Washing Machines Logo
Anonymous Posted on May 17, 2009
Washer loud grinding noise spin stop
I got my new Maytag washer model MVWC500VW today. when I open the top on the spin cycle there is a loud grinding sound while the drum is stoppind. I'm assuming it may be the brake. Is this sound normal.
Mike Inman
Level 2:
Champion:
  • Expert 219 Answers
  • Posted on May 22, 2009
Mike Inman
Expert
Level 2:
Champion:
Answers
219
Questions
0
Helped
78884
Points
392
If its brand new it shouldnt be making a loud grinding noise id get it checked make sure they removed all shipping bolts
Maytag Bravos washer starts cycle and fills, but at noise at agitation/spin then starts and fails immediately
i reccomend you check the drive belt if its worn, damaged, or misaligned. motor bearings that are damaged can result to result in grinding noise
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Washer is making a grinding noise
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
Maytag Neptune front load washer model MAH3000AW, load during spin cycle
YOU MEAN LOUD DURING SPIN CYCLE? IF THAT SO, WHAT KIND OF NOISE? BANGING NOISE MEANS YOU HAVE UNBALANCED LOAD OR ONE OF THE SUSPENSION IS BAD OR FELL OFF. GRINDING NOISE MEANS YOU HAVE A BAD TUB BEARING, TO REPLACE THAT, YOU HAVE TO REPLACE THE WHOLE REAR TUB ASSEMBLY, VERY COSTLY. MEANS YOU PROBABLY BE BUYING A NEW WASHER.
[email protected] OR 714-334-1998
1helpful
Loud noise on spin cycle
most common cause for this is pump bearing on water pump. remove belt and attempt to turn pump by hand. if it grinds get a new pump.
10helpful
5answers
Maytag washer makes loud grinding noise during the spin cycle
if it's making a noise then either your drain pump bearing is going out or your thrust bearing is going out (assuming the noise happens in both spin and wash). Tip the washer backwards so that you can get underneath of it. Take the belt off and spin the pump pulley on the right side. This should spin effortlessly.
The middle pulley is the trustbearing pulley. Spin this--- one direction it should have a little bit of resistance--- the other should have more resistance
When spinning it seems the washer is getting louder and louder during the spin cycle. It is a very steady noise no grinding to it. Maybe a bearing?
make sure heavy items are evenly distributed in the barrel. if to loud , stop the machin by openning the lid and make sure the weight is evenly distributed. never just throw laundry in , place it so wieght is evenly placed around.
1helpful
Maytag Washer HAV2558AWW loud noise during spin cycle
Your maytag is really an amana and the bearings are bad. Yes it does cost a lot. If i were you i would buy another washer. Get a whirlpool. (whirlpool now owns maytag)
Maytag Performa - Loud Noises during Spin Cycle
This washer is JUNK!!!!!! We have the same washer (2 1/2 years old) and same problem. Tried to replace the bearing myself, no luck. So I called a repair man to come out and look at it. As soon as i told him the model number, they would'nt even come out. Very common problem for this washer. We are on our way to Sears to purchase a Kenmore.....GOOD LUCK
Top Maytag Washing Machines Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ZJ Limited
ZJ Limited
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
