Our Air Condidition is not getting cold. Have no manual
Our new Air conditioner is not getting cold. It only blows air and eventually gets so hot, it smells like burning conponants or wiring. We lost the manual and need to see first if we can print an elecronic manual. Can you help us? We purchased from AirForce BX and cannot locate the receipt. thanks Nancy
Continental Elecrtric Air conditioner Model CE14085
  • dcastillo7
    dcastillo7 Sep 07, 2012
    Were having the same issue with it not cooling, it trys to kick on but keeps blowing hot air we also bought ours at the local Air Force base, the cooling numbers only goes up to 18, we have the manual but it has no solution as to how to trouble shoot! We talked to a local Air con tech and they have never heard of this modle and has no clue how to get parts for it, if you could please advise as to what could be the problem. Thank you
  • Anonymous Mar 26, 2014
    i have lost the manual and cant get it to blow warm air
  • 148 Answers
Check the wiring to thermostat sounds like the reversing valve is open letting hot gases through
Posted on May 17, 2009
Why does my 2005 GMC truck air conditioner will blow cold air then hot air?
possibly low coolant, that will make the clutch disengaged and you get hot air instead,
Jul 22, 2014 | Heating & Cooling
Air conditioner
Check whether the warm air isn't going in with the cold air .Coolant line that runs into the firewall on the passenger side of the engine which is toward the bottom half of the firewall on the passenger side. If there is warm air going into the vents with the cold air then it blows warm air. You may have to shut it manually because it gets stuck sometime. Check it out.
Jul 24, 2012 | 2005 Honda Accord
The air conditioner blow out cold air on the
try checing the vacuum hoses-may be difficult to do this--get manual at store--the connectors and lines are probly failin
Apr 18, 2010 | 2001 Buick Century
My duted air conditioning started blowing hot air instead of cold and then stopped. blew a fuse and now will not work
Sounds as if the compressor has gone bad. The blowing of hot air and then the fuse blowing lets you know the compressor is pulling a lot of amps causing the fuse to blow and no cold air could mean the compressor is locked up and therefore you need a new compressor.
Dave
Jan 24, 2010 | Honeywell ER150B Air Conditioner
Air condtioning unit
check capicitor on motor, fan motor bearings may be locking up when they get hot then when cooled the motor comes back on. Then you must replace fan motor.
Aug 11, 2009 | Heating & Cooling
Uotside unit blowing cool air but hot on the inside
It sounds like you have a unit called a heat pump. When a heat pump unit is in cooling mode the outside unit blows hot air and the inside unit blows cold air. If the outside unit is blowing cold then the indoor unit is most likely blowing room temperature or warm air. It sounds like the thermostat could be controlling incorrectly or you could have a failed reversing valve which is the device that switches the unit from heating to cooling mode.
May 31, 2009 | Ruud UBHC Air Conditioner
Comp shuts off
Coils could be dirty. Compressor could be getting too hot and cutting off. Will have one fan motor that turns condenser fan and evaporator blower.
May 30, 2008 | Fedders D Chassis A6D24E7A Air Conditioner
Heating & Cooling Logo
583 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
