Question about Car Audio & Video
Purchased a 1995 ford explorer with a 6 disc cd changer and it now will not eject the cd cartridge and when the cd player button in pushed a message comes up ''no dj''. have read the owner's manual and it doesn't give any solutions to this problem any help out there????
    President:
  • 1,114 Answers
If there is a cartridge in the unit, you need to take the player out. pull the housing and do a manual release. do not force it. Possible problem could be 2 discs in the same slot or 2 discs trying to enter tray, either way, if the cartridge is present, it's jammed and needs to be pulled apart. If my memory is correct the factory unit was either Alpine or Clarion. The cartridges are still available at most car audio shops. 20-30 bucks. If you don't feel comfortable pulling the unit, most custom shops can check it on the spot, and let you know if it needs to be sent out for repair. Stay away from Best Buy, etc... go to a custom shop that's been around for a while and you'll get honest service.
Posted on May 17, 2009
2 Suggested Answers
ronaldo_ross
  • 1056 Answers
SOURCE: 1995 Explorer 6 cd changer - how to manually eject cartridge
No there is none you have to hook up power to it then press eject.
Posted on Jun 27, 2009
I have CDs jammed in side 6 disc changer (factory)> I have tried resetting the system by removing and replacing the fuse, but still get CD Error> If I need to remove the unti, is there an easy way...
Press and hold eject button,insert a credit card under cartridge
Push card fully in and move left /right right/left
This will locate micro switch to release cartridge
May 30, 2011 | 1992 Ford Explorer
I have a 1997 Ford Explorer purchased new with te
is there a coin holder in front of the changer? if so, there may be a coin lodged inside the changer preventing the carrier mechanism from moving. look on the bottom of the changer to see if a coin might be stuck.
Mar 11, 2010 | Clarion DC625 6-Disc CD Changer
How do I instert a CD into my pioneer deh-p6200 car radio?
Slide the door open (1/2 gray 1/2 silver door) on the disc changer, inside is a push button that ejects the 6 disc cartridge. Load and unload cd's into it.
Oct 05, 2009 | Pioneer CDX-P1280 12-Disc CD Changer
Jun 27, 2009 | Panasonic CQ-DPX33 CD Changer
I have a 2004 Ford Explorer Limited which has a 6 cd player. I do not have satellite service. A couple of days ago, I pulled into my driveway and turned off the ignition. After the engine cut off, the CD...
If it's a remotely installed CD changer (not in-dash) you've got a pretty good chance of getting it operational again. You need to pull the unit out of the vehicle and take the cover off of it. #1 phillips screws 6 or 7 pop the top and look down at the loading mechanism, chances are it tried to eject a cd int an occupied slot and jammed. Gently slide the cd back towards the player side so it's out of the cartridge, leave the top off and plug it back into the truck. it should automatically reset itself. If this is sucessful, eject the cartridge and inspect the slots, if they are warped or bent, replace it with a new one. If you have a Laser Lens Cleaner that uses fluid, use it. If not, get one, they can be purchased at almost any retailer for 15-20 and will extend the life of the lens quite a bit. Run it thru 3 or 4 times a year, it only takes a minute. If your unit is an in dash changer... It's kinda the same process, but alot more work. The unit has to be pulled out of the dash, which takes a little time, then it has to be disassembled, if your not a nuts n bolts kinda guy/gal, let a car audio shop do it for you. If you need more help, post a comment and I'll help some more. Hope this helps
Jun 11, 2009 | Car Audio & Video
6 disk cd changer in 2002 Ford Explorer V8 AWD
I have a 2002 Ford explorer and a 6 disc cd changer, all slots are full, no CD's will eject or play. I just took my car to a local body shop, they went under the hood, disconnected my battery, plugged it back up and my CD's came out when I pushed the eject button
Nov 06, 2008 | Car Audio & Video
CD PLAYER FORD EXPLORER
I have an '03 Explorer with the 6 disc changer. It does the same thing. Many times, you can set the radio to "FM1" and hold down buttons 3 and 6 on the radio. This will put the unit into self diagnostic mode. After it runs the diag., turn off the ignition and remove the key for at least 30 seconds. Sometimes it takes a couple times but it always works on mine.
Oct 12, 2008 | Car Audio & Video
Cd error message
Try to disconnect battery contacts and connect it back. Check also if there is an emergency opening device. In some model you have a pin hole underneath the cd tray. push a staple tip inside the hole, and this will release the cd.
If the tray still does not open, you may need to have a repairman opening your stereo at your local service point.
Regards
Apr 03, 2008 | Car Audio & Video
6 cd changer
try to reset the cars computer. i had the same problem and it fixed it. all you need to do is unplug the battery for about 10 minutes and it may work. Good luck!
Oct 26, 2007 | Car Audio & Video
Changer won't acknowledge discs
hi make sure that you cart is inserted all the way in, push the eject button why hitting the mag with the handle of ascrew driver. this may dislodge the jammed arm/lever. otherwise its down to your repair agent.
regards
Mark
www.carradiospares.co.uk
Jul 30, 2007 | Alpine CHM-S620 6-Disc CD Changer
Car Audio & Video Logo
272 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
