New ibuypower windows install error
Computer restarted unexpectedly restart installation
MJS_1
  • 150 Answers
SOURCE: When I switched on my
This sounds like a corrupted XP installation or possibly a damaged hard-drive, either through a hardware failure
or through file system corruption.
(the last scenario is the most likely)
Windows uses write back caching to improve performance.
This means that data is not immediately written to disk, but
the writes are delayed until there is enough data to make
it worth while.
Also, the NTFS system uses transaction based data transfers,
which set a dirty flag, write the data, update the file indexing
structers (MFT) and then clear the dirty bit on a hard drive.
If a PC unexpectedly looses power, or if it is hard reset during
a disk access operation, the hard drive may be dirty or
corrupted. For this reason, reseting or powering down a PC
without going through a proper OS shut down is a very bad
idea.
The correct procedure is START ==> SHUTDOWN ==> options,
and let windows do its thing.
Having said that, the NTFS file system is very robust, with
transaction logging and indexing redundancy, such that
it usually recovers from such events, by automatically
scanning and repairing the hard drive's index structure
when the system is re-booted.
For some reason, this has not happened on your machine,
and for some reason, windows is trying to re-install itself.
This may be due to and automatic recovery partition and
utility built into your computer. Most modern laptops have
a small, hidden HD partition, on which they store a rescue
copy of the operating system, along with some diagnostic
and recovery utilities.
This recovery mode is often activated by a special button
(such as the IBM BLUE BUTTON) or a bypressing a special
key combination during start-up.
1) Try completely powering down and restarting your machine.
Wait a couple of minutes after power down, then physically
remove the battery.
2) Wait a couple more minutes, put back the battery and
restart the machine.
3) If this does not help, you have one of the following:
a) Damaged operating system / aborted re-installation
b) Damaged file system through improper shut down
c) Hard drive failure
d) Bad settings in the BIOS or within the BOOT.ini file
causing the system to boot from an incorrect hard drive
or partition. (but this is unlikely)
At this point you need to call tech support for model specific
instructions on operating system recovery.
Martin
Posted on Apr 24, 2008
  • 44 Answers
SOURCE: when turning on my hp
you can do a system recovery. turn unit off. once you turn it on press f11 key select recovery manager then system recovery
rate me if this helps
Posted on Jun 03, 2008
  • 90 Answers
SOURCE: I bought new laptop and
Try booting your system with the Windows installation CD.
Thank you.
Thomas
Posted on Nov 16, 2008
  • 192 Answers
SOURCE: I am doing a clean
Ok, first blets try and use the eRecovery program.
When you turn the system on, and it displays either the ACER logo or black screen with white writing, press F2 or Del to enter setup. It should display what to press in the bottom left corner of the screen.
This will open the BIOS settings. There should be a tab at the top called Main, select it. Somewhere on the list there should be something called D2D Recovery. Highlight it, and make sure it's Enabled. Now, while it's highlited, it will display what keys you need to press to start the recovery program. This is usually Alt+F10. Now save your settings and exit.
The system will now reboot. When the ACER logo or black screen with writing appears, press the keys that you saw in the BIOS. The Acer eRecovery program should now start. Follow the on screen instructions.
Hope this works, let me know
Posted on Apr 11, 2009
computer254
  • 31 Answers
SOURCE: I keep getting an error screen after a system
If this was a windows system restore try picking another date before the one you just carried out.
Its going into a loop because its missing some information ,or your restore method was not windows system restore but acer recovery only a drivers and OS system restore,try pressing F8 on start-up and see if it will boot into safe mode this should allow you to check all the drivers and also do a virus check which I suspect is Master Boot Record based, If the problem persists and you have no way even after trying out safe mode use complete Acer System Recovery to factory defaults this will then make a backup file on the desktop labeled windows old backup where you can then recover documents,music,photos etc
Posted on Feb 28, 2011
Testimonial: "Thank you. I have tried Safe Mode, Restore with keeping my files and a restore to Factory Original and all give me the same results."
I had to factory reset my tablet and after it factory reset it shut off and when it turned on again it said 'the computer restarted unexpectedly or encountered an unexpected error.
Help laptop wont start after resetting factory settings - Acer ...
www.tomsguide.com/.../77186-35-help-laptop-wont-start-resetting-facto...
Mar 25, 2012 - 5 posts - ‎2 authors
i restored my laptop back to factory settings as it kept crashing, now when i ... TVs · Cameras · Smartphones · Tablets · Software · 3D Printing; More ... or encountered an unexpected error, windows installation cannot ... then restart the installation... i do this and its just repeating itself, i have no recovery discs.
"The Computer Restarted unexpectedly or encountered an ...
heresjaken.com/the-computer-restarted-unexpectedly-or-encountered-an...
Feb 1, 2013 - Now your computer will restart and continue on the Windows setup process ... THOUGHT MY 1000 DOLLARS COMPUTER HAD CHRASHED AND .....setup experienced an unexpected error" To install windows, restart the installation. .....JUST fyi - I had a similair problem on a Surface Pro 3 tablet and this ...
encountered unexpected error when going to factory reset ...
h30434.www3.hp.com > Laptop & Notebook > OS/Recovery
Jan 13, 2016 | Computers & Internet
New ibuypower. Turn on, goes to open windows & error pops up saying unexpected restart & asks to restart to finish installing windows...does this repeatedly?? & won't do anything else...
It seems to be missing some of the windows install files. I'd suggest contacting the retailer, and ask for either a fresh install of windows, or a recovery media
Dec 29, 2015 | Computers & Internet
My new acer aspire 7560-sb416, Windows 7 laptop won't boot. Error: "the computer restarted unexpectedly or encountered an unexpected error. Windows installation cannot proceed. To install...
Try pressing F8 whilst booting to get into safe mode, if this will not work your only option may be to restore to factory settings either from the hard drive partition or from a Windows 7 DVD.
Aug 25, 2013 | Computers & Internet
Resetting to factory settings trouble
You are caught in a loop. Have no recourse other than to use your restore disks and attempt a repair or new installation.
Sep 06, 2017 | Acer Aspire Z5600 PC Desktop
Trying to Re-install windows 7. Got the following error: "The computer restarted unexpectedly or encountered an unexpected error. Windows installation cannot proceed. To install Windows, click...
So was this the issue then? You can run the Windows Vista Upgrade Advisor to see if there are any compatibility issues that you may be having with hardware or software that would prevent an upgrade to Windows Vista.
I hope this helps.
Mar 28, 2011 | Microsoft Windows 7 Ultimate for PC
I did recovery manager. When it restart den it says ((The computer restarted unexpectedly or encountered an unexpected error. Windows installation cannot proceed. To install Windows, click ''OK'' to...
The previous windows installation is either damaged, or did not complete, it is asking you to put your windows disc in so that in can proceed with the installation.
The recovery manager must have damaged your windows installation
Sep 05, 2010 | HP Pavilion dv6000z Notebook
I have a BRAND NEW HP Pavilion Notebook which I just switched on for the FIRST time. It has come up with an error message, ie: "The computer restarted unexpectedly or encountered an unexpected error....
Your windows installation CD might have become corrupt. Use a fresh CD and enter into BIOS settings to set Default Settings before installation.
Try & reply.
Sep 11, 2008 | HP Computers & Internet
Computers & Internet Logo
David Payne
David Payne
