Question about Dacor ECD227 Epicure Stainless Steel Electric Double Oven
Dacor oven u22 error code - Dacor ECD227 Epicure Stainless Steel Electric Double Oven
4 Suggested Answers
vitg55
  • 73 Answers
SOURCE: dacor single oven flashes an F2 error code and won't stop beeping!!!
This is from manufacture service manual:
-F2- Alarm Heating Mode High Temperature
Is activated when the ERC senses a runaway heat condition or when the temperature exceeds
“runaway limits”. The ERC will beep until the cancel or another function is selected. If the alarm
repeats the F2 alarm check the oven sensor and wiring after fi rst checking for a stuck relay. If alarm
goes away verify the oven will complete a clean cycle without any type of failure.
Another words the problem with oven sensor or relay board.
Posted on Dec 18, 2008
localwonder
  • 6784 Answers
SOURCE: Dacor error codes
HI. the F-1 code is a System Watchdog Circuit failure code.
Press "Cancel", if beeping continues after 30 seconds, replace the main control board (also called clock or ERC).
Concerning the F-5 code. This is an oven temp sensor failure code. have it replaced asap. ((Check the wiring leading to and from the control and sensor for cracks and fouled structure. if the wiring is bad, replace the harness as well)),
Posted on Aug 01, 2009
  • 523 Answers
SOURCE: ECS227 Epicure Electric Double Oven: I have a Dacor model # CPD227R double convection o...
replace touch pad
Posted on May 06, 2010
Dacor model ersd30 how do i fix an F0 error code that also blinks F1 and beeps
Hi dan8260,
If you're encountering F0 error code, it is due to a stuck function key. You need to replace the touch pad to fix this error. If the touch pad is part of the clock, you need to replace the clock or ERC.
Hope it helps.
Thank you for using FixYa.
Feb 07, 2011 | Dacor Epicure EO127 Stainless Steel Dual...
We have a dacor double oven that is not running and keeps giving us error message of F1.. Neither of the ovens will work.. Any idea what is wrong and how to fix it?
Hello & Welcome to FixYa
Error code F1 is displayed due to electronic oven control failure and the only way to solve this problem is by replacing the control board which is bad. Please get back to me if you have any other questions.
Kevin
Feb 03, 2011 | Dacor Ovens
A code appears on my Dacor oven/stove that reads FO, what does it mean?
Hi bevtrust,
The error code that appears on your Dacor oven is about a stuck function key which refers to F0 error code. To fix this problem, you need to replace the oven's touch pad. If the touch pad is part of the clock, you need to replace the clock or ERC.
Hope it helps.
Nov 16, 2010 | Dacor Epicure EO127 Stainless Steel Dual...
F4 code Dacor oven
F4 means there is an open circuit in the Oven Temperature Sensor. Could be a bad sensor that needs replacing, cound be an issue with the wiring harness.
A test would be to short the sensor wire together at the sensor. the error code should change to F3. then you would know it is the sensor and not the harness.
Mar 03, 2010 | Ovens
Dacor single oven flashes an F2 error code and won't stop beeping!!!
Oct 26, 2008 | Dacor MCS130 Millennia Electric Single...
Dacor error codes
Apr 25, 2008 | Dacor ECS127 Epicure Electric Single Oven
Display reads U60 Cooling Fan - oven won't heat
I got Dacor to give me the number sequence -- - push "cancel" and "#" at same time - when screen asks for "service ID" enter "S1234" (get "S" by pushing "7" 5 times) - screen will list "U60 Cooling Fan" as number 1, so select "1" - select "clear all", this should clear the error - hit "cancel" to get out of that screen
Hope this works for you! Best suggestion I have is DON'T BUY DACOR!! We also own their 30" dishwasher, which has been a nightmare experience as well.
Apr 09, 2008 | Dacor ECS230 Epicure Electric Double Oven
SELF CLEANING DOES'T WORK
"F8" ERROR MESSAGE. This indicates a door latch failure.
Jun 25, 2007 | Dacor ECS130 Epicure Electric Single Oven
Dacor ECD227 Epicure Stainless Steel Electric Double Oven Logo
64 people viewed this question
Top Dacor Ovens Experts
Dan Webster
Dan Webster
Vitaliy Gins
Vitaliy Gins
ashburton
Are you a Dacor Oven Expert? Answer questions, earn points and help others
