Question about Kitchen Ranges
I need replacement handles for my inkor stainless steel pots
fridgetech
  • 473 Answers
SOURCE: LOOSE DOOR HANDLE ON GE PROFILE ARCTICA STAINLESS STEEL REFRIDGERATOR
I may need to know your model # from the sticker inside the fridge to view a diagram but usually there is are small set screws (usually 2) on the handle which are allen head that can be tightened.  Look for this first and let me know if there are no set screws.  If this is your setup then I would appreciate a solved rating.
Posted on Oct 18, 2007
SOURCE: pan Handle
Try this site: https://www.regalware.com/default.pgm
Hope it helps.
Posted on Nov 20, 2007
SOURCE: Handles for Presto Pride Kitchen Cooking Pots
Go to www.regalware.com .Click on customer services, then click order replacement parts.then click on presto pride
Posted on Jul 07, 2008
DeBruce
  • 145 Answers
SOURCE: stainless steel doors need to be polished
I've personally been performing restoration of high end metal surfaces, bronze, stainless steel, aluminum etc., including scratch removal, polishing, regraining, lacquering etc.. Strictly commercial properties, elevators escalators etc. I've performed these services for 30 years. As a Master Finisher I developed DeBruce Polish, and still perform metal restoration personally.
go to debrucepolish.com
contact: Bruce Smith
Posted on Apr 17, 2009
SOURCE: I have a stainless steel
Yes, these parts can be replaced with stainless steel parats.
Posted on May 05, 2009
What is the role of stainless steel products?
Products which are manufactured by stainless steel is mainly depend up on the type and quality of stainless steel means it may be plain, ordinary stainless, like in a handle or pot, then any alloy steel drill will do. On the other hand, if it is hardened stainless like what is used in instruments, you probably will need carbide, although you might get a tool steel drill to make one hole.
Stainless steel is defined as a steel alloy with a minimum of 11.5 wt% chromium content. Stainless steel does not stain, corrode or rust as easily as ordinary steel, but it is not stain-proof. It is also called corrosion resistant steel when the alloy type and grade are not detailed, particularly in the aviation industry. There are different grades and surface finishes of stainless steel to suit the environment to which the material will be subjected in its lifetime. Common uses of stainless steel are cutlery and watch straps.
For detailed information visit at: Solutions of Stainless Steel Products
Feb 01, 2016 | Maytag MFI2568AES Stainless Steel Bottom...
The carafe for our Mr Coffee BVMC-PSTX91 leaks (has done so from the start). I can't tell if it is just dribbling from the spout and collecting in the joint between the plastic and stainless steel...
Coffee is leaking past the silicon gasket. To get to the gasket, look for a round plastic plug in the top of the handle and pry it up. Under the plug is a screw that prevents the top of the carafe from twisting off. Remove the screw. Will now be able to unscrew the the plastic handle/top part from the stainless steel pot.
Between the 2 pieces is a silicon rubber gasket. Clean everything good. lubricate the gasket all over with "Plumbers Faucet and Valve Grease" available from Ace Hardware. It is waterproof and resists high temperatures.
Replace the silicon gasket making sure the groove fits over the top lip of the pot. Screw the handle/top part on the pot clockwise. It will only twist a short distance, but make sure it is very snug.
You do not need to replace the screw. This will make it easier to take apart if it leaks again. You might be able to get by with petroleum jelly instead of plumber's grease.
Sep 16, 2011 | Mr. Coffee BVMCPSTX91
Need replacement lid for Rival Crock pot Model 5070. 13 1/4" x 10 1/4"
Hi, for the oval lid (SCVS600) for less than $2.00, buy two 3/4 " long stainless steel #8-32 round head (Phillips) screws with self-locking nuts. Using a 5/32" drill bit, drill a hole through the handle at each of the two locations in the handle where the original threaded inserts were located (they are probably out since that is where the handle probably broke). (NOTE: Drill the hole in the handle at the same angle that the original screw makes with the handle because of the curvature of the glass, so that the new screw head will still set flush against the glass.) Using the original inside washer from the original screw, re-assemble the handle onto the lid. The 3/4" screw will not extend out past the top of the self-locking nut - it will sit below about 1 - 2 threads - but that's OK. This sould never break again.
Apr 30, 2011 | Rival 38601 Smart Pot 6-Quart
Faulty handles on arcosteel pots ,i can"t find war...
Broken handle on Arcosteel Saucepan. Where can I purchased or obtain replacement. Live in Illawarra Area NSW
Thanks Lorraine
May 20, 2010 | Arcosteel Stainless Steel Heavy Duty...
Rust in bottom of 10/18 stainless steel pot
Use DeBruce Polish to pacify the steel, we get DeBruce Polish at debrucepolish.com. We especially like it on Ceramic cook tops, refrigerators, stainless steel grills that rust- DeBruce removes it all. Debruce is ECO-FRIENDLY we love it, having replaced 6 products under our sinks DeBruce paid for itself.
Jan 23, 2009 | Ultrex 259-218 Deep Fryer
I have a 4-quart stainless steel Rival Crockpot, somewhat new. Both handles have broken. Would like to order new handles. Model 3040, Q08219
You say it's somewhat new - could it have been manufactured between 1999 and 2004? If so, check out www.rivalrecall.com for information about a safety recall due to breaking handles.
Jul 07, 2008 | Rival 38601 Smart Pot 6-Quart
Stay or go slow cooker
most slow cookers have a flexible element in the bottom of the cooker. the porcelain "pot" fits into the shell or outside of the cooker. heat rises so naturally the outside of the pot will heat up after the pot and anything in it heats up. (radiated heat) some have insulation around the inside of the shell to slow down the heat convection but will heat up eventually. that's why they all have phenolic handles. if they didn't heat up then would you need handles?
May 29, 2008 | Hamilton Beach 33162 Stay or Go Stainless...
Feb 11, 2008 | Presto 06821 Electric Skillet
Kitchen Ranges Logo
189 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
