Question about Thetford Porta Potti
I have a spinflo caprice 2020 built in cooker everything was fine until i mentioned to the dealer one side of the control knobs had dropped down.after fixing the grill did not get hot enough to toast or grill anything.it has been back 3 times and,it is still not cured can you give me any idears .les
2 Suggested Answers
greenspan
  • 1734 Answers
SOURCE: Spinflo Caprice 2020 grill
find the manual at http://manualfox.com
Posted on Jun 30, 2009
I have a Leisure Gourmet Classic double oven. The hobs, the grill and the upper oven all work fine, but the lower oven suddenly stopped producing any gas. I turn the knob and the austomatic ignition s
Apparently there is a bad valve for that oven , recommend calling a gas service repairman . your gas provider should be able to recommend a good one to you .
Apr 19, 2017 | Leisure Kitchen Ranges
I have a stoves cooker which was working fine until we upgraded to the seventeeth edition consumer unit and rcds. Now I have a negative earth fault.Rcd trips out, circuit is fine up to the cooker. Any...
The clue will be when the rcd trips out. If everything is switched off on the cooker with the exception of the clock when you power it up and then it trips out, it could be in the wiring to the oven from the control switch and or the wiring in the oven. The only way you are going to find this is to take the oven out of the housing and test the wiring, isolating components until you find the problem.
Jul 31, 2011 | Stoves 720EF Electric Double Oven
I need replacement control knobs for my Cuisinart Slow Cooker
Marbeck has a match, but the link finds nothing. Anybody find anything compatible? It's just a knob. Others should fit????
Sep 07, 2009 | Cuisinart CSC-650 6.5-Quart
Rangemaster 110 gas cooker - RH Oven lights but doesn't heat up
Will the flame go out if you turn the control knob to the off position?
Sometimes gas cooking control knobs have two seperate types of control in the one knob. One control turn the gas on or off, one adjusts the variable quantity of gas allowed through a gap to your flame jets. Some control knobs can get gummed up and stick a little. The can be fixed by carefully taking apart the control knob, taking note of EXACTLY how everything goes back together and cleaning any gummed up bits. Then reassemble the knob and drizzle soapy water over the control to test for leaks. A leaky gas join blows bubbles and makes noise. Let me know if this fixes the problem.
John
May 08, 2009 | Rangemaster 110 (Gas) Kitchen Range
Slow cooker Model SCO-150 switch knob broken
ince replacing the lid and knob will cost several dollars plus postage I recommend purchasing a new one. That way you have new electronics and a warranty which will assure that you have a cooker for at least a year.
Apr 05, 2009 | Crock Pots & Slow Cookers
Radio troubles for 1985 Chevy Caprice
If the car has a built in amp/s for speakers would need to hook the wire from car amp/s up to amp turn on or power ant from radio
Jan 21, 2009 | 1985 Chevrolet Caprice
I have an AEG cooker but the marking around the cooker knobs have
Hi.
You need thermostat knob and main oven control knob.
Nov 19, 2008 | Ovens
Replacement Knobs for the Rival Slow cooker
I HAD the problem with the handle snapping off the lid of my oval 6qt lid - until I spent 10 minutes and $2 in the cabinet hardware section of Home Depot. Now I have a stylish silver & white handle on my crock pot lid. The bolt and grommet were re-used, several little tiny o-rings were added as spacers, along with a drop of Loc-tite.
Oct 31, 2007 | Rival 38651-C 6-Quart
Thetford Porta Potti  Logo
483 people viewed this question
Top Thetford Camping, Backpacking & Hiking Experts
Fredrik Str?hle
Fredrik Str?hle
Level 1 Expert
Tony
Tom Chichester
Are you a Thetford Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
