Question about Brookstone Handle-Mount Grill Light
I can't get the battery cover off Brookstone grill light
I follow instructions but can't get cover off
Change light in whirlpool gold accubake system upper microwave oven
If you need to replace the bulb for the interior cabinet, you'll need to remove the two screws that holds the upper grille in place with a Philips screwdriver.
Access to these screws are from on top of the microwave.
Once you remove the grille, you should see a white plastic cover with a release tab; pop the open and you'll have access to the bulb compartment:
Watch the following youtube video- the instruction phase of removing the grille and access to the bulb compartment starts at 2:40
http://youtu.be/RQM302PShKw
Mar 04, 2015 | Whirlpool Ovens
How do I change the light bulb on the Brookstone Daimond 367RL... how does the flush ceiling mount glass cover come off...
contact manufacturer tech support they will guide you on which light style is in your unit for removal of lens without breaking it
Jan 10, 2015 | Coachmen 2011 Brookstone 367RL
Replace the led's
LEDS have very long life. I dont believe that is the issue. Can you post the make and model and what happened?
Apr 06, 2014 | Brookstone Handle-Mount Grill Light
I can't get the cover off my grill light can you help
I had the same issue. There is a rubber O-ring that makes ti waterproof and is very tight when new. You twist counter-clockwise as per instructions and then use your thumbs from underneath the cover to pop up one side of the cover (and possibly work the other side as well) until the seal is broken. Once you open it once it gets much easier.
Dec 24, 2013 | Brookstone Handle-Mount Grill Light
How to put batterys in my grill light
I had the same issue. There is a rubber O-ring that makes it waterproof and is very tight when new. You twist counter-clockwise as per instructions and then use your thumbs from underneath the cover to pop up one side of the cover (and possibly work the other side as well) until the seal is broken. Once you open it once it gets much easier.
How do you change the batteries of the bbq grill light
The battery compartment is the opposite end of the light from the on/off buttons. Turn it counter clock wise about 1/2 turn and the batteries should push the end cap out. Remove it all the way. If the unit is new and doesn't have batteries you might have to pull the end cap to get it free of the compartment. Once the cap is free tip the batteries out, replace with new batteries, replace the cap and tighten by turning it clock wise.
Nov 05, 2013 | Brookstone Handle-Mount Grill Light
How do I put batteries in the brooks tone BBQ grill light
I had same problem. Note you cannot see down the Battery tube as there is a top attached to the battery cover that turns. I worked a very thin screwdriver head between that top and the light unit, and the cover then wiggled free rather easily.
Jan 09, 2013 | Brookstone Handle-Mount Grill Light
Unit beeps continuously
I had the very same problem and some web research suggested my unit was dead. However, I called Brookstone and they informed me that a faulty probe is typically the problem. I ordered a "Replacement Probe for Grill Alert (SKU# 558783)" which cost $15 (plus shipping and tax). This solved my problem, was well worth it as I like the Grill Alert, and I cooking turkey tomorrow!
Feb 10, 2012 | Brookstone Grill Alert Talking Remote Meat...
Brookstone grill alert manual
My grill alert will not connect to the remote prob? The prob flashes yellow? The unit is trying to connect at least but doesnt happen.
Dec 21, 2011 | Brookstone Grill Alert Talking Remote Meat...
Brookstone Handle-Mount Grill Light Logo
222 people viewed this question
Top Brookstone Grilling Experts
paulcarew
Dan Webster
Dan Webster
Are you a Brookstone Grilling Expert? Answer questions, earn points and help others
