Question about In-Sink-Erator Ise 9008 Garbage Disposer Power Cord 3F - Each
When trhe power button is pushed the blades don't rotate the unit just hums
  • In-Sink-Erator Master
  • 5,245 Answers
Kenmore 3/4 hp garbage disposer does not work, it only hums.
Do not turn on... humming sound will overheat motor
See if cutter disc located inside disposal can be moved and rotated using broom stick:
If disc rotates freely, then try motor again... if still hums, then replace disposal
http://waterheatertimer.org/How-to-repair-and-install-Garbage-disposal.html
Gene h
Mar 25, 2014 | Kenmore 3/4 hp Food Waste Disposer
Motor just hums,grinder wedges are free, no leaks apparent,motor turns free in both directions.
yes there is start capacitor on each motor, connected to start winding.
There are two windings on each motor: start winding and run winding.
Both windings receive power at same time. If the start winding is bad, or capacitor is bad, then motor hums as the run winding receives power but there is not enough torque to get the motor rotating.
If motor is humming instead of rotating, then quickly the motor overheats and looses speed after repair or melts and fails.
The problem with disposal repair is getting the thing apart... finding replacement capacitor, or replacement parts, and then reassembling without a leak.
http://waterheatertimer.org/Color-codewire.html#motor
http://waterheatertimer.org/Color-codewire.html#Motor
Gene
h
Nov 15, 2013 | In-Sink-Erator Garbage Disposals
Kitchen aid kadette 250
with the power "off", check inside the unit to make sure nothing is jammed in there. assuming the interior is clear, try the reset button which is usually located on the bottom of the unit. may need to use a mirror and a flashlight to locate it. if the unit hums (indicating power is there) but it does not rotate/turn/work, use your "disposal key" or a hex wrench to turn it manually: usually inserts on the bottom-middle of the unit; turn it both ways to free it up.
Jul 05, 2013 | Garbage Disposals
Reset button not working
Try reset button on bottom of disposal.
Following link has full troubleshoot resources:
If reset will not restore functionality, check that unit is getting power, and then check that unit is receiving 80% rated voltage. Replace disposal.
Add a comment
Jun 20, 2013 | Whirlaway Garbage Disposals
Replace garbage disposal shredder disc
Which direction does disposal blade turn?
For example when looking straight-on at the nut holding power saw blade, the blade rotates counterclockwise, so the nut is reverse thread.
Most disposals are not made for repairs
Add a comment and say where you are getting the parts and which model
May 25, 2013 | Kenmore 3/4 hp Food Waste Disposer
In-Sink-Erator Ise 9008 Garbage Disposer Power Cord 3F - Each Logo
Top In-Sink-Erator Garbage Disposals Experts
john h
Gil Shultz
Robert A. Watson
Robert A. Watson
Are you an In-Sink-Erator Garbage Disposal Expert? Answer questions, earn points and help others
