Question about RCA P52926 52" Rear Projection Television
Rca d52w26 MY tv is 2 years old, been used alot, (wife leaves it on for the dog all day), the other day, it went crazy. looks like i have either 2 or three images of different color kinda like shadows of them selfs but completey different color like 1 red one blue. also when i access the menu controls all the words are out of alignment as well as curved. auto converge as well as manual converge will not fix the problems. i powered down down unpluged for days to see if that would help.. but no change at all... any sugestions? thanks
  • socrates75 Apr 29, 2008
    I have the same problem as the post above but after researching i cant seem to find the IC chips (stk) and was told they might be TDA6120Q IC chips instead? can someone let me know what parts i would need for a D52W26 rca tv?
  • ayynat Jun 02, 2008
    My problem is the screen is has a duplicate in colors sometimes red and blus and all doubled up I have the HDTV D52W26 and it is only two years old aswell its on from morning till night.I can't frind the convergence selection on my TV is there a way to reset the TV to get that selection back to manually converge it?
With RCA units you have a real problem. Most rear projection sets other than RCA use two IC(s) that look like large transistors mounted on aluminum heatsinks , with around 20 pins, #'s stk 392-150 0r stk394- 250 0r stk 392 -140. A simple desoldering of the connections and replace the bad chips then if you are lucky you may not have to redo the service mode alignment of the three colors. But RCA units have basically several transisters on the convergence board instead of the simple 2 chip setup. You will need a meter to test Each seperate transistor after you desolder them from the board so to get an acurate measurement. The meter needs to have diode testing ability. This will take you awile to test them all, there is about 12 or more of this on the baord all with heatsinks. Each row of these controls green horizontal ,green vertical, red horizontal, red vertical and so on. With the board out carefully go over every solder joint with a magnifying glass and lots of light ( no joke), you are looking for small cracks in the old solder. This is not considered an easy fix even for the techs. Sorry but you are basically looking for a needle in a haystack. Even if you attempt this there is a possibility that it is a resistor or diode, or something somewere else at fault. Even if you find a fuse gone you should ask yourself - what made the fuse go. Get the picture. These sets are the hardest to repair , I have spent days looking for faults and RCA has the worst support than any other sets. sorry but that is just the way it is with the RCA
Posted on Sep 24, 2008
You have to have your tubes re-alined, they sometimes do that if the tv has been bumped or jared.
Posted on Oct 17, 2007
    Genius:
  • 1,694 Answers
Do not adjust CRT alignment.Only done when yoke/CRT are
replaced.The problem you described is convergence circuit
and/or power supply repair.At the least,solder pins of convergence IC(s),check power supply for open fuses and research like problems with same model.At times, moving the
set causes a bad connect,which can cause IC failure.If you need
more help,let me know.--T.
I have a rca d52w20 rear projection tv that has sound but no picture what may be the problem
When was the last time the tv projection lamp was change in this tv?The projection lamp in the tv now,if 1 1/2 or 2 years olds,tv on an in uesd like 4 or 5 hours a day?The projection lamp life is over.Require a new projection lamp.Hear alot of clicking too?The board call the Ballast board also require changing.This Ballast board help to ingnite the projection lamp.
Aug 21, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W26 rear projection. 2 years old. 3 times and powers out.
Try replacing CP150, CP114 and CP120 first cost about 12.00 with free instructions available at the following link under the RCA parts category
http://servicemanuals.vstore.ca/
Feb 10, 2009 | RCA P56923BL 56" Rear Projection...
Have you ever had this problem?
Sorry Ginko, but a convergence problem would have the curves down from the top and up from the bottom. The hourglass shape is a pincushion problem. This can be as simple as a bad capacitor in the pincushion circuit.
Could you please confirm the model number so I can look up the probable part?
Thanks,
Dan
Jan 08, 2009 | RCA F32632SB 32" TV
Sorry, here is the original post.
When you press power does the led light at all? That chassis has been plagued with bad flyback causing dead sets sometimes the led will flash 3 times slowly then go out. Other times it will make a soft short hiss. Does your set exhibit any of these signs?
May 12, 2008 | RCA P52926 52" Rear Projection Television
RCA D52W26 that won't power on.
Yes that would be the model number. What item are you needing assistance with, as I have so many people I am helping that I need you to indicate the problem unless you respond by the origional post. Let me know what you need help with and I will be able to help you I have alot of experience with RCA/Thomson models
URGENT: My RCA D52W26 Big-Screen TV won't turn on...AGAIN!
These TVs are RCA biggest mistake ,all most all of these models are shutting down accoding to information you just sneeze and they shut down, Id say try soldering around flyback transformer solder all pins.also they have trouble with ribbon connectors as well as the ribbions.
Apr 22, 2008 | Televison & Video
D52w26
the board with the power cord attached is the power supply/ filter board. please send a pic if possible so I can be sure
Apr 19, 2008 | RCA P52926 52" Rear Projection Television
Generally,pincushion may be driven by a chip or IC,but pin out is normally a durable xistor. Servicer adjustments are minor for pin correction.Go to pin out circuit & measure voltages.Get back to me on your findings.
Nov 04, 2006 | RCA 32V430T 32" TV
RCA P52926 52" Rear Projection Television Logo
1,481 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
