Hello, I have an tv set model sony black triniton KW-14M1E. As soon as I try to connect the device I go nowhere and the set retrieves a small noive (tek tek tek).... Any chance of support in what conc
Hello, I have an tv set model sony black triniton KW-14M1E. As soon as I try to connect the device I go nowhere and the set retrieves a small noive (tek tek tek).... Any chance of support in what concerns this problem? Thanks in advance
SOURCE: Sony WEGA 36" Trinitron HD
u have a problem with your power supply circuits. ur regulator circuit is not function well thats why ur picture is a little bit smaller
Posted on Jan 15, 2007
  • 55 Answers
SOURCE: Sony Triniton Wega 37"
sounds like capacitor problem
Posted on Nov 25, 2007
  • 55 Answers
SOURCE: To Connect AV Cable from Panasonic VCR to Sony 29 inches
You can either connect the antenna output of the VCR to TV ant in or hookup the audio/video outputs from VCR to audio/video TV inputs. If using the antenna output you need to sellect channel 3 or 4 to view VCR. If using the adio/video lines you need to select the line input on TV to view VCR.
Posted on Feb 18, 2009
crazyhcris82
  • 34 Answers
SOURCE: How do I tune in Sony Triniton tv please
Hello
The first thing is to try going in the tv's menu
It should be similar to this:
Menu>setup>channel setup
once you find something similar, run the channel setup and it should add in the channels
If that doesn't work, screw on the cable wire, unplug the tv for a good few minutes, then replug the tv and it should automatically scan
Hope this helps
-Chris
Posted on May 01, 2009
  • 69 Answers
SOURCE: seeking Sony TV users manual
i have an original part nr for you i dont know in witch country you live.
in holland we can order.
the partnumber: 448257612
Posted on Apr 21, 2010
Testimonial: "thanks for your help, any idea how much it would cost? my email: artist56@t-online.de"
Trying to connect and make it work to a triniton sony tv
May I know the brand and model no. of your Receiver and Sony TV. It can help to determine the right hook-up.
Jdvillanueva
Jul 30, 2011 | Audio Players & Recorders
My sony triniton 29" only sounds
go to sony's website to get the manual
Feb 11, 2010 | Televison & Video
Hello
Hope this helps
-Chris
May 01, 2009 | Sony Televison & Video
Dvd's are playing black & white via sound surround system
Check first your dvd player settings if it is in PAL or NTSC.
Mar 30, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony TV the screen goes black for a few minutes then it comes back on. It is a Triniton
looks u need a new television soon....first sign that the picture tube is on his end.....
Mar 12, 2009 | Televison & Video
Tv turning off
Hello
Sony FD Triniton Wega KV-36XBR400 service manual has no info for 11 times flash. It has info up to 7 falshes. Please count again. Error codes are in below pictures...
Regards,
Aug 27, 2008 | Sony FD Trinitron WEGA KV-32XBR400 32" TV
Sony 32" Triniton TV. Will not turn on.
The four blinks indicate a vertical deflection problem. I would suspect either bad connections on the vertical IC or a defective IC. This IC is a small flat IC with about 9 pins or so and should be marked LA7837 or something similar. Try resoldering the pins first. If that does not resolve the problem, replace the IC.
You may also need to replace some capacitors in the circuit, but try the IC first and keep us updated.
Dan
Mar 17, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Televison & Video Logo
56 people viewed this question
Top Televison & Video Experts
