be done. At the same time the crown wheel still engaged in any position and this is why it still winding in both positions.
As repairs of this can be done only by skilled man, go and see your nearest watchmaker and ask for help.
It is understandable that I can not execute repairs over the net, so, rate it as if I did it, please.
Mar 14, 2009 | Watches
How to set the time on relic watches
Dec 27, 2008 | Relic Degrade Pocket Watch
Hi i have just recieved a pocket watch but cant work out how to adjust the time.
There should be a button on the top that opens the watch, under this is a dial, you lift the dial not the button, there should be a click and the watch will stop, then swivel the dial to set the time.
Dec 24, 2008 | Colibri Colibori Swiss Made Elite Quartz...
How do I change the date on a Colibri Pocket Watch?
Usually all quartz watches are supplied with calendar setting mechanism and it is very simple-
try to pull out crown and you will notice that there are two clicks,so, when the crown is pulled out to the first click, the date can be adjusted by the turn of the crown. When crown is pulled further out (second click)- the watch is in hand setting position and you can adjust time.
Did it help?
Dec 15, 2008 | Colibri PWS-95877-N Pocket Watch
I just bought a Mondaine travel alarm pocket watch. Instructions say the crown has 3 positions. 1> Home normal for a quartz watch. 2> Pull out 1/2 way to set alarm. 3> Pull out all way to set time. My...
It seems like your watch has a little short stem and that's why it has only 2 positions. This does not affect battery in any way, nor the timekeeping.
The only downside of this is that you can accidentaly reset alarm time without knowing it as your watch crown is in permanent 1/2 way position.
If you are happy with that - keep your watch.
Dec 12, 2008 | Watches
Watches Logo
66 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
