Question about Microwave Ovens
Lg mh6644b everything works but dont heat
Lg 700 w microwave everything is working as normal but the food is not heating up
There three parts that will cause this, the first is the magnetron "heats food" the most expensive part, followed by the high voltage capacitor and diode, they work in conjunction to generate the high voltage to cook the food.
Feb 03, 2011 | LG Microwave Ovens
My LG (model ms3446vrl) wont heat anything. Everything else works fine. It is only 2 weeks out of warranty too, not happy. Lynda
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Jan 04, 2011 | LG LMV1680ST Microwave Oven
Microwave model MV-1510M is not heating, also sounds louder. Everything else is working, fan, lights, turntable etc..
If everything is working normally, except for heating, the likely cause is the magnetron.  Microwaves can be dangerous to work on, as the site below points out.  If you have an ohmmeter, it is possible to check the magnetron, but be certain to follow the precautions outlined at the webpage:
http://www.gallawa.com/microtech/mag_test.html
Oct 08, 2010 | LG LMV1680ST Microwave Oven
My lg microwave is not heating food everything seems to be working fine
Basic Microwave Oven Troubleshooting Tips
heatman101
[00000000000
Sep 15, 2010 | LG Microwave
Microwave not heating anything? everything else work
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
heatman101
fgshg
Jul 28, 2010 | LG LMH1517 1000 Watts Convection /...
Everything works ok except strange hum and no heat
When the microwave sounds okay, but there's no heat, one of the internal door switches, the high voltage circuitry, or the circuit board may have a problem. To resolve this problem, you need the assistance of a qualified appliance repair technician.
If it is under warranty you are golden. If not, you should get an estimate, as many new microwaves are now in the 50 dollar to 99 dollar range
May 21, 2009 | LG LMV1650ST Microwave Oven
Have a goldstar microwave apparently made by lg and last nite it just stopped heating everything else works fine just will not heat
Check the fuse between the highvoltage terminal of the transformer and the hivoltage capacitor. If it is Ok replace the magnetron.
May 07, 2009 | Microwave Ovens
Lg LMV1630st stainless steel microwave oven
I'm confused. If it's 6 weeks old, you can get it repaired free.
If it's 1-1/2 years old, the manufacturer will cover the part cost of the magnetron (assuming that's what's wrong) and you will have to pay for labor and any other needed parts.
Also, the subject line mentions a model LMV1630ST while your message body mentions model LMV1680BB.
For Goldstar / LG / customer service, help, call 1-800-243-0000 (M-F, 7am-8pm CT, Sat 8-5 CT) and choose the appropriate prompt from the menu or visit here.
Chances are your problem is a bad magnetron, but it may be another high voltage part.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 27, 2008 | Microwave Ovens
Goldstar NV1502 No Heat
You should still have about a 5-year warranty on the magnetron, if that's the trouble.
If everything else works, it's almost certainly a high voltage component, most likely the magnetron or diode, but also possibly the transformer.
Generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose connection at the magnetron
- problem or loose connection on the control unit circuit board
- bad magnetron or other high voltage part (such as a shorted diode)
If you or someone you know decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
I would contact LG / Goldstar first. For Goldstar / LG / L.G. help, call 1-800-243-0000 (M-F, 7am-8pm CT, Sat 8-5 CT) and choose the appropriate prompt from the menu or visit http://www.lgservice.com.
We're happy to help and we appreciate your thoughtful rating of our answer.
May 05, 2008 | Goldstar MV-1501 Microwave Oven
Make sure the door is aligned and closes safety switches.
May 02, 2008 | LG LMV1630ST Microwave Oven
Microwave Ovens Logo
24 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
