Question about Wowwee Robosapien X
Robosapien is not starting up
When powered on the eyes blink and it makes a ticking noise
Robosapien V1 not responding to remote
Mine does not work too, looks like remote works, but robot does not pick up the commands Robosapien 1
Jul 03, 2012 | Wowwee Mini Robosapien Humanoid Robot
2000 chrysler town and country wont start and makes ticking noise when ignition switch is turned on
have a load test done on the battery
have the charging system properly checked by an auto electrician
Dec 20, 2017 | 2000 Chrysler Town & Country
My son just received a robosapien for Christmas. I put batteries in it and the remote. The eyes only light up. The robot does not move or speak. The robosapien my son received is about 2 feet high,...
Sometimes the robot may get stuck in sleep mode. Press the power button on the robot's back (by his shoulder blade) once, and if nothing happens, wait 2 seconds and press it again. The Robosapien should begin its wakeup procedure.
Jan 06, 2011 | Wowwee Mini Robosapien Humanoid Robot
I need a operation manual
Do you have the Robosapien or Mini Robosapien? For the Robosapien, you can download the manual from WowWee.com (click Robosapien Manual.pdf). For the Mini Robosapien, it doesn't come with a manual -- there aren't very many instructions, and they all come printed on the box that it comes in.
Dec 19, 2010 | Wowwee Mini Robosapien Humanoid Robot
My Samsung LN52A550 LCD TV will not stay on.
The ticking noise usually comes from the power section of the tv. Usually it is a capacitor failing. As far as the cost of repair this can go either way ie cheap or expensive. It will dpend on what exactly has failed and if it requires a board replacement or just a part.
I'm going to assume this isn't under warrenty anymore. It is covered if it is. You need to get some repair estimates from Samsung and any tv repair shops. Then keep and eye out for a replacement. Make sure you include any shipping costs or other costs when you are totaling up the estimates. If it gets close to the replacement cost then you will have to choose if you want a new tv or have a repair done.
Jul 07, 2010 | Samsung LN52A550 LCD TV
I have a 2005 dodge neon sxt, in the morning when I start it up I hear a loud knocking noise from the engine but after about 15 seconds it gets softer but is still there all day when I'm driving around.
It is probably your lifters sticking. Check your engine oil level and if thats fine, then add some oil detergent/additive that says it will "reduce engine knock and free sticky lifters" run with that additive for a couple hundred miles or until the noise gets better. then replce your oil after that without using the additive
Nov 22, 2009 | 2005 Dodge Neon
Sceptre LCD monitor blank screen, blinking power light
Something has failed or is failing in the monitor. It may be serviceable, but may not be cost effective to do so unless something has just come loose. I'm assuming you have no problems with the new monitor. Your time line is a little confusing.
Dec 13, 2008 | Sceptre Dragon Eye D219A (White) 21 in.CRT...
Wowwee Robosapien X Logo
83 people viewed this question
Top Wowwee Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Wowwee Toy Expert? Answer questions, earn points and help others
