Question about Dishwashers
Ge potscrubber 580 will not completely drain - Dishwashers
  • 35 Answers
SOURCE: dishwasher not draining fully
Remove and replace the motor / pump assy. Call technician. Big Job
Posted on Dec 09, 2007
SOURCE: GE Potscrubber 1000 with temperature sensor GSD1000M20-Water in bottom at end of cycle
Does it sound like it is trying to drain or is it just silent?
Posted on Jul 27, 2008
localwonder
  • 6784 Answers
SOURCE: Potscrubber 900 Dishwasher won't drain
HI. check the following areas for faults.
1. Air gap / Drain hoses
If there is an air gap (located in the sink, near the faucet), check to see if it is clogged. Unscrew the top cap and see if there is anything blocking inside. Note: If there is no air gap installed, the dishwasher might not drain properly.
If the drain hose is clogged, the dishwasher would not drain. If there is an air gap installed, it is very common that a hose going from the air gap into the garbage disposer is clogged. Remove and clean the hose. Make sure to reattach the hose before starting the dishwasher.
Note: If you recently had a garbage disposer installed, it is common to overlook removing the drain plug.
2. Broken belt
Some dishwasher models use a belt to drive the pump. Replace the belt if found broken.
Note: Sometimes the belt would just come off the pump. Even though it might not be broken, it is recommended that you replace the belt, because it is probably too stretched out.
3. Pump
Some models have two impellers inside the pump - one, wash impeller, takes care of the wash cycles, the other, drain impeller, drains the water out. If the drain impeller is broken (broken blades, shaft), the dishwasher would not drain. Replace any broken pump components.
4. Drain solenoid
Some models (for example most GE dishwashers) use a drain solenoid to drain water out. Sometimes the solenoid gets stuck, preventing the water from draining out. Try to free up the solenoid. If unsuccessful, you might have to replace the pump assembly.
5. Motor
If the motor is stuck, it is sometimes possible to free it up by manually spinning the motor.
Replace the motor if defective.
6. Timer
Replace if defective (note: uncommon problem).
Posted on Aug 27, 2009
SOURCE: ge potscrubber dishwasher will not
Had the same problem with my dishwasher. Took it appart thinking that something was plugging the drain but there wasn't anything. Turns out the cylinoid that has the hook coming out of it to control the flap for the ejection of the water is broken. When looking at your pump, you should see a small flapper valve on the exterior of the pump hooked up to a small cylinoid that when accivated flips a flap in the pump to eject the water out of it instead of letting it circulate in the unit. This is an easy part to replace, but for me, hard to find since my potscrubber is so old. Hopefully your units are newer and you can find this part at your local appliance shop.
Posted on Oct 12, 2009
heatman101
  • 43501 Answers
SOURCE: my GE Potscrubber dishwasher will not drain
Here is a tip I wrote that will help[ you with your problem..
http://www.fixya.com/support/r4078724-dishwasher_problems_water_will_not_drain
Heatman101
Posted on Feb 22, 2010
What is wrong with my dishwasher and how can I fix it?
Check water temp. Needs to be a minimum of 120 degrees. Check all the spray arm holes for food blockage. Look closely at the holes on the spray arm ends. Those holes act like jet engines to spin the arms.
Apr 02, 2015 | GE Dishwashers
How do you remove the sprayer arm from a GE potscrubber 600
Thought I had a problem with the spray arm or pump because water was not flowing enough to spray the upper rack. But it turned out it was a simple part missing: the "check valve" that is in the lower neck of the spray arm assembly. It's a $10 part. Part #WD1X5488 for GE Potscrubber 600.
May 20, 2013 | Dishwashers
I have the GE 206c1513p001 Potscrubber and recently found a black seal or rubber band in the dishwasher. Since then, it has been making a continuous clicking noise when it is run and does not clean the...
I have the exact same problem!!! Found 2 loose rubber bands, the bottom doesn't drain completely, and the dishes are left either dirty with a white film on them. Please help!
Oct 06, 2010 | GE Dishwashers
Burning smell coming from dishwasher caustic to nose. GE Potscrubber 900. Nothing on element upon inspection. Smell more at beginning of wash cycle or when using the pot scrubber button
Older GE's had problem with drain coils over heating
Remove the bottem front plate and the coil will be on the left side of the moter and activate when the drain cycles, check that
Apr 22, 2010 | GE 24 in. GSD2000Z Built-in Dishwasher
Water not draining
For starters does it drain at all?If the drain line is connected to the sink drain and you have a garbage disposal,the drain hose could be plugged up.
Aug 06, 2008 | Dishwashers
Jul 08, 2008 | Dishwashers
Dishwasher not draining fully
Dec 02, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwashers Logo
Top Dishwashers Experts
