Question about Relic Watches
Remove links relic 15709
Remove braclet links
SOURCE: Watch Band Adjustment
I just got this watch for a gift and was able to remove links myself after doing some research. It really isn't difficult if you are patient, have a little mechanical experience, and have some very basic "tools" available.
Tools:
  • 1 push pin like you use on bulletin boards with a plastic head
  • 1 small hammer like a tack hammer
  • 1 pair of small pliers. Needle nose pliers would be best but I used diagonal wire cutters (be careful not to cut the link pin)
  • 1 small block of wood
Try to pick a well lit table in a room where you will not be interrupted.
Procedure:
1. Lay the watch and band sideways on the block of wood so that a pin for the link you would like to remove is just hanging over the edge of the block and pointing down. You need the block to brace the band while you hammer lightly on the pin. Someone to hold the watch in that position would be helpful, but it can be done alone. Only try to remove pins that have an arrow on the back of the band pointing at them. It does not matter with this watch band which way you go with the pin.
2. Carefully line up the push pin point with the top of the pin.
3. Slowly, lightly and carefully hammer the plastic side of the push pin so that the pin in the link just emerges from the band on the bottom side enough so that you can grab it with the small pliers.
4. Slowly and carefully pull the pin straight out with the pliers. You can pick up the watch from the block of wood to get a better grip. Be careful not to bend the pin since you will need to replace at least one of the pins you remove.
5. Repeat steps 1 - 4 until the band is the correct length. I needed to take out 3 so I removed 2 from one side and 1 from the other side of the clasp.
6. To fasten the watch back together again, gently insert the pin back in the hole it came from it. You will probably need to use the tack hammer to make the top of the pin flush with the band.
Posted on Jan 09, 2008
  • 3 Answers
SOURCE: Remove link form Relic Wrist band
For my relic ZR15372, all I did was take a thin, hard object (a thumbtack in my case) and carefully pushed out the connecting bar from the link.
If you look at the inside of the band of your watch, you may notice that on some of the links (the ones nearest the clasp for me) there is a little arrow pointing at the side - if you look at the side of the links, there should be a little hole, big enough to push a thumbtack into. If you apply enough pressure (again, carefully - no need to stab your thumb or any other part of your body), the connector pin should slide out a little on the other side. Then it's just a matter of pulling the pin out - perhaps a pair of tweezers would do the trick.
Hope this works for you!
Posted on Mar 04, 2008
escapement
  • 2334 Answers
SOURCE: need to resize watch braclet on a mens invicta watch
You may or may not have arrows inside bracelet. Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
If you do not want to do it yourself, any jeweler will do it in a matter of few minutes.
Don't forget to rate, please.
Posted on Apr 02, 2009
escapement
  • 2334 Answers
SOURCE: how to remove links from relic chronograph
Click on my profile, then click on TIPS AND TRICKS. There you will find explanation how to add or remove links. Rate me, plz.
Posted on Feb 28, 2010
escapement
  • 2334 Answers
SOURCE: How do you remove links from the subaqua venom
Find how to remove or add links here: Use this link and browse through my TIPS AND TRICKS: http://www.fixya.com/MyProfile/tips.aspx?usrid=1700524.
Posted on Apr 25, 2010
Remove links from braclet
does this expand? or links.if its pins they need to be punched out, look inside there should be arrow.
Mar 23, 2012 | Dunhill Millenium DC2601M Wrist Watch
Remove links rotary watch braclet
am given you the watch service center link you go on the site and follow the instruction and resolve your problem
http://www.rotarywatches.com/en/service/rotary-watch-servicing
Jan 10, 2011 | Rotary Rocks Chronograph RLS00042/07 Watch...
Apr 25, 2010 | Invicta Reserve Subaqua Venom Swiss Quartz...
Set the date on my new Relic watch
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all RELIC watch manuals.Rate me, please
Mar 22, 2010 | Relic watch
How to remove links from relic chronograph steel watchband
Feb 27, 2010 | Relic Watches
How do you remove links from a Relic watch?
The ladies Relic used two different link systems. The easiest is the easy link system. This is a series of links that are put together with clasps. Simply undo the clasp of the number of links to remove. Its like a series of buckles. The second is a cotter pin or tension pin. You will need to push the pins out from the right end with a narrow punch. To tell the right end of a cotter pin look for the split at one end that makes it look like a screw. The opposite end will be smooth. The smooth end is the end you place your punch on and push the cotter pin out. To tell the right end of the tension pin look for the end that looks the snuggest and possibly has a dimple. The opposite end will look smaller in diameter. The smaller end is where you will place your punch to push out the pin.
Although this can be easy i always recommend going to a qualified watch maker/technician to insure you do not damage the band when removing the link.
Sep 21, 2009 | Relic watch
How to make a relic watch bracelet a little smaller?
No but if this is a mens watch there might be a micro adjustment on the clasp. To adjust press the pin in the clasp and move the pin in or out depending on the position of the pin to make loose or tight.
Sep 18, 2009 | Relic 0504648FA
Feb 14, 2008 | Relic 0504648FA
Adjusting the watch band on a Relic Adjusta Link Watch
have heard to call relic 1 800 842 8621 and they will send up to two links i think with no charge just shipping
Jan 27, 2008 | Watches
Watches Logo
37 people viewed this question
Top Relic Watches Experts
Andrew Taylor
Andrew Taylor
Vernon Taylor
Are you a Relic Watch Expert? Answer questions, earn points and help others
