Question about Sears Dual 8 Silent Movie Projector
Sears du all eight projector manual
How to load film.
I need a manual for Bell & Howell Lumina MX60 for an elderly person - need instructions how to load film.
Spec says it's auto-load. From what I recall of my own projector, you mount the input film reel on the front 'arm', extending it as necessary to give clearance, switch on the projector, then feed the free end of the film into the appropriate orifice at the front of the projector.
It then takes over, feeds the film through and wraps it around the take-up spool automatically. It may be necessary to cut the end of the leader on a diagonal to feed it in (not each time the film is loaded, just the first time.)
Once the film has fed through, switch on the lamp, focus and enjoy.
Dec 30, 2016 | Bell & Howell Cameras
How to load a Sears du all 8 1973
Sears 8mm projector with 1950's & 60's films - YouTube
? 13:24
https://www.youtube.com/watch?v=7-IIS8ti7Ig
Jul 5, 2011 - Uploaded by drh4683
Vintage sears automatic projector. ... All 8mm and 16mm movie film, even going back to the 1920's and 30's ...
Sears Du-all Eight - Demo - YouTube? 0:37https://www.youtube.com/watch?v=WHbqCMKUGkoNov 13, 2007 - Uploaded by fierorcr86Buy This Now at www.mycurrentauctions.com I demo a Sears Du-all Eight super 8 ... How to load a Bell ...Sears Du-all 8 auto thread projector - YouTube
Jan 01, 2016 | Office Equipment & Supplies
I need a description for this item
This is a movie projector for 8 MM Film and Super 8 MM film (That is why it is called 'Duel Eight". Does it have a 'Volume Control' knob for sound film? If not is is just for silent film. Does the light come on when turned on and film engaged?
Mar 08, 2015 | Miscellaneous
Loading film
Hi Jacqueline, While I haven't used the particular model you have asked about, I "Googled" the Sears Du-all & got many hits. One of the hits was a UTube demonstration of a working Du-all. The link to it is the first link below. I also found a Sears database that details the manual number, lamp information, etc. That is the second link below. Take a look at these and other links you get when you Google "Sears Du-all". I hope this helps !!! Jim
http://www.youtube.com/watch?v=WHbqCMKUGko
http://www.super8data.com/database/projectors_list/projectors_sears/projectors_sears.htm
Mar 27, 2014 | Sears Du-all Eight 8mm Projector...
I need the owner's manual for a Sears Du-all projector
I believe if you check out the "Manuals & Guides" section of Fixya, they have the manual there. I found many listings for it online, also. Jim
Oct 09, 2012 | Sears Du-all Eight 8mm Projector...
I have a sears easi-load circular tray 9985 for a slide projector. I don't know what brand projector it will fit in. Thanks.
I have a number of these. The printing on the box is as follows:
For use with Sears 9833, 9843, 9853, 9854, 9883, 9884, 98833, Sawyers, GAF and Anscomatic tray-loading projectors.
Apr 30, 2011 | Cameras
How to load the film
http://www.craigcamera.com/lit_b.htm. This is the cheapest I could find for your actual owners manual. I hope it helps. Steve
Dec 15, 2008 | Electronics - Others
Belle & Howell Super 8 Projector model 254RS loading problem
Don't have the motor switch in the still position when loading -make sure it is on FORWARD. Look at the little holes in the film and make sure the film is on the same side as the little grooves on the drive gear.
PS -let the bulb cool off before try to move the projector ,the bulbs are very expensive and hard to find.
If you do use the still position to view a frame do it for just a few seconds or the bulb will burn the film. Good luck- Tom.
Jun 21, 2008 | Bell & Howell Photography
Downloadable instruction manual for Bell Howell 456 super 8 mm dual movie projector
May 20, 2008 | Photography
Sears Dual 8 Silent Movie Projector Logo
153 people viewed this question
Top Sears Video Cameras Experts
J.D. Browning
J.D. Browning
Tony Parsons
Tony Parsons
Are you a Sears Video Camera Expert? Answer questions, earn points and help others
