Question about Yamaha 01V96 VCM Digital Mixer
Where is fuse 01V96 yamaha - Yamaha 01V96 VCM Digital Mixer
Does a Yamaha clavinova clp 760 have a fuse that may need changing
There are a number of fuses on the main power board ( by transformer ) the sizes differ depending on the country of use but are clearly marked on the board.
REMEMBER TO UNPLUG FROM THE MAINS BEFORE OPENING - if in doubt seek the advice of a qualified electrician
Mar 07, 2015 | Yamaha Music
I have a Yamaha Electone HS-6 which for some reason won't power on anymore.. is there somewhere I can look at to get it fixed? where should I be looking at fixing this? Fuse? power box maybe?
Yamaha has a service locator at http://usa.yamaha.com/dealers/service_locator/ I ran it and it came up with the exact place local to me I would have taken it to. I know their reputation and have had service done by them before with excellent results. Your organ's a pretty complex unit, so if I were you, I'd take it to a Yamaha recommended facility, after checking with Yelp.
Jan 12, 2015 | Yamaha Music
Hen the controller is switched off the monitor comes back VOX
Depending on what other settings are chosen- this at times can be normal. You may be simply switching from the output of the mixer board to the sound input source, and if gain is up and mixer level is up, you will hear it. If it is outputing to the host and it should not be; check stored settings and Scene memory.
Apr 06, 2012 | Yamaha 01V96 VCM Digital Mixer
I have blown the fuse in my yamaha hs80, when getting a replacement i realised it is hard to establish if it is a 0.2A or 2A fuse, as there is some sort of logo before the 2. I was wondering if you would...
Hi,it is hard to tell which one is correct without examining the blown fuse..
May I recommend to you to contact official YAMAHA support site as seen on the link below..
please fill all the blank info ont form and they will return to you in 24 hours..
Additionally I included another link for the user manual just in case..
Take care and if it succeeds please Remember to rate/vote and give me 4 Thumbs Up
for Helping out the Community :)
Hope this helps!
https://inquiry.yamaha.com/global/?act=1&lcl=en_WW&auth=none
About YAMAHA ProductsFor product support:
Please enter product category / model.Send your inquiry to us via the form provided.
Please fill out the following information. Entry fields marked with * are mandatory.
*Required Information
http://www.helpowl.com/p/Yamaha/HS80M-hs-80m-speaker/19026
Yamaha HS80M Manual Pages
Jun 21, 2011 | Yamaha HS80M Powered Monitors
I Have Yamaha Electone HS-4. I already changer a fuse but i have no sound. Someone said, for change a fuse, i must change also a transistor or condensator? Help please. Thanks. andriaharifara@yahoo.fr
the problem is the main output amp. It is an IC so it is better left to a tech to put it in. Just had the same problem with mine. Seems to happen when unit is left on overnight.
Oct 19, 2009 | Yamaha Full-Size Keyboard
Yamaha PSR-79 keyboard fried fuse
i have the same problem please someone help us.
Sep 10, 2009 | Yamaha Portable Keyboard with 61...
Yamaha PSR-280 : AC power instead of DC power
An answer, but likely not a solution. I believe all Yamaha PSR series keyboards use the same 12 VDC adaptor, so I looked at the electrical schematic for another model I have. There seems to be no fuse on the power input. There are two components shown on the positive and negative wires off the power socket, but the symbols do not look like anything I have seen for fuses - they may be resistors. Power goes directly to a 5 VDC voltage regulator, which powers all of the solid state componenents. Too much voltage of the wrong type could have easily ruined many of the sensitive components.
Your only hope is to check the power socket area for the possibility of having fuses. My drawing shows the power socket, voltage regulator, and audio power amplifier being on one circuit board. That may not actually be the way it is in your model.
(your English is fine)
Feb 23, 2009 | Yamaha Portable Keyboard with 61...
Yamaha 01V96 VCM Digital Mixer Logo
64 people viewed this question
Top Yamaha Music Experts
Matthew Spark
Matthew Spark
Mike
Are you a Yamaha Music Expert? Answer questions, earn points and help others
