Question about Pioneer Elite Vsx 50 Av network receiver
Flashing ue33 on pioneer elite vsx-50
Flashing ue33 on screen
SOURCE: Need a user manual for my Pioneer Elite VSX-07TX
I have this receiver, and just scanned the manual for an individual. If you still need a copy of it, let me know and we can figure out how to get a copy to you. Regards, Berry bcaddell@icsystems.net
Posted on Jan 12, 2009
Gurudristi
  • 98 Answers
SOURCE: Pioneer VSX-D209 receiver shuts off when too loud
Dear Tabasco,
Your receiver is basically going into protect mode.
Just check your speaker cabling again. Make sure that all of them are seated properly, none is touching each other or the body of receiver. Take out all the wire and put them back again if necessary..
Some times even a little tiny frayed wire touching the receiver could trigger the protect mode. Be careful, since protect mode is sometimes not fast enough and it could blown a few trasistors in the power circuit.
Just check your speaker as well....whether they play all right thru another receiver or amplifier. its posiible they might be shorting inside. A little frayed wire could also trigger the protect circuit in your receiver.
I hope this should solve your problem.
If everything else seems all right and still your receiver shut down when you raise the volume then it possible that there are bad connections on the main board that are set in.
This would generally happen if the system is slighly old or have dry solder and when you raise up the volume. This should be a simple repair that will not require parts. If you can solder, you will be able to repair this yourself. If not, then a local service center will change the local labor rate.
Hope you can sort out your problem with the above trouble shooting. Let me know if I can guide you further.
Best of luck! Thanks for using FixYa!
Posted on Apr 21, 2009
  • 5 Answers
SOURCE: pioneer elite VSX-92txh freezes up and cannot be turned off
There is a fix for this problem
Posted on Dec 19, 2009
SOURCE: I have a VSX D710S and it flashes poweroff then
Im having this same problem. It happened after I had the music up really loud for about 3 hours. Also, where it has the volume all i see is -- instead of a number when i try to turn it on
Posted on Jan 07, 2010
SOURCE: Pioneer VSX-1019 with a flashing red MCACC
you can "release" the error by pressing the "down arrow" and the "zone 2 on/off" for 2 seconds.
Posted on May 23, 2010
Why does my Pioneer Elite VSX 50 overheat?
Shorted component/s at its audio output stage circuit. Check and replace it. Check the site linked here. Pull up older posts. Check whether its cooling fan works properly.
If you want further advice over phone; visit https://www.6ya.com/
Aug 23, 2016 | Pioneer Elite VSX-50 7.1-Channel 3-D Ready...
Tip
How to make a Pioneer vsx-816k/s last longer
I really don't recommend this product to anyone, or any newer pioneer products for that matter (except the elite line). This model has the "hybrid" design, which is a very flawed design. At first the speakers will start cutting in and out, and then some of them wont work at all, and then the receiver will flash "overload" and the receiver will go into a permanent protection, all because the receiver cant handle the resistance of the speakers(doesn't matter what speaker it is). Once in protect mode, press ENTER+ ADVANCED SURROUND and it will tell you what the problem is causing it to stay in protect mode. In order to keep this from happening, use external amps. Pioneer wants around 500 dollars to fix it if its out of warranty, it will cost at least 50 to fix it yourself, in most cases it will cost 150 to fix it yourself (most cases all 3 power modules will go out, or as pioneer calls them, power packs). If you have an older vsx model (50s-80s) then it is usually worth fixing. If your having problems with pioneer vsx 3600, 3700s, 3800, or 3900s, send me an email at Joshadk@embarqmail.com and i will help you the best i can
on May 16, 2010 | Pioneer VSX-816-K/S Receiver
I bought a used Pioneer VSX 50 receiver and it did not come with the remote My old remote is not pairing with it. How do I get them to work together?
Hi Pamela,
if the old remote is not for the same make and is not one of those multi remotes that can now be bought then it will not work with the pioneer VSX or if it is from another Pioneer VSX then it may need to have the code re entered by Pioneer.
I would suggest to go to a shop that sels equipment of the same kind and ask for their advice and also whether they do multi controllers that would work, a shop such as Maplin (if you have a Maplin store where you live as they can be very helpful with such problems).
GOOD LUCK.
Feb 06, 2015 | Pioneer Elite Vsx 50 Av network receiver
Hdmi picture sound pioneer elite pro r04u
disconect video cable from the box and if you see color video bars on the screen the problems is the box.if you dont see anything you problem is in the display
Nov 10, 2013 | Pioneer Televison & Video
On my Pioneer receiver (model # vsx-9100tx) MCACC light keeps flashing and system will not power on. Please advise.
Hi the mcacc light keep's flashing and will not come on. Can you help with this thank you Lee
Dec 22, 2010 | Pioneer Elite VSX-9100TX Receiver
Manual for pioneer elite ex 500 really need the manual for tge receiver it is a pioneer elite vsx 50, i can not find a free download for it anywhere
I went to Pioneerusa.com then support then home audio video then older models. They list a 49 and a 51. No 50. You can download any manual from their site for free. Is it a USA model? if not, post a comment and I will find the info for you. Hope this helps
Jun 20, 2009 | Pioneer Elite EX500 600Watt A/V Receiver...
Pioneer Elite VSX-94THX USB problem
There is probably no files on the usb that are recognised. Just a guess check the compatible formats
Dec 29, 2007 | Pioneer Elite VSX-9100TX Receiver
Pioneer Elite Vsx 50 Av network receiver Logo
558 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
