Question about Fisher and Paykel 23 in. DD-603 Built-in Dishwasher
Top drawer stops, will restart if I push start
Hi-our DD-603 top drawer will stop about 20 min. into a cycle, will start from the correct time if I hit start, will shut off again after 15 min. or so. It does this every time I try to run a cycle, but will finish if I keep hitting start every 20 min. Any clues? Thank you.
Sounds like a micro switch problem to me, telling the dishwasher that the drawer is open when it is not actually open.
Posted on Dec 26, 2013
5 Suggested Answers
  • 62 Answers
SOURCE: dd603 top drawer won't start
on the hinge slide there is a micro switch the draw needs to be removed to locate it.
Posted on Feb 13, 2008
  • 784 Answers
SOURCE: top drawer dead bottom drawer funtions fine
1-Pull out the drawer.
2-At the bottom either side has a plastice pin , use a long nose ply to pull them off.
3-The front pannel can be seperated from the tube by put both hands on the side of the front pannel with a pulling out force
Posted on Jul 04, 2009
SOURCE: FISHER & PAYKEL DD-603
I have a DD603 bought used, put in the upgrade kit. But now it goes into pause several times during a load. It happens on both drawers very very anoying.
Posted on Mar 30, 2010
SOURCE: When I start the top drawer it defaults to 5
Here is the solution:
http://applianceguru.com/forum1/24814.html
Posted on Jan 16, 2011
My top dishwasher drawer won't finish through the cycle. It runs fine on rinse only but not any of the wash cycles. It stops mid cycles, beeps like it has been paused, then tries to start again
Try to feel the temperature of water inside the dishwasher. If it is normal room temperature for the hot wash cycles then it is likely the heater is faulty.
It is not easy to replace unless you have good experience with repairing dishwashers.
Jan 17, 2013 | Fisher and Paykel 23 in. DD-603 Built-in...
Drawer stopped mid cycle
Have you tried to turn the mains power switch off and on to see if it resets the drawer to off state. Need a bit more detail of what you see on the display etc. when you try to turn back on.
Dec 10, 2012 | Fisher and Paykel 23 in. DD-603 Built-in...
DD-603 cycle and draining problems.
check your kitchen drain as it might be blocked or if you have a garbage disposal (kitchen insinkerator) make sure it is cleared before running the dishwasher.
Jul 18, 2012 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher Paykel double drawer built in top drawer stops mid cycle.
It would help to know which LEDS are on when it stops. Are you able to open the lid etc. Does this happen with the short rinse cycle as well?
Oct 17, 2010 | Fisher and Paykel 23 in. DD-603 Built-in...
I have a dish drawer DD603 purchased in 2005. It
I presume you have a double drawer model.
Does this problem occur with both drawers?
Jan 18, 2010 | Fisher and Paykel 23 in. DD-603 Built-in...
F&P DD 603
Same thing just happened to me. There was a slight leak from the top drawer and it wet the tray on the bottom which caused a short and the circut board and the plug to the top drawer melted. I need to replace the board and wiring harness and am looking for a manual to find out how to remove the faceplate on the top drawer. What you should do first is remove the bottom drawer and check dry the bottom tray if it is wet. There are two circles on the side of the drawer on either side. Turn these with pliers and release the plastic clips on the ends of the drawer slides. you will then be able to pull out the drawer and inspect. Good luck
Jul 14, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Oct 30, 2007 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher and Paykel 23 in. DD-603 Built-in Dishwasher Logo
157 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
marley mcelhinney
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
