Question about General Electric WHDRE526EWW Top Load Washer
Started to leak from clear (OVERFLOW) TUBE in backside of washer what could be the cause?
    President:
  • 331 Answers
Geo,
The answer to your question is most definitely NOT what you want to hear, but I'll go ahead and deliver the bad news... (don't hate the messenger, OK?)
The transmission is shot. There, I said it.
Here's what is going on... See? When the washer fills and begins to agitate, the inner tub (where the clothes are) is supposed to "lock". The only thing that's supposed to actually move in there is the agitator. OK... now when the washer advances to "spin mode", the tranny switches gears (think of it like going from "drive" to "reverse") and the inner tub unlocks and is spun up by the tranny.
Your inner tub is not being locked by the transmission when it's in "agitate". When this happens, the inner tub begins to rotate with every stroke of the agitator (the thing in the middle of the tub). So, the tub continues to rotate... faster and faster, until the water in the tub rises because of centrifugal force. Eventually, the water rises high enough to overflow... that's where your overflow tube (and the leak you see) comes into play.
OK, Geo... there's good news if your washer is less than 5 years old. Can you believe it? Good news! The transmission is covered by a 5 year warranty. Yeahhh! Don't worry if you don't have you original paperwork for it. You don't need it. All you'll need to do is copy the exact model and serial numbers down (<-- they're located above and behind the control panel on a white sticker) and holler at GE (1-800-GE-CARES). Give 'em the M# and S# and they'll be able to tell if it's covered or not. Just tell 'em that you had an appliance repair company diagnose you machine with a "failed transmission" and you need to schedule a service guy to come replace it.
If it more than 5 years old, you ask? Well my friend... you are the proud owner of a very large boat anchor cuase that's all it worth right now. The reason being is that a transmission replacement (if you hire it done) would cost far more than the washer is actually worth. Obviously, it's possible to replace on your own... but I would NOT recommend it unless you are very very comfortable with tolls and have many of them accessible to you. The transmission itself would set you back about ~$140.00 (which is more than you'd spend on a good used Whirlpool washer from craigslist or classified ads).
So there ya go. I hope that the information/news I gave you was enough for you to decide which direction to go from here. If it was, please rate my solution here as "It solved my problem". Thanks for using FixYa!
SG
Posted on May 17, 2009
Ge washer mod. wpre8100g0wt leaks out of overflow while agitating
while you have the front panel off look on the left side,you'll see a clear plastic hose,pull the hose off of the tub and cclean out the tube with a plastic tie or a paper clip,also stick it into the hole where it pushes onto the tub,this is from the pressure switch,either the plastic tube is blocked or you could have a bad pressure switch.i've found a number of these washers with the pressure hose caked up with detergent,it will look black in color,hope this helps
Apr 05, 2013 | Washing Machines
Water will not turn off
see this causes and fix it. God bless you
Water Inlet Valve If the washer is overflowing and power is shut off to the washer, the water inlet valve has failed. Replace it.
Pressure Switch If the washer is overflowing the pressure switch might be defective. The pressure switch is attached to a small tube which is attached to the outer wash tub. As the water level rises the air pressure in the tube increases, once the set water level is reached the pressure switch turns off power to the water inlet valve. Check to be sure the air tube to the pressure switch is clear before replacing the switch.
Low Water Pressure from House Supply If the washer is overflowing the water pressure to the water inlet valve might be too low. The water inlet valve requires a minimum of 20 psi to shut off properly. If the pressure is lower, the valve may not close fully when the power is shut off. This results in the valve leaking water into the washer and causing it to overflow.
Oct 16, 2012 | Maytag Washing Machines
Pushes coolent out through expantion tank, acts like it has air bubble even after the car warms up
This is generally a clear sign of a head gasket leaking, or a cracked head/cylinder wall.
Sometimes, in the beginning stages, just a stuck thermostat causing overheating will cause the overflow tank to fill if boiling occurs, but that's generally not seen in a cool engine.
The engine compression going through the leak, pushes air into the cooling system, forcing the fluid out through the overflow tank, or radiator overflow tube.
Good luck with your repair.
Mar 26, 2012 | 1997 Ford Expedition
LSE7806A stack: the wash fills to the water level/load size selected. it starts to agitate then stops and begins to fill with water again which causes overflow, help please
Your fill sensor is leaking and allowing air pressure from the clear tube to seep out. First make sure your clear tube from the tub to the water level valve is firmly connected. If it is then you may need to get a new water level adjuster switch.
Mar 09, 2010 | Maytag LSE7806A Top Load Stacked...
Our washer overflowed last night. no warranty on
Overflow is usually caused by a “stuck-open” fill valve, and the cold water half of the valve is usually the culprit. This can also be caused by the fill system control components: pressure switch, pressure tube, or pressure tube dome/port.First of all, determine whether your overflow condition is mechanical or electrical. Start the washer filling, then turn the timer off by pushing the knob in. If the fill continues, pull the washer plug. If filling continues with the washer unplugged, you have a mechanical problem - nearly always a stuck valve ***’y. Replace the fill valve.i f however, the fill stops when you unplug the machine, you are looking at an electrical fill control problem, Here a small piece of rubber or plastic tubing is handy. Unplug the washer and open the console where you’ll see the pressure switch. This is the switch with a small rubber tube, usually clear, sometimes black, attached. Pull this tube off and replace it with your short tubing. Blow a bit of pressure into the switch using your mouth, and listen for a click, then another when you release the pressure. Hear two clicks? Good! The switch is probably OK, Plug the washer back in (being aware that components in the console are now ‘hot’ and start the washer filling again. With it filling, again blow a bit of pressure into the switch. If the switch is good, the fill should stop and the machine should start to agitate.
