SOURCE: connecting bluetooth headset
You have to go through a process to pair the devices.
Firstly:
Make sure bluetooth is turned on on your laptop (varies for each model)
Make sure the headset is fully charged.
With the headset power off, press and hold
the Call button for 6 to 10 seconds until the
blue indicator light turns on and remains
steadily lit.
Then goto the bluetooth control panel and select "Look for Devices" or similar. Wait until the device has been found and when it asks for a passkey, enter 0000 and press okay.
see some more info at: http://tinyurl.com/2bz7hc
SOURCE: PASSCODE
hi have motorola h700 bluetooth device but i forget my passcode how do i reset it again i tried many passcode like 0000, 1234, 1111 ,2222, 3333,4444,5555,6666,7777,8888,9999, but its not connecting wat do i do nw.. plz solve my problem.... my email address is [email protected]
SOURCE: Motorola S805 headset worked fine with T60 laptop
Solution I found with the same devices is to properly par the devices.
Refer http://direct.motorola.com/ens/s805/QuickstartGuide.pdf
It basically states :
1.Ensure the headphones are turned off (L indicator light not blinking).
2.Press and hold L button. After about 6 seconds, the L indicator light becomes steadily lit.
3.Release the L button. The L indicator light remains steadily lit.
If the L indicator light is flashing or not steadily lit, repeat steps 1 through 3
Now on the T60:
Search for Bluetooth Devices as you would normally.
The T60 lists Bluetooth devices it finds.
Select Motorola S805.
Select OK or Yes to pair your headphones
with your phone.
Enter the passkey: 0000
Select OK.
When your headphones successfully pair
with your phone, the L indicator light
changes from steadily lit to rapidly flashing.
That's it next time you start a audio program on T60 output will be sent to Motorola Headphones
