Question about Samson Meteor Mic - USB Microphone
Steady red light
I can't get the blue light on despite connected to usb port in my mac
Sumvision egem external hdd
more often hardware compatibility issue, try using different usb cable first,
Mar 18, 2014 | Apple Computers & Internet
Error code10 device refuse to start
PC or mac
try other PC?
try all direct connected, to PC , USB ports.
does the light glow red/green or blue? LED? if not , it has no power.
or is dead.
this slow drive gets its power from the USB port.
and is weak power and problematic , across all platforms.
the horses mouth
http://en.faq.buffalo-global.com/app/answers/detail/a_id/11884/p/1492,1493
Sep 29, 2013 | Buffalo Technology Buffalo 1TB MiniStation...
Red blinking light
Hi, Ephraim. The flashing red light indicates that the device is showing "low battery". It could be that the LG phone charger fits the charging port on your bluetooth headset but it is not compatible with your device. In order for you to know that it is charging, the device should show a steady red light(means charging).
Please take a look at the table reference below.
•With the Charger Plugged In
______________________________________________________________________
•Headset Indicator Headset Status
Red-----------------------------------------------Charging (battery level less than 50% charge)
Yellow-------------------------------------------Charging (battery level more than 50% charge)
Green--------------------------------------------Charging complete
With No Charger Plugged In
Off ---------------------------------------------Power off
Three blue flashes------------------------Powering on/off
Steady blue --------------------------------Pairing/connect mode
Rapid blue/purple flashes -------------Connection successful
Quick blue flash --------------------------Incoming/outgoing call
Slow blue pulse --------------------------Connected (on a call)
Slow blue flash ---------------------------Standby (not on a call)
Slow red flash ----------------------------Idle (not connected to phone)
Slow purple pulse -----------------------Connected call muted
Steady red ---------------------------------Attempting to connect
Quick red flash ----------------------------Low battery
Note: After 20 minutes on a call or of inactivity, the light stops flashing to conserve power, but the headset remains on
Hope that'll help you in some way.
**Please rate my post and/or leave a comment** ...Thanks...
Sep 25, 2013 | Motorola Mobility H560 Bluetooth Headset
A blue and red flashing light and won't connect to computer
External hard drives not only provide additional storage space on a computer system but also allow data to be conveniently transported from one computer to another.
These drives typically plug right in to a port on the computer and function without any additional setup; however, if you are running into trouble where your external hard drive is not being detected, you must troubleshoot the situation to determine why the drive appears to be missing.
Check the USB connection running from the hard drive to your computer.
If the USB cable is not seated securely in the port, the computer will not detect the external drive.
Disconnect the USB cable from the computer and plug it into a different USB port. Occasionally, a USB port will fail to function with some hardware and changing the USB connection may correct this issue.
Switch from a USB to a Firewire cable connection, if possible.
The USB port on the hard drive may have died; if so, changing to a Firewire connection will resolve this issue.
Install the driver for the external device from the installation disc provided with the product. Older computer systems may require you to manually install this driver.
After inserting the installation CD, follow the prompts from the installation wizard to install the driver on your computer.
Restart the computer.
If you connected the external drive while the computer is powered down, it may not recognize the device when you turn on the computer.
After restarting the computer, connect the external drive to the system.
The drive should now be detected by your operating system.
Connect the external hard drive to a power source and then plug it into your PC computer using a USB or Firewire cable.
Log on to your PC computer using an account with administrative privileges.
Open the Start menu and click on the "Control Panel" icon.
Open the "Administrative Tools" folder and then double-click on the "Computer Management" icon.
Select "Disk Management" from the list of options on left side of the window.
Right-click on the drive you want your computer to recognize and select "Change Drive Letter and Paths."
Select a drive letter for the external hard drive to be recognized as and click "OK."
The drive will now appear in My Computer.
Hope this helps.
Nov 22, 2012 | NexxTech new 3.5-inch hard drive enclosure...
Wont stop flashing green and I can not connect to xbox live yet I used to be able to Any Help Thanks, Paul
IF The LIGHT IS FLASHING GREEN then there is something wrong with your wireless network
Check your network settings and Retry connecting
Check the adapter's status light loadTOCNode(2, 'moreinformation'); The adapter's status light can tell you a lot about the state that the adapter is in. Here's what the different lights mean:
  • Steady green light: The adapter is connected to a wireless router, gateway, or access point. The adapter is ready to use.
  • Steady red light: The adapter is not recognized. Try plugging the adapter into a USB port on the front of the Xbox 360 console.
  • Flashing green: The adapter is attempting to connect to a wireless network.
  • Flashing red light: There is a problem. The adapter might be experiencing a hardware failure. Contact Xbox support at http://www.xbox.com/support/contact (http://www.xbox.com/support/contact) .
  • No light: The adapter is not receiving power. Unplug the USB connector and plug it in again. Still no light? Try plugging the adapter into a USB port on the front of the console
Jan 10, 2011 | Microsoft Wireless Network Adapter Xbox...
The blue light on my Maxtor is blinking really fast and my Mac no longer recognizes the connection. How can I fix this?
Have you tried restarting your Mac (with the Drive still connected)?
Otherwise try:
1. Disconnect the USB cable from your Mac.
2. Restart your Mac.
3. Reconnect the USB cable to a different USB port on your Mac (like the keyboard USB port for example).
See how you get on. Let me know. Regards,
Feb 16, 2010 | Maxtor OneTouch II 300 GB Hard Drive
Resume light coming on but printer won't work
Normal 0 Probably has corrupt driver.
Try disconnecting the Camera from the USB port and reinstall the software program. When the program asks you to connect the camera to the USB port, do so and it should work.
Hope this helps. Bud
Jan 03, 2009 | Office Equipment & Supplies
Supertooth one user manual
Charge your Supertooth one via the car charger or by attaching a usb/mini usb cable to your computer usb port. Need to charge for 4-10 hrs. Indicator light glows red (needs charging), orange (charging) or green (charged)
Power on: Press green button for 1 second. Indicator light blinks blue. A beep will be heard
Power off: Press green button for 1 second. Indicator light turns red. A beep will be heard
To pair with your mobile phone:
1. Press green button on Supertooth for 5 secs until indicator light blinks red/blue 2. Access bluetooth menu on your phone. Turn bluetooth on. Execute a bluetooth search. 3. Select ST ONE from list 4. When phone requests password enter 0000 and press OK 5. The handsfree kit is now ready for use 6. Clip Supertooth on sun visor of your car so that the microphone and control buttons are directed towards you.
To make a call: Dial number on phone. Supertooth will automatically connect. Indicator light is steady blue during call
To end a call: Press red button for 1 second
To answer a call: Press green button for 1 second. The bluetooth indicator will turn a steady blue.
To increase/decrease volume. Press volume buttons repeatedly up or down. They are situated between red and green buttons.
Hope this helps.
Nov 22, 2008 | Cell Phones
I can't get it to work
try back ports might have bad unit plug on the mouse bad
Jan 28, 2008 | HP Wireless Optical Mouse
Samson Meteor Mic - USB Microphone Logo
141 people viewed this question
Top Samson Audio Players & Recorders Experts
Michial Gueffroy
 Grubhead
Grubhead
Jerry Umali
Are you a Samson Audio Player and Recorder Expert? Answer questions, earn points and help others
