Question about CAD Microphones GXL2200 Professional Microphone
How do I connect my CAD GXL2200 mic to my apple laptop?
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 24 Answers
You need a USB interface such as an M-Audio M-Track and a standard XLR male to female audio cable.
You use the cable to connect the microphone to the interface using the XLR cable, then you plug the USB cable on the interface to a USB port on your laptop. Finally, you go to System Preferences - Sound - Input and select the USB interface as the input source.
Depending on the software you you use for recording sound (I use Sound Studio from Felt Tip Software) you may need to go into the Preferences for the program and select the USB interface.
Posted on Jun 03, 2016
What USB adapter is best to use with the GXL2200?
If you're going to use a mixer anyway, it'd probably be better to run the mixer into the line-in of the computer. Even better would be to just get a USB recording interface, and do the mixing in the software.
Otherwise, Behringer, Alesis, Yamaha, and probably other all make USB mixers that should be of similar quality (i.e., very low).
Mar 20, 2014 | CAD Microphones GXL2200 Professional...
CAD GXL2200 stopped working.
The first thing you can try is to unscrew the base by turning counter-clockwise, holding the body and screen together carefully. Then carefully slide the main body sleeve downward, and off. The rest of the mic is held together with a frame. You will be able to inspect all the internal wiring and solder joints for poor connections or cracks, The rear PC board is held on by two tiny Philips screws. Remove them and slowly lift the back PC board - it is connected by 3 short wires. This will just allow you to inspect the PC board for bad solder joints or cracks in the metal film. If that doesn't help, you may have to start removing and testing diodes and transistors etc.
BTW, on the front board you will find a tiny lo-cut switch I'll bet you didn't know you had.
Feb 13, 2013 | CAD Microphones GXL2200 Professional...
What is the best way to run the mic on desktop
Your condensor mic requires special electrical handling usually reserved for proffesional audio equipment, not a PC. You will need two pieces of equipment, a short XLR cable and an adapter cable.
1) Behringer PS400 Ultra-Compact Phantom Power Supply.
This will supply the mic with necessary Phantom Power.
2) Rapco Horizon ISOBLOX Transformer Isolation 1:1 BLOX Device
This will isolate the Phantom Power from your computer, allowing it to work as necessary.
The adaptor connector cable you need will be a female XLR (with pins 1 and 3 shorted, pin 2 hot), through a cable connect to a 1/8" mini plug. They connect in that order with a short XLR cable between 1) and 2). .
Aug 23, 2012 | CAD Microphones GXL2200 Professional...
How to work EMU 0204 with CAD GXL2200
Turn on phantom power for mic? Try a different cable.
Aug 01, 2012 | CAD Microphones GXL2200 Professional...
On the CAD GXL2200SP Where is the the power switch for the mic located at? Im not getting anything i have the phantom power and everything plugged up right. But i knw there has to be a power switch...
I don't believe the GXL2200 has a power switch directly on the microphone itself. Would you be able to tell me how you are supplying phantom power to the microphone?
Feb 18, 2011 | CAD Microphones GXL2200 Professional...
Son wants to buy CAD GXL2200sp studio microphone package and wants to plug into laptop.Will that work?
for purposes of recording quality, I would recomend getting and external sound card. M-audio make a good range. You would need to have a +48v phantom power supply for this unit to work. The sound card you buy should have this. A Pc or laptop won't
Jan 16, 2011 | CAD Microphones GXL2200 Professional...
Can I connect a CAD GXL2200SP Condenser Mic to a computer?
Technically, you can plug any microphone into a computer via an audio interface or USB(if applicable) With this mic it will require an audio interface just remember that since you are using a condenser you will need an interface that can supply phantom power. Good Luck, Cody J.
Dec 15, 2010 | CAD Microphones GXL2200 Professional...
I have a gxl 2200 mic and my computer acknowledges the mic but i cant record anything because when i play it back there is no sound
You'll need a phantom power source, like an interface or mixer. Otherwise, the mic is likely in need of repair.
Sep 19, 2010 | CAD Microphones GXL2200 Professional...
CAD Microphones GXL2200 Professional Microphone Logo
169 people viewed this question
Top CAD Microphones Audio Players & Recorders Experts
Michial Gueffroy
Vito Vacirca Jr.
Ben Armstrong
Are you a CAD Microphones Audio Player and Recorder Expert? Answer questions, earn points and help others