This verifies that the pressure switch is working, and causes us to suspect the pressure tubing or a clogged port/dome to which it connects. Wipe off the end of the original tube you removed from the switch, and blow into it. You’re blowing air down into the tank now, and you should feel very little restriction. If it is very hard or impossible to blow through this tube, the tank dome or port is clogged..
Whatever your brand, if air can’t be blown back through this tube, the port or dome will need cleaning.
If you have no trouble blowing pressure through it remove the tube completely and inspect it carefully. This tube must not have the smallest hole in it, and we sometimes see them worn through or, more often, chewed through by mice. while it is the least common cause of overflow, it does happen and is easily overlooked. sometimes this tube will swell and loosen a bit, leaking air where it attaches to the tank fitting. If you suspect this, or the tube fits very loosely, simply cut 3/4” or so off the end and push it back on.
Sep 30, 2009 | Kenmore Washing Machines
Water leaking from overflow tube
pour warm water and baking soda down drain and look for cracks in tube.
May 12, 2009 | GE Refrigerators
Water overflow on washer
  1. some how you have caused the pressure switch hose too come off.it is a clear vinyl tube in the upper timer console area.it is very common for it to come off.it is the water level selector switch/knob,behind is where the tube goes
Jan 24, 2009 | Kenmore 24032\24036 Top Load Washer
Ge washer leaks when you let it fill to top
feel in the back of your outter tub towards the top and chances are you will find a hole ge's love doing this if it is not under warranty you can repair with some JB weld with out replacing the tub
Oct 09, 2008 | GE WBSE2090A Top Load Washer
I have blew threw the clear tube and it still over flows?
i assume it's a top load and not a front load ..could be bad pressure switch,small hole somewhere in clear pressure switch hose or least likely a hole on inside within air dome area but not through tub to cause leak
Sep 28, 2008 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
The washer overflows with water. help
This can also be caused by the fill system control components: pressure switch, pressure tube, or pressure tube dome/port. So let’s take a look at these.
If however, the fill stops when you unplug the machine, you are looking at an electrical fill control problem, and it gets a little more complicated.
Here a small piece of rubber or plastic tubing is handy. Unplug the washer and open the console where you’ll see the pressure switch. This is the switch with a small rubber tube, usually clear, sometimes black, attached. Pull this tube off and replace it with your short tubing. Blow a bit of pressure into the switch using your mouth, and listen for a click, then another when you release the pressure. Hear two clicks? Good! The switch is probably OK, but we’re having fun, so let’s continue!
Plug the washer back in (being aware that components in the console are now hot)and start the washer filling again. With it filling, again blow a bit of pressure into the switch. If the switch is good, the fill should stop and the machine should start to agitate.
Older Maytags are known for this, and if you have one, spin out all water, remove the ‘Corbin’ clamp from the pressure tube outside of the tank and pull the tube off. (Pull washer front off – 2 Phillips screws at bottom, then two 3/8 in. hex screws release top, which swings upward) You will probably see ‘gunk’ clogging both the rubber tubing and the ‘spud’ that is a part of the tank. The hose ***'y can be taken to a sink and flushed clean with hot water, and an old toothbrush used to clear the tank spud, which, in the Maytags, is about 3/4 in. ID.
It is best cleaned from the inside, which means pulling the cabinet and tub. Not beyond the reach of the handyman, this job does require a special spanner wrench to remove the tub nut, as well as the removal of some other components. I’d probably recommend this one as a job for the pro. An experienced tech will have seen this before and be in and out in an hour or less.
The tank port on these washers is too small - only about 3/8 in. diameter, and hard to clean, even from the inside. Here’s yet another job for the trusty wetvac. We are hopeful that Whirlpool will soon enlarge or baffle these ports to correct this problem - one of very few ‘glitches’ these excellent machines have.
If you have no trouble blowing pressure through it remove the tube completely and inspect it carefully. This tube must not have the smallest hole in it, and we sometimes see them worn through or, more often, chewed through by mice. I mention this last because, while it is the least common cause of overflow I see, it does happen and is easily overlooked. We run into this a couple of times each year, usually in the Fall when the mice are looking for a warm winter home.
Also uncommon, sometimes this tube will swell and loosen a bit, leaking air where it attaches to the tank fitting. If you suspect this, or the tube fits very loosely, simply cut 3/4” or so off the end and push it back on.
One last comment on this concerns some newer Frigidaire 27” (wide) machines. These use a piece of tape (!) to secure the pressure tube to the outside of the tank. This tape has to be there (don’t ask me how I know!) or the tube will pull off while spinning, causing flooding. If it has come off, or was removed for service, be sure to replace it. Duct tape will work well; just be sure to clean the tank before attaching to be sure it stays put. Naptha (lighter fluid) will do this well.
Hope this helps,
Sai.
Sep 11, 2008 | GE WDSR2080D Top Load Washer
General Electric WHDRE526EWW Top Load Washer Logo
236 people viewed this question
Top General Electric Washing Machines Experts
Dan Webster
Dan Webster
Paul Bade
Are you a General Electric Washing Machine Expert? Answer questions, earn points and help others
