Question about Iomega 1TB Desktop USB 2.0 Hard Drive
My computer doesn't recognize my external hard drive
I have an external hard drive Iomega 1TB USB 2.0 and my computer doesn't recognize it.I tried the hard drive at another computer but it still doesn't work.I switched the hard drive on,it seems like it's working,but it doesn't recognize it on any PC.What seems to be the problem?I've had it for over 5 months and I had no problems with it.I tried with another cable but still doesn't work.I have over half of memory occupied and there are stuff that I really need to save.Please help me!!
  • trajan May 20, 2009
    I have the same issue. I am looking into a SATA RAID enclosure hoping to move the drives and save the data.
  • 696 Answers
Hi Trajan & Cossrock,
Both may be as simple as stopping in at the local computer store and buying a new enclosure to move the drive into, however in Trajans case if the drives were working as a stripe set yours will likely need more in depth help.
So Cossrock, pop into your local computer store and have them test the AC adapter, it may simply need replacing, if not then try moving the drive to a new enclosure. If that doesn't work then you will need the help of a Data Recovery Expert and I can point you in the right direction, just comment back here and let me know how you made out.
Trajan, if your NAS box was simply running two drives seperately you should be able to move them into seperate cases or another dual drive case similar to Cossrocks solution, however if they are RAIDed you will likely need more assistance, please check and comment back if they are in RAID format. Also even if they are not in RAID many NAS boxes use a Linux OS and therefor a Linux format on the drive, if this is the case comment back and I will get you a link to a Linux file format driver but please include your OS Wndows Vista/XP/2000, Mac, Linux etc.
Well folks hope this helps you both out and like I said comment back with an update if you run into trouble and I will keep helping on the next steps.
Chris
Posted on May 20, 2009
3 Suggested Answers
Crankstart
  • 696 Answers
SOURCE: Iomega Prestige 1TB External Hard Drive (34275) adapter
Hi LeoChen,
Most of the Iomega drive adapters do but not all. There's no information on Iomega's site regarding the voltage but if you look carefully at the fine print on the adapter, it should have a Input Voltage Range listing, normally 100-240, if this is the case then as long as you have a cord that fits from the wall to the adapter the adapter will adjust itself to voltage within this range. If you have one of the few that staes only 90-120V for range then the answer is no, but Targus sells a universal adapter for laptops that comes with an appropriate tip for your drive that does support 90-240V.
Hope this helps FixYa,
Chris
Posted on Aug 09, 2009
bronk50
  • 27725 Answers
SOURCE: My iomega prestige 1TB hard
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they could be faulty ?
one bad lead will end with a computer error a computer needs its connections continue its cycle and have an end to function properly
even something as small as an electrical extension or a faulty fan lead can cause this problem
a computer needs all of the data and electrical current to travel through every working device and to have an end to be able work properly
a motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail check all electrical extensions make sure they are securely seated even the cd/dvd floppy drives need to have current go through make sure these drives are working
make sure your computer ram modules are securely seated with no dust in sockets also Cmos battery has charge with no dust in the socket
hope this helps
Posted on Aug 24, 2011
My iomega 1 tb hard drive isn't recognized by computer. Blue light turns on but I don't hear anything from the device itself
What's your operating system? If windows: Check in device manager if its recognized as USB device. You can also look in disk managment
Aug 31, 2013 | Iomega 1TB Desktop USB 2.0 Hard Drive
My sony asnd laptop will no longer recognize the external hard drive
Check it in another pc. If it's the same then the Iomega has died, junk it and get a new one.
Jul 03, 2011 | Iomega 1TB Prestige External USB 2.0 Hard...
I have a white light on my iomega external harddrive. My computer does not recognize it. Is my data recoverable?
There is a chance that the only thing that isn't working on the external hard drive is the actual controller of the enclosure. What you could try doing is opening up the external hard drive to get at the actual drive that's inside. Go online and look for something called an IDE to USB adapter. They are usually relativly cheap, 10-20 bucks. This will plug into the back of the hard drive and then to the computer with a usb cable. See if the drive is readable. or if you have another open SATA port in your desktop computer, just try connecting it as a secondary hard drive. See if it will read it.
Mar 04, 2011 | Iomega 1TB Desktop USB 2.0 Hard Drive
Hello, I plugged in my iomega 1tb desktop hard drive storage device and the drive does not appear in my drive or computer. I do have the new hardware 'sound' that comes up but I dont have the drive show up...
Iomega 1TB Desktop Hard Drive is a dedicated usb 2.0 plug and play external storage device that has an ability to transfer at 480Mbits/second. having these large capacity storage drive needs a fast connection and additional power source to make sure to run the external unit system properly.
just make sure both power and data cables are properly plugged and connected respectively. if you are using it with a desktop, please always plug your usb connection from the Iomega 1TB external drive to the rear USB port in line where you built-in LAN is.do not plug it in the frontload ports. some motherboard manufacturers uses usb 1 and/or 1.1 only for frontload desktop casing provision.
thank you.
Dec 30, 2009 | Iomega 1TB Desktop USB 2.0 Hard Drive
My iomega 500gb external hard disk is corrupted
my pc is not showing my 500gb iomega external at all,in device manager syas all is working correctly
Nov 08, 2009 | Iomega 1TB Desktop USB 2.0 Hard Drive
I have a 1TB iomega external drive but it only shows as 10GB. I have reformatted but it only allows 10GB. What am I doing wrong?
make sure u r formatting in NTFS format since FAT format does not recognize big drives. u can try to use third party software and still do it in FAT32 as long as it is under TB.
Nov 07, 2009 | Iomega 1TB Desktop USB 2.0 Hard Drive
My external hdd used to be reconized and accessable by my computer but after several uses all it does is make a buzzing sound. My computer will not reconize its presence until after it is shut down.
Hi
Its not a software issue with your computer or external hard drive but a hardware issue with the external hard drive. You'll need to get your Iomega hardrive checked from Imomega, hope its under warranty. You can reach them at--
External Hard drive iomega support
Please do accept this solution and revert for further assistance.
Thanks
Rylee
Jul 04, 2009 | Iomega 1TB Desktop USB 2.0 Hard Drive
1tb hard drive with 2 500gb hd's which i need to separate
Use a third party tool to split the drive. Drive image has that capability.
Nov 12, 2008 | Iomega 1TB Desktop USB 2.0 Hard Drive
Computer does not recognize new 1TB ext HD
First I had to reseat one of the drives which had worked loose and become unseated during shipping. Then I had to format the hard drive and finally I had a 1TB external hard drive I could use. The light is still red.
Jul 31, 2008 | Cavalry Storage Cavalry CADB001U32 1TB...
Iomega 1TB Desktop USB 2.0 Hard Drive Logo
1,043 people viewed this question
Top Iomega Computers & Internet Experts
Owen Barnes
Martin Murray
Are you an Iomega Computer and Internet Expert? Answer questions, earn points and help others
