Question about Razer Audio Players & Recorders
Sound only coming one side headphones - Razer Audio Players & Recorders
My laptop plays sound out of both my speakers and headphones.
It sounds like that port is set to mono, go to properties and check that.
Jan 10, 2015 | HP Pavilion Computers & Internet
When i put head phone in my laptop sound is coming from both sides , outside and also from headphone, how when inserting head phone sound should come from only headphone
On your audio device setting/configuration.Check to see if your headphones are set to be used as the 'default communication device" instead of the integrated sound, or if both devices are set to default. Choose the "headphones" as the default device so that windows will use them only when they are plugged in.
Aug 24, 2011 | Computers & Internet
All of a sudden sound is not coming in one of the channels (right). On pressing the headphone's band a bit sound comes on and goes off.
The cable connects to one headphone and then through the headband to the other side.
I sounds like the cable connecting them that runs through the headband has been damaged.
The only solution is the try and remove the cover from the headband and repair the cable.
Please leave feedback
Cheers
Andy
May 03, 2011 | Audio Technica Audio-Technica QuietPoint...
No sound coming from the "right" side of the headphone?? did I deactivate something??
Sounds like the connection for the right channel is interrupted somewhere- check at the point where the cable enters the actual headphones. sounds like you might need new headphones if yours don't have a removable cable.
Mar 05, 2011 | Pioneer SE-M280 Consumer Headphones
Bose headphones only working on one side
You might want to look at my Tip on replacing plug/cable on headphones, it might solve your problem.
Apr 16, 2010 | Bose On-Ear Headphones
After using the headphone jack on the side of the TV, I've removed my headphones and there is no sound. When I connect the headphones there IS sound coming from the headphones, but when there is no...
try changing the sound output sometimes the tv will change to headphones only so you have so change it back to the tv speakers your owners manual should tell you how to do this
Apr 15, 2009 | RCA L26HD31 26 in. LCD HDTV
No sound
Are the lights on the side on? If not try the little switch on the side of the in line remote, also they need to be plugged into the soundcard&USB.
Dec 25, 2007 | Razer Barracuda HP-1 Consumer Headphones
Sound Issues w/ PSP-1000
Your headphone jack is probably damaged and needs replacement. Here is one I found on the net: Repair your broken "Hands Free" socket, soldering required. This item is also available pre-mounted to the board, ready to plug in. Free shipping.
http://powergamingparts.com/psp-socket-and-housing--replacement.html
Nov 22, 2007 | RaidMax Samurai 908 Yellow Mid Tower ATX...
24 people viewed this question
Top Razer Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Razer Audio Player and Recorder Expert? Answer questions, earn points and help others
