Question about Yamaha RX-V373 5.1 AV Home Theater Receiver Black
How can I hook bose cinematic speakers to a yamaha rx-v375 receiver
Ajkill
  • 2035 Answers
SOURCE: yamaha rx-v2500 receiver how to hook up speakers
You can hook the speaker like this one center speaker , two front right and left speaker,and then rear right and left speaker and one sub speaker in the unit ...
Good luck...
Posted on Oct 06, 2008
hbsurfdawg
  • 95 Answers
SOURCE: Yamaha RX-V1400 receiver powers off, in case it becomes louder
Hey, yeah that can be frustrating.
When you turn it up do you hear the relay or a clicking sound, then you turn it on and it comes back below the +2db?
Try unplugging All the speaker wires from the unit. Turn on the unit and listen for the click.
after the click, turn it up past the 2+ db mark and see if you hear it click or shut down. If it did not click off, then suspect a shorted crossover on one of your speakers.
2nd test is to plug in One speaker, and test it at high volume, it will not harm it. If it shuts off disconnect that speaker and try another. Only one at a time.
If it works at high volume, you need to isolate one of your speakers and i bet it has a shorted crossover that has been cooked. P.S. If one is bad, suspect they will fail at a later date.
If they all fail, use a friends speaker and try it before sending it to a repair shop.
P.S. i found one on ebay i think you can get for under $100 bucks in the box.
http://cgi.ebay.com/Yamaha-RX-V1400-7-1-THX-Select-Receiver-MINT-Condition_W0QQitemZ330311512027QQcmdZViewItemQQptZReceivers_Tuners?hash=item330311512027&_trksid=p3286.c0.m14&_trkparms=72%3A570|66%3A2|65%3A12|39%3A2|240%3A1318
E
Posted on Mar 02, 2009
easyq
  • 144 Answers
SOURCE: The subwoofer is not working on our Bose 5.1 surround speakers.
First of all you should never indicate speakers as Large unless they can produce below 20Hz (which is very low), otherwise always set your speakers to Small.
Second, did you also indicate in teh setupmenu that you have a subwoofer? Because if all speakers are set to Large some receivers will omit a subwoofer because Large indicates the speakers can reproduce all sounds even below 20Hz.
So walk through your setup menu, say YES when the sub (SFW) is asked for and that should do the trick.
Posted on Apr 17, 2009
SOURCE: Yamaha RX-550 receiver. Presently, no sound on
This solution helps! I got this unit from a friend and there was no sound from the left channel, and after playing with the input knob, there was sound.
I sprayed alot of electronic cleaner and it worked like magic.
the unit is now in full working mode.
Posted on Mar 22, 2010
dunnbiker
  • 8546 Answers
SOURCE: Yamaha RX-V365 unable to receive 5.1 audio from TV with HDMI
If you're expecting multichannel sound FROM THE TV instead of from the source you're watching, it's not gonna happen. TV's are notoriously poor sound sources. This one is no different.
Multichannel TV-related audio is best found at its source - cable / sat / dvd / bd....
I run video-related audio from my video sources directly to my TV and their audio directly to my receiver. Specialization yields best results.
I'd recommend skipping the Receiver for video, too, as it adds a lot of opportunity for HDMI-related incompatibilities and sound syncing problems. The more interconnects in the path, the more distorted it will become and the more opportunities for problems. Plus you can bypass the receiver and listen to lo-fi programming like news and weather through the TV's speakers if you like. Save a buck on electricity.
Just curious, which HDMI on the receiver is connected to your TV? Input or Output?
This note is on Page 11 of the manual:
Audio signals input at the HDMI jack are not output from any speaker terminals but output from the connected video monitor. To enjoy the sound from speakers connected to this unit,
-- make an analog or digital connection besides the HDMI connection (see page 13).
-- mute the volume on the connected video monitor
"Check SP cable." -- The unit is perceiving a short circuit. Are your speaker impedances sufficiently high? Disconnect the Front Right speaker and try raising the volume again. The speaker may be blown or the cable shorting.
Posted on Apr 30, 2010
Would a Yamaha RX-V1 drive the Bose 901 Series VI speakers well?
The Bose 901's can handle up to 450w per speaker, using the Yamaha receiver, would not be MY first choice. Considering you invested in bose for a the quality of the brand, don't short change it like that with a lower powered receiver. NOT saying it won't do it, IT WILL, HOWEVER, if you really wanna see what those bose can do, get something more than the Yamaha RX. (110 watts)
Speakers like power, its best to run them at a minimum of 225watts. the closer you get to the 450w the better. 110watts is just too low, and can damage the bose. HECK, under powering ANY speaker can damage it QUICK!.
Oct 14, 2016 | Bose Audio Players & Recorders
Yamaha Receiver won't turn on after USB plugin in. Help!
Unit is in protect mode. Sometimes an ipod draws too much current through the usb jack and causes the unit to shut down due to an abnormal voltage being detectected. Press and hold the 'info' and 'tone control' buttons and push power. This should turn the unit on. Turn it back off and turn it on again and should power up normally. If the ipod continues to make the unit shut down when plugged in, try and make sure it is fully charged before plugging it into the receiver - this may help.
Apr 13, 2014 | Yamaha RX-V375
Yamaha RX-V375 turns off during periods of heavy subwoofer/base sounds. Sometimes it turns itself back on, other times not. Help!
most likely you're hitting the clipping or the threshold of the power.
the other possibilities is you have a small short there.
one way is unhook our speakers, tidy the cable u and hook it back to make sure there are no shorts.
if this does not solve the problem then you just might be hitting the limit of your receiver which the only way is to change receiver or your speakers to match them
Oct 27, 2013 | Yamaha RX-V375
Just purchased the Yamaha RX-V765 receiver. Have
I too have purchased the same receiver and have the same speakers. Did you get a good solution to this problem and how does it sound?
Jul 26, 2010 | Yamaha Audio Players & Recorders
How do I connect to my Yamaha RX-V490 some bose speakers. The ones that are only 2
Perhaps if you named the Bose system or go to Bose.com and find its manual.
Sep 05, 2009 | Yamaha RX-V490 Receiver
I can't seem to hook up my DVR and VCR.
Hi..
Go to the site:
http://www.yamaha.com/yec/home.html?VNM=LIVE
Look up your model number.
You might need to register for a free password thing
Dec 18, 2008 | Yamaha RX-V461 AV Receiver
Hooking up a Yamahoa RX-V861 without a manual
If you jump on the Yamaha web site you can download the manual which will show you how to connect the speaker system. Hope this helps.
Regards
Nov 17, 2008 | Yamaha RX-V861 Receiver
Yamaha RX-V373 5.1 AV Home Theater Receiver Black Logo
98 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
