Question about Amana Haier AP125HD Air Conditioner
How often do i have to drain the amana ap125hd
Drain water
3 Suggested Answers
hvac1960
  • 2133 Answers
SOURCE: I have a Amana portable
Better
Posted on Dec 06, 2010
heinzhvac
  • 229 Answers
SOURCE: how do I remove the
What are you trying to do? what kind of problem are you having?
Posted on Jun 30, 2011
I purchased a Haier Amana commercial cool portable air conditioner tonight and there seems to be something missing. There is a little hole in the rear of the unit that is discharging water, there is no...
Since there are no specific numbers for your equipment, I will respond generically. Part of the cooling process is removing moisture from the air. This sounds like it is a condensate drain. You may be missing a hose or a pan or both, that collect the moisture removed from the air. This is the only reason I know of for any A/C unit to be discharging air unless it is a water cooled unit.
Sep 09, 2017 | Amana Haier AP125HD Air Conditioner
How do I remove the back of the amana AP125HD portable air conditioner?
Jun 30, 2011 | Amana Portable Air Conditioner
I have an ap125hd and the fan doesnt blow in heat mode everything works good in cooloing
Toget proper heat, keep your temp setting at 30+ degree and also mode in "heat"position. If still no heat, check your heating sensor for closed circuit by anOHMs metre.It it's with RV, check power to RV
Dec 30, 2010 | Amana Haier AP125HD Air Conditioner
My 1 year old Amana portable air conditioner (model AP125HD) is not getting as cold as it should. My attempt at troubleshooting was to reset the unit, check to see that the options are properly set, be...
inside there is a filter attached to the motor. you will have to unscrew and open the unit to clean it off. it will be approximatly 6 to 8 screws to remove. i used a damp cloth to wipe the dust which was as thick as carpet(lol) cuz my unit is 4 years old and after that it is as cold as ever. also refrain from using the inlet hose as it attract more debris to that filter but still use the exhaust. hope this helps
Jun 26, 2010 | Amana Haier AP125HD Air Conditioner
Is there something I'm supposed to change or clean at the end of the season? What and how? Water tank? Filter? thanks!
there is a drain pan which you should empty often and a filter somewhere which you can hose off and let dry in the sun... clean that filter somewhat often like once a month.
Oct 10, 2009 | Amana Haier AP125HD Air Conditioner
Heater not blowing hot air display says lo
when the coils freeze up , from intake of outside air, when using the heat pump mode, the unit will try to defrost the coils before going back to heat mode. mine did this alot. does it kick back to heat after a few mins? also after 2 years , mine started having issues with the exhaust blower control and would go into warp mode and bang noise.seems like common issues for this unit.whether the amana, or haier version.
Dec 13, 2008 | Amana Haier AP125HD Air Conditioner
Heating & Cooling Logo
56 people viewed this question
Top Amana Heating & Cooling Experts
Bill Long
Pete Norton
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
