Question about Amana Haier AP125HD Air Conditioner
Why does amana portable air condition ap125hd needs to be drained after every use
SOURCE: Amana AP125HD Portable Air Conditioner This
I have this Amana/Haier unit. I recommend reading the Owner's Manual because it actually discusses this issue although a bit indirectly. I've used the unit in Mississippi, and it's voltage and surge sensitive, and the Manual implies.
So, when the Manual says to put the unit on its own circuit, and to make certain that the circuit is also fully capable of supporting the electrical load, including the full amp load noted, it means it, in my experience. I even had to ditch a work-around long extension cord (albeit a heavy-duty, rated one).
The long term solution was making sure the machine was getting clean, non surging, non sagging AC power on its own circuit to the main board. And then ... it's worked flawlessly in heating, cooling, drying and ventilation modes.
One last thing ... the Manual is also serious about leaving the unit to sit still for 12-24 hours if it moved and rotated from the vertical. If fhe oil moves inside and can't resettle, it can also trigger motor shutoffs.
I hope this is helpful for enjoying what seems to be a well built machine.
Posted on Feb 23, 2009
hvac1960
  • 2133 Answers
SOURCE: I have a Amana portable
Better
Posted on Dec 06, 2010
SOURCE: Heater not blowing hot air display says lo
when the coils freeze up , from intake of outside air, when using the heat pump mode, the unit will try to defrost the coils before going back to heat mode. mine did this alot. does it kick back to heat after a few mins? also after 2 years , mine started having issues with the exhaust blower control and would go into warp mode and bang noise.seems like common issues for this unit.whether the amana, or haier version.
Posted on Feb 18, 2011
heinzhvac
  • 229 Answers
SOURCE: how do I remove the
What are you trying to do? what kind of problem are you having?
Posted on Jun 30, 2011
  • 50 Answers
SOURCE: amana portable air conditioner
you need to empty the drain pan every couple of hours depending on the humidity level
Posted on Jul 21, 2011
Hi, I have an amana ap125hd portable air conditioner and for some reason is doesn't produce cold air anymore. Then fan blows and the compressor kicks in, but to no avail, no cold air. I took the unit...
replace it,most likely the freon leaked out,if the compressor is running and the fan is blowing but not getting cold most likely you have a leak in the sealed system.
Jul 09, 2011 | Kitchen Ranges
How do I remove the back of the amana AP125HD portable air conditioner?
Jun 30, 2011 | Amana Portable Air Conditioner
I have an ap125hd and the fan doesnt blow in heat mode everything works good in cooloing
Toget proper heat, keep your temp setting at 30+ degree and also mode in "heat"position. If still no heat, check your heating sensor for closed circuit by anOHMs metre.It it's with RV, check power to RV
Dec 30, 2010 | Amana Haier AP125HD Air Conditioner
My 1 year old Amana portable air conditioner (model AP125HD) is not getting as cold as it should. My attempt at troubleshooting was to reset the unit, check to see that the options are properly set, be...
inside there is a filter attached to the motor. you will have to unscrew and open the unit to clean it off. it will be approximatly 6 to 8 screws to remove. i used a damp cloth to wipe the dust which was as thick as carpet(lol) cuz my unit is 4 years old and after that it is as cold as ever. also refrain from using the inlet hose as it attract more debris to that filter but still use the exhaust. hope this helps
Jun 26, 2010 | Amana Haier AP125HD Air Conditioner
Is there something I'm supposed to change or clean at the end of the season? What and how? Water tank? Filter? thanks!
there is a drain pan which you should empty often and a filter somewhere which you can hose off and let dry in the sun... clean that filter somewhat often like once a month.
Oct 10, 2009 | Amana Haier AP125HD Air Conditioner
Dec 13, 2008 | Amana Haier AP125HD Air Conditioner
Amana AP125HD Portable Air Conditioner This unit now seems to randomly shut itself off, beeping 4 or 5 times after doing so. Not on a timer. I can restart it immediately, but will shut off again in an...
My AP125HD had exactly the same symptoms. It did not matter what ac outlet I used where the air conditioner was.
But...THIS PROBLEM STOPPED once I moved the ac cord to an outlet outside of the house. This outlet is on it's own separate circuit breaker and I have no other electrical equipment/appliances on it.
I guess the user manual is correct that this unit should be on a home circuit all by itself!
Jun 02, 2008 | Amana Haier AP125HD Air Conditioner
Heating & Cooling Logo
Top Amana Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
