Question about Hitachi Televison & Video
Hitachi 59F51A How do I get a picture from a system plugged into the HDMI port in the back of the T.V.?
2 Suggested Answers
  • 1746 Answers
SOURCE: when i plug an hdmi
Hi, When you use the HDMI you have to switch the TV to HDMI to make it work. Not the other way around. Select the menu on your TV click to HDMI 1 or 2 depending which you are using. Sometime you have to ignor what it says. Try it out any way. Good luck.
Posted on Jul 22, 2011
I plugged my xbox one to my Hitachi 57F500 hdtv using a dvi/hdmi cable but there is no audio. How can i get audio?
On some tvs the hdmi port are weak maybe its starting to come away from the motherboard , I had this happen with ps4, do you have another port to try ? The only way I could sort mine without hefty repair bill was to use the hdmi port that I was using for Sky and then connect Sky through scart lead.
Oct 30, 2016 | Hitachi 57F500 57" Rear Projection...
Ps3 hdmi on hitachi
Not sure what your asking? Plug into HDMI on your tv then your ps3. Hit input on remote until picture comes up. Hope this helps?
Jun 10, 2013 | Video Game Consoles & Games
No audio with hdmi on 51" Hitachi Flat Screen Projection High Definition Television
The device are not talking to each other. Unplug the television from the power, let it sit a minute, unhook the hdmi cable from one device, Plug the power back in to the television, unplug the other device from the power, hook the hdmi back to the connection you unplugged and then connect power on that device. Turn them on and see if it works.
Feb 26, 2018 | Hitachi 51F500 51" Rear Projection...
I am trying to hook my ps3 up to my Hitachi 65 s500. I have the hdmi cable to hook up to imput 1 but when I do that The screen is showing fuzzy color but no picture. What am I doing wrong.
Make sure you're hooking it up to the HDMI port or the Composite port correctly. There is a red green and blue for composite that usually wont work in a port marked "Input 1" You would need to put it in "component/composite 1" correctly. I've come across this not working in 1080, but fine in 720p.
Jun 07, 2011 | Hitachi 65S500 65" HDTV-Ready Rear...
Computer to HDMI outlet of Hitachi HDTV rear projector
The TV should be pretty simple. It is generally going to be HDMI 1, 2 or 3. If the TV won't tune to one then it doesn't detect a signal on that port. More likely, there is a setting either in your Graphic Adapter software or in Windows to output to this port. Windows doesn't turn anything but the RGB port on by default.
May 02, 2010 | Hitachi 51F59 51" HDTV Projection...
HDMI and or Receiver problem
While Bluray pluged into the TV change the resolution from AUTO to 720P then plug Bluray back to the receiver and see if it solve your problem.
Nov 27, 2009 | Hitachi 51F59 51" HDTV Projection...
Hitachi l42vpo1u no sound through hdmi
HDMI port damaged, mainboard need to be replaced.
But be absolute sure your HDMI port is not working properly, I recommed you try it again with another HDMI cable, you can also try same cable in another TV.
Bye
May 18, 2009 | Televison & Video
57 hitachi ultravsion rear proj hdtv :ps3 hdmi issues
TRY ON THE DISPLAY PS3 SETINGS TO NOT LET THE HDMI DO AUTOMATIC,,CHECK OFF A FEW ,,LIKE TRY JUST DION IT CUSTOM,,CHECK 480P,,AND 1080I,,,NOT 720P OR 1080P,,TRY THAT AND IF YOUR TV IS A 1080P,,JUST CHECK THAT,,OR IF ITS A 1080I,,JUST THAT
May 15, 2009 | Hitachi 53FDX01B 53" Rear Projection...
Televison & Video Logo
15 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
