Question about HKC 7" Touchscreen 8GB Tablet Android 4.0 with Assorted Colors Case
LOCKED OUT OF HKC TABLET P774A-GR HOW TO FACTORY RESET
Made password at 3 a.m. and cant remember it. only have a home power and reset button on side. reset button doesnt do anything but restart the tablet not factory restart it.
My Settings, System UI and download apps disappered????
Posted on Jan 11, 2014
How do i reset my hkc tablet model number p771a
This should do the trick,
1)
Make sure the tablet is NOT connected to the charger
2) Power off the tablet by holding down the power button for about 10 seconds
3) Once it is off, hold down the HOME button and connect the charger while the button's being held down.
4) When you see the HKC logo come up, let go of the HOME button.
5) Eventually, you'll see an Android logo with a red exclamation mark. If you don't, repeat step 3-5.
6) If you do see the Android logo, hold down the POWER and HOME at the same time for one second and just let go of the HOME which should bring up a "Recovery mode" menu with blue letters. Make sure you let go of the POWER button as soon as you see the menu pop up, otherwise your tablet will just shut itself again.
7) Navigate to "wipe data/factory reset" using the HOME button and select with the POWER button.
8) Navigate to "Yes - delete all user data" and select it.
9) Once it's done, you should see the menu come up again. Navigate to "Wipe Cache" and press the POWER button
10) It should take you back to the recovery menu. Simply press the POWER button while highlighted on the "Reboot system now"
Dave
Dec 03, 2014 | HKC 7" Touchscreen 8GB Tablet 1GHz Android...
Forgot password to get in tablet how do you reset it
RTM. Read the Manual. If you need a manual, google the make and model and manual and you should find a .pdf file you can download. Or go to the manufacture's website and contact them.
Nov 23, 2014 | HKC 7" Touchscreen 8GB Tablet 1GHz Android...
How to do a factory reset on an hkc p886a tablet
Press and hold the power button and the volume up button till the screen turns off, wait a few seconds and if it doesn't start again press the power button, wait while it initializes.
https://www.youtube.com/watch?v=x6u2qWWeaEM
Mar 12, 2014 | Tablets & eReaders
I for got my hkc password to my tablet may you help
First you have to attempt to type in or guess the password 5-10 times make sure that it is plugged into the wall outlet and that it is charged up fully. Once you guess a few times shut it down and power it back up the sec you see the hkc screen let go over the power button and push and hold the home button. Hold the button till you see the dead android with the yield sigh then let got of the home button. Once you achieve this you then push the power button down and tap the home button once you have to be quick about this don't hold the power button for more then 5 sec or you will have to start again you will get the service screen where you can do a factory reset . You can scroll down with the home button and the enter button is the bower button hope this helps it took me 2 days and limited resource to figure this out but it works you need lots of calmness and time but this iOS the fix with no volume button good luck
Jan 31, 2014 | HKC 7" Touchscreen 8GB Tablet 1GHz Android...
Locked out of a hkc p776a a tablet
Recently my daughter locked her self out so I had to spend lots of time trying to figure out how to hard boot it and we all know Internet is limited with info on how to fix this. I figured it out so here it is.
first you got to try to figure out the password 5-10 times then plug it in to your charger and make sure it charged up 100% and try a couple more time then power it down. After it is powered down turn it on the sec you see the hkc symbol let off the power button and push and hold the home button it should take you to a dead android with a yield sight over it you can then let go of the home button when you see this symbol if you don't get this repeat till you get the android. Once you get this then continue on to this next step push the power button down and hold and tap the home button you have to be quick with it don't hold the power down for more than three sec at a time. You can use the home button to scroll down and the power button is used as enter go to the factory settings hit enter and scroll down thru all the no to the yes and it will reset and then you tap on reboot and exit and it is back to factory hope this helps
Jan 20, 2014 | Tablets & eReaders
How to reset hkc tablet p886a
ALL CREDIT OF THIS GOES TO HKC...
this 100% works to factory reset if you are locked out of a hkc p886a tablet...
1)
Dec 28, 2013 | Tablets & eReaders
Reset vigo android
This works with devices having physical home button:-
1. Press the power button and the home button together for a while, long enough until the screen appears with Android bot and a progress bar which shows that it's formatting the internal memory.
With NO physical HOME button:-
2. In case your device does not have a physical home button, press the power button and both the volume keys together for few seconds.
3. Press gently the "reset pin-hole" present generally on a side of Tablet. Use a clip-pin or similarly fine thing to gently push inside to reset your device to factory settings.
or you can Check my blog how to reset your tablet lol,
http://pcgadgetdeni.blogspot.com/2013/02/forgot-passwordpattern-unlock-of.html
Feb 18, 2013 | Android Flytouch 3 8gb 10.1 Inch Super Pad...
HKC 7" Touchscreen 8GB Tablet Android 4.0 with Assorted Colors Case Logo
993 people viewed this question
Top HKC Tablets & eReaders Experts
JonSnell Electronic
JonSnell Electronic
 Mikey
Mikey
avionik99
Level 1 Expert
Are you a HKC Tablet and eReader Expert? Answer questions, earn points and help others
