Question about Mantis 2-Cycle Tiller
What is left to do but change the flywheel?
2cycle mantis tiller has no spark i have changed the spark plug and the coil and still no spark, switch is new also.i have cleaned up all the contacts on the engine and the coil and the flywheel.
  • Renrut1211 May 19, 2009
    engine will not fire. I have replaced the coil, cleaned all contact points on the flywheel, cleaned all the rust where the coil is attached. I think I can barely feel it fire when I put my finger on the spark plug, but it is so weak that I'm not sure if it's firing or just vibration from turning the engine over.
  • Anonymous Mar 26, 2014
    We have replaced the coil and spark plug and cannot start. Upper portion of engine was cleaned.
    New Friend:
    Problem Solver:
  • 11 Answers
Is the air gap measured on mm or inches?
Posted on Dec 04, 2015
  • 284 Answers
Check what they call air gap between the coil and flywheel .010-.012 gap
also be sure your flywheel is in time.
you will actually have to remove it to do this and check for the sheared key or be sure the key way aligns with the crankshaft keyway on the flywheel
Posted on May 26, 2009
  • Joe Saubolle
    Joe Saubolle Dec 04, 2015
    Is the air gap measured 8n inches or millimeters?
Mantis tiller no spark
Hi anon two thing's that it could be. Firstly it could be the coil is fouled by Corrosion or secondly the switch that you switch on could have failed.
Jun 08, 2014 | Mantis Tiller
New coil and still no spark on my GC 160 Honda tiller
Did you check the gap between the magnet on the flywheel an mag? Unplug the stop wire an see how that works. Sometimes the switch is bad. Are the magnets on the flywheel, did you set the gap on the flywheel to mag correctly? Did you do the simple thing an change the plug they go bad more than anything else.
Mar 25, 2014 | Garden
My mantis tiller 2cycle: Iput new spark plug the on&off switch ok just not getting a spark to the plug. Think its the coil ?
I would say it is the coil, if you have a multimeter you can connect it to the coil and try to start it to see if it producing voltage. Hope this helps Tim
Apr 16, 2011 | Mantis Gas Mini Tiller/Cultivator, 2 -...
I have a manis tiller that wii not run rigth. i have put i a carber kit
My mantis tiller ran fine,I put it up for the winter and now it won't start,I checked to see if it was getting gas which it was, could it be the coil? I did check and they say its very rare that the coil goes out.I also check for any type of spark and nothing. Please help!!!! thanks ,Clay
Mar 26, 2011 | Mantis Gas Mini Tillercultivator 2cycle...
Won't start. have replaced plug and cleaned filter. any suggestions?
check and see if your coil is grounded,if not clean flywheel magnet and check for spark if no spark replace coil,
Jul 28, 2009 | Mantis 4-Cycle Tiller/Cultivator with...
I Have a Mantis tiller that I can get NO spark
set the coil to the thickness of a dollar bill from the flywheel and tell me what happens. make sure kill wire isn't grounding somewhere else
Jun 07, 2009 | Mantis 2-Cycle Tiller
Mantis tiller sv-4 echo engine no spark from coil mantis 2cycle tiller i got it running tryed to start it 4hrs latter same old problem wont start, plug wet with gas wont start. coil was checked by shop...
Sounds like it's flooding either from over choking or the inlet needle in the carb is leaking. Have you removed the plug and blown out the cylinder and plug with air and then tried to restart? Be careful not to keep cranking with the choke pulled out. When it 'hits' ONE time, move the choke halfway in and crank again
May 31, 2009 | Mantis 2-Cycle Tiller
No spark
No spark can be several things but begin with the easiest first.
  1. Ensure the grounding wire (thin black wire) that connects to the coil is not grounded.
  2. Ensure sure the plug wire end is connected well to the plug wire, some of these clamp the wire interior cord to the metal wire end by wrapping and crimping around the plug wire.
  3. Make sure the ignition generator coil is not scrubbing against the flywheel, there should be .030 air gap between the coil and the flywheel magnets.
  4. If you are mechanically savy, remove the flywheel and inspect the breaker points, replace/adjust as needed.
May 26, 2009 | Mantis 2-Cycle Tiller
Mantis tiller sv-4 echo engine: no spark from coil
There are only 4 parts to the 2-stroke Mantis ignition system: the spark plug, the "kill button", the flywheel with embedded magnets, and the coil with integral plug wire. There are no "points" to clean or refurbish. If you've tried a new spark plug, unplugged the wire leading up the handlebars, and the magnets on the side of the flywheel are strong enough to attract a screw driver blade, then it must be a bad coil. That's all it could be. End of story.
Cruising the internet I see where these Echo coils go bad all the time. You can order the coil, but if the machine hasn't run in several years the carb will also need cleaning. So one thing leads to another. The gear box grease also needs replacing each year. What I'm trying to tell you is these are disposable tillers and due to length of time, incomplete care/ storage, ....whatever, this one's time is up.
Sorry.
Feb 26, 2009 | Mantis 2-Cycle Tiller
Mantis 2-Cycle Tiller Logo
1,101 people viewed this question
Top Mantis Garden Experts
paulfvincent
Jim Parker
Jim Parker
Mike Squire
Are you a Mantis Garden Expert? Answer questions, earn points and help others
