Bryant wiring diagram
No need diagram for furnace 394gaw036125
5 Suggested Answers
flatech
  • 111 Answers
SOURCE: bryant programmable thermostat will switch on furnace
Turn the power off to the Air handler unit.
Remove the thermostat from the wall, (Just the face part).
Look on the back side of the thermostat and verify that the jumpers are set to electric and not gas, otherwise the fan will not run during heat mode, they come from the factory usually set for gas.
If this is a electric heater this will solve your problem, If it is gas then it will be more detailed. Once you put it back on keep in mind that most thermostats have a 3-5 minute delay so just give it a little time and the fan should then work once you have the jumpers in the correct position.
FlaTech
Thank you for using FixYa!
Posted on Nov 17, 2009
SOURCE: need wiring schematic for model#
I will advice you contact the dealer for the wiring schematic of your device. This is the best option that you can use to get the wiring schematic for your device.
Take care.
Posted on Oct 03, 2010
SOURCE: I need a wiring diagram
I have it, but the image is too large to upload directly. Email me at calonzo@yahoo.com if you want it.
Chris
Posted on Nov 08, 2010
SOURCE: need wire diagram for 3207-121189
a/c compressar not warking supply coming
Posted on Mar 29, 2013
Bryant plus 80 furnace no fan/ operation , yellow constant flashing light code , power to furnace was rerouted during remodel and since then furnace stopped working. Any suggestions ?
You need to have/ know the "fault code" chart for that specific furnace. Count the number of flashes and refer to chart. Look on the inside of the furnace blower door or other panel. Also look up on internet and print it off. If the furnace was allowed to run during the remodel it voids the warranty automatically. Read the installation manual.
Try resetting the electronic board by turning the power off then back on.
Mar 29, 2017 | Bryant Heating & Cooling
On a Bryant furnace 373lav what is error code 41 furnace tries to light imonitor lights up but the won't light
Code 41= blower out of valid speed range. you will more than likely need a new motor module. they are not cheap 300$ to 400$. If you call a carrier or bryant tech out they should have a test module they carry on their truck that lets you know if its the furnace circuit board or motor module.
Jan 02, 2015 | Heating & Cooling
WIRING DIAGRAM FOR BRYANT 127ANA036-A
The blue wire from the Ac goes to the y2 on the board for the furnace the yellow and brown goes to c on the board for the furnace and the last wire goes to y1 on the board for the furnace
Jun 16, 2014 | Bryant 462AJC021BA Air Conditioner
Carrier furnace HK42FZ011 wiring diagram
carrier plas 90 bryant Gas Furnace wont light - LED has 2 blinks what can be
Dec 25, 2012 | Heating & Cooling
From the furnace what are the blue, white, green, red wires
here's a link to a wiring diagram which is pretty standard.
http://ingramswaterandair.com/images/HCD1%20AC%20Models%20Installation%20Manual.pdf
Color what it does terminal
Blue 24V common C
White to heat control (gas valve) W
Green manual fan operation G
Red 24V power to thermostat R
Yellow activates comp during cooling Y
Sep 27, 2009 | Bryant 462AJC021BA Air Conditioner
Wiring to bryant furnace/ac
your t-stat maybe now not talking to the furnace remove it temporarily to check
Apr 09, 2009 | Honeywell Electrical Supplies
Why Wont My Bryant Furnace Stay Running
Look on the blower door panel in the wiring diagram there should be a flash code but it sounds like the flame sensor is not picking up the flame and you may be able to clean it
Oct 28, 2008 | Heating & Cooling
Honeywell thermostat
If you have a forced air furnace with an air conditioner attached make sure you have a jumper wire between Rh and Rc. If the Bryant thermostat had a wire hooked up to C you do not want to hook this up to Rc. Just cap it off and put it back in the wall or disconnect that wire down in the furnace.
Aug 10, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
13 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
