Question about Kenmore 2.1 cu. ft. Portable Top Load Washer
I have a Sears Kenmore portable washing machine - no model number on it - that I have had for many, many years. However, in total the machine probably only has about 6 years use on it. (Some apartments where I lived already has machines installed.) Today, after the machine sitting idle for about 2 years, I decided to pull it out and do some wash. The first load two loads, towels (not to capacity) worked fine. During the third load...three pairs of jeans...water started leaking from the bottom. Not a flood, but a good puddle. And, it doesn't seem to have the same power spinning and all the water won't drain out. It just sort of spins and sloshes. Any suggestions? Thank you! Pam
SOURCE: washing machine will not spin
MY WASHER WANT SPIN AT ALL
Posted on Nov 15, 2008
jumptrout51
  • 3361 Answers
SOURCE: Kenmore 80 Series - machine won't rinse or spin
Manually move the timer to the SPIN mode and turn it on.
If nothing happens, replace the lid switch.
With a model number I could be more specific.
Posted on Feb 27, 2009
  • 10 Answers
SOURCE: Kenmore Washing Machine won't agitate, spin, or drain
It sounds like the motor needs to be replaced, you can drain the water by taking the drain hose from the drain and lowering down water will drain.
Posted on Jun 01, 2009
  • 23 Answers
SOURCE: water leaking from bottom ofoasis top loading machine
you may not be leaking out the bottom. Your stand pipe may be clogged. If the stand pipe has a slight clog in it, the stand pipe will over flow, and the water "looks" as if its leaking from the bottom... These pump faster than your old machine, so the pipe will back up faster... hope that helps
Posted on Jul 31, 2009
  • 1937 Answers
SOURCE: My washing machine (Kenmore 70 Series) does not spin
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.#######) and you'll see a list of major sub-components with diagrams and parts.
The Kenmore / Whirlpool top load uses a reversing motor to initiate the pump for draining and the transmission to spin.
If you cannot hear the motor trying to turn the pump, (but the washer will agitate) the problem points to the Timer, or the Lid Switch.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
Following is a description of how to release the console for access to the pins.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
This is a Whirlpool PDF on how these washers operate. It has a diagram on jumping the switch as well as a detailed section on how the transmission works.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
It also has a troubleshooting guide.
To bypass the switch, you only have to disconnect the power to the washer, tilt the console back, unplug the switch and using an short piece of insulated wire, jump the two outermost contacts on the connector coming from the console and plug the washer back in.
Following is a description of how to gain access to the console and how to remove the cabinet if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=913ba652cd504fb162f87d892bcb427b
With the jumper in place, try to re-start the washer.
If it works, the Lid Switch is a relatively inexpensive part.
If the problem isn't in the switch, and the Timer continues to move, the problem is likely in the transmission.
We had the same problem:
If you lift the lid, put it down again and the washer begins to spin, the problem is likely in the transmission "Neutral Drain Assembly".
Those cams/gears etc. in that assembly keep the washer from spinning until all of the water is pumped out and then go into spin mode.
Apparently, by opening and closing the lid, torque from the motor starting throws the cams into the right gears so that the washer will spin.
Ours had the same problem, no spin unless the lid was raised and lowered or we shut off and re-started the cycle.
After looking at the transmission parts list (available on a number of sites) and on the Whirlpool site (Whirlpool makes Kenmore) we noticed that the one of the cams in the neutral assembly which is supposed to have a small spring, didn't on ours when we tore the transmission apart again
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
Found the part number for a kit (Whirlpool part number 388253 Neutral Assembly) for $15.00 and replaced the cams and gears.
In order to get the transmission out, you have to remove the cabinet, the fabric dispenser and both agitators. The top agitator uses a plastic 1/2" drive bolt (a 1/2" socket extension works well).
You don't have to remove the drum.
Lay the machine down (after disconnecting power and hoses, remove the pump (two clips), the motor (two screws hold two clips on the motor), lift and set the motor aside.
Remove two 1/2 inch bolts for the motor mounting plate and three 1/2 inch bolts for the transmission.
Pull the transmission, remove the clutch (there is a spring clip that holds the clutch on the main
agitator shaft), remove the 8 screws carefully the transmission holds 14 - 15Oz of oil, remove the clip holding the main spin gear on and check the plastic cams.
If the cam that should have a spring doesn't, or the others look damaged, or the main spin gear is damaged the washer won't go into spin mode.
If that's the problem, install a Neutral drain kit, put everything back together carefully and the problem may be solved.
As an aside, fixing ours cost less than $30 including 80-90 weight gear oil vs. $170 for a new transmission.
Posted on Jan 12, 2010
Looking for a manual for sears kenmore portable sewing machine model 158.13200
Search the internet for:
Manufacturer + Model + the word "Manual"
Nov 22, 2015 | Kenmore Sewing Machines
Any recalls on Kenmore Model # 110.20022012 Washing machine?
I think that your "LID Switch" is broken, go to www.sears.com/parts and put your model number in and you'll see the lid switch listed.
Aug 28, 2014 | Kenmore Washing Machines
I need to get the hose adapter for my portable kenmore washer 44722 can you help me?
You may be able to find a hose adapter on the site.
Also check the Sears site:
http://www.managemyhome.com/
for PDF manuals and you may find a suggestion in one of them.
Mar 31, 2010 | Kenmore Washing Machines
What year was my washing machine made? Kenmore model # 110 91565210 serial # CF1608473
Looks like it was in the 16th week of 1996 so that would be around in April 1996... according to your serial number... btw it was actually made by Whirlpool for the Kenmore line at Sears..
Jun 05, 2009 | Kenmore Washing Machines
Kenmore portable washing machine does not drain water properly
MOST KENMORE MORE WASHERS THE LID SWITCH DOES BAD FROM CLOSING ALL THE TIME,YOU CAN REMOVE THE LIP SWITCH WIRES(2 OF THEM) WIRE THEM TOGETHER AND YOU HAVE BY PASSED THE SWITCH AND YOUR DONE,LET ME KNOW HOW YOU DO-MIKE
Oct 30, 2008 | Kenmore 2.1 cu. ft. Portable Top Load...
Will not advance to the rinse and spin cycles...
The buzzing can only be that the pump if sticking or the inlet valve is sticking, other than that it is lack of water supply. Regards Advisor
Aug 23, 2007 | Kenmore 2.1 cu. ft. Portable Top Load...
Kenmore 2.1 cu. ft. Portable Top Load Washer Logo
316 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
