Question about Intermec EasyCoder PF8t Thermal Barcode Label PN PF8TA03101000 Printer
Intermec pf8t when printing stop get orange light
2 Suggested Answers
RCtech
  • 55 Answers
SOURCE: I have an Intermec PF8t
depending on what version of office your using you will find a label tab under mailings (in office 07) or under tools (previous versions) you should be able to specifiy a label type or build a custom label.
Posted on Dec 10, 2008
My printer is intermec PF8T i have i SAP program to print patient information but it cannot print the error is orange ligths was the error.
There are a few things to figure out here from a SAP basis administrator perspective these steps are common. Also I am just trying to help and with SAP there could be multiple solutions. Good luck.
Check SAP MarketPlace for SAP note: 1557674
Here are the steps taken from the SAP Community Network which might help. I would suggest reading the entire link as its informative. http://scn.sap.com/thread/1975158
Step:
run SPAD
to create an output device, choose Output Devices on the Devices/Server Tab
click on Display now you will be in Spool Administration window
click on Change button then Create tab will be appear, now you have to put the following information.
Under DeviceAttributees
put the Output Device name with shortname
Device Type: SAPWIN
Device class: Standards printer
you can put Model/Location/Message as per concern.
Under Access Method
Access Method: G
Host Printer: __default
save
for more information about
Device Type
http://help.sap.com/saphelp_nwmobile711/helpdata/en/d9/4a910f51ea11d189570000e829fbbd/content.htm
Access Method
http://help.sap.com/saphelp_nw70/helpdata/en/4f/9c033cff903105e10000000a114084/content.htm
(1) Choose "S: Print Using SAP Protocol" if a print server with SAPlpd or SAPsprint is used to print barcodes.
(2) Choose "F: Printing on Frontend Computer" if SAPlpd and SAP GUI are used together to print barcodes, SAP GUI sends print job to SAPlpd, SAPlpd is started automatically and forwards the print data stream to the Windows print manager.
(3) Choose "G: Frontend Printing with Control Tech", only SAP GUI is involved in printing barcodes, SAPlpd is not used.
Here are the Intermec drivers:
http://www.intermec.com/support/downloads/index.aspx
Understanding the LED Indicators
LED Meaning
Green (blinking) Auto-Sensing mode
Green (blinking) Downloading font, form, or graphic
Green (solid) Dump mode
Green (solid) Ready mode
Green (solid) Print mode
Orange (solid) Boot mode
Red (blinking) Media jam, overheated print head or stepper
motor
Red (blinking) Downloading firmware
Red (solid) Error mode
Good luck
Dec 27, 2013 | Intermec Office Equipment & Supplies
When i open the printer the led flashes orange.. and i cant get print.. i checked the connection and power they are all fine..
Try resetting the printer.
How to reset the printer. Turn off the printer, (in the back) then turn on the printer while holding down the Reset button on the top. Release the reset button when the light turns green then wait for the printing to stop. IMPORTANT: Next press the reset button for 1/2 second. If you hold it too long it will not reset the printer properly.
Jan 25, 2011 | Intermec EasyCoder PC4 Label Printer
REQUIRED DRIVER FOR INTERMEC PF8t BARCODE PRINTER
here is the download site we use for intermec downloads its safe fast and free good luck
please remember to rank this advice
sonic boom electronics
Dec 28, 2010 | Intermec Cable (USB Adapter) for Keyboard...
The Thermal transfer labels are not readable when I print to the Intermec easy coder PM4I. They print too light. I can use the same ribbon and label stock on an Intermec 3400 printer and they print...
You can adjust the darkness level +/- 10. If you adjust it all the way to 10 and it is still too light, there is a print head pressure adjustment screw to the left of the ribbon feed roller.
Aug 19, 2010 | Intermec EasyCoder PM4i Printer
I have an Intermec PF8t printer with InterDriver Windows Driver -- How can I get my labels created in Microsoft Office to print? How do I specify label size?
Dec 10, 2008 | Intermec Office Equipment & Supplies
Intermec CK30 Won't Display Desktop
The ck30 does not have a desktop. Press the green then orange key to access the system menu. Alt then escape will bring up the task manager.
Nov 27, 2008 | Intermec CK30
Printing Bar Code Labels from Intermec 3400
I am using Smartforms with Intermec printer 3400-e and it works in the correct way.
What is the software that you use to build the layout of the label? In my case Loftware.
What is the code to print the Barcodes.
In my case Code 39
Aug 07, 2008 | Intermec EasyCoder 3400 Thermal Label...
Will not print labels
you have connected two printers on a data switch.right.
1. Print test page through Printer driver.
2. If you are using command for printing on Intermec printer, you should not use generic printer.
3. Interchange the cable connected to printers
May 01, 2008 | Intermec EasyCoder PC4 Label Printer
C4 intermec printer
If you're using this printer on a print server then do the following
Turn Printer Off
Disconnect Data Cable
Press & Hold Feed button whilst switching on
Keep Holding Feed Button until test label is complete and light has gone red
Switch Printer off
Reset your Print Server
Plug Data Cable back into printer
Switch Printer on
This should start it printing (unless there are jobs inthe print queue, if there are then they will need to be deleted before printing will commence)
Mar 28, 2008 | Intermec EasyCoder PC4 Label Printer
Intermec 3400 label printer
try here they oft times has a few good referance materials http://epsfiles.intermec.com/eps_files/eps_man/064678.pdf
Sep 06, 2007 | Intermec EasyCoder 3400 Thermal Label...
Intermec EasyCoder PF8t Thermal Barcode Label  PN PF8TA03101000 Printer Logo
Top Intermec Office Equipment & Supplies Experts
Paul Bade
Don  Farrell
Don Farrell
Arizona Information...
Are you an Intermec Office Equipment and Supply Expert? Answer questions, earn points and help others
