Question about Sony KP-57WS510 57" Rear Projection HDTV
Sony model kp-57ws510 timer/stand by light blinking 6 times can't turn on tv t all
Tv shut off timer light blinking 6 times cant get it to turn on at all
ctf1800
  • 4402 Answers
SOURCE: SONY KP-57HW40 TUNS OFF AND STANDBY LIGHT BLINKS 6 TIMES
6 blinks is usually associated with failure of the horizontal deflection amplifier - which shuts down the high voltage system as well.
The repair requires testing to determine the exact parts that have failed. There are, for example, a few hundred parts and a section of the Jungle IC chip involved. So, repairs could require something as simple as replacing some inexpensive passive components OR as complicated as replacing the jungle chip (very expensive).
most of the time it's the horz. transformer and transistor.
Posted on Dec 20, 2007
Slinteriors
  • 8617 Answers
SOURCE: SONY REAR PROJECTOR TV
5 blinks means AKB detected. Try turning down all 3 screen adjustments slightly.
Posted on May 27, 2008
billyjones69
  • 42 Answers
SOURCE: 6 bliks on sony kp-46wt510
KP46WT510 Shutdown 6 Blinks. 6 Blinks = Low B+ OCP/OVP
SOLUTION: Replaced Flyback transformer. It had no rings on the ringer test.
HQ
Comments: Any load on the B+ line can cause 6 Blinks.
Example: If the 200v line is loaded down will cause a drop in B+ due to bright picture current demand.
Click Here! to download the Sony Kp-46wt510 full service manual.
Posted on Nov 16, 2008
ginko
  • 19396 Answers
SOURCE: Sony Wega stanby light blinks 5 or 6 times
When a Sony TV flashes five times, that means that there is an AKB circuit fault.
Six blinks is also a fault related to video problems, and regards a fault concerning the digital board and the Jungle IC (the main CPU).
This means that there is something wrong with the video.
Try first unplugging power for few hours, if that does not work, call a technician, as several IC and components must be tested and eventually replaced.
Posted on Dec 01, 2008
ladywinn
  • 5138 Answers
SOURCE: How to change convergence ICs in Sony KP-57WS510 TV?
Replace Both STKs convergence ICs big black ics with number on them STK392-560.Parts 1-800-223-3205
Posted on Dec 28, 2008
TV turns red,shuts off, stand-by light blinking 8Times
Eight blinks - Problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code. Check IC406 audio amp, PS401, and 402. On some projection models of Sony TV sets, this code means that T8005 (flyback transformer), or the associative components in the high voltage circuits are defective on the D board.
Feb 27, 2014 | Sony KP-51HW40 51" Rear Projection...
My tv is not turning on but the stand by light is still on.
The model listed does not have a standby light, only the power on/off light which is there in case the set does not make it on to blink a error code--specific number of blinks
before going further can you confirm the model number and add if have sound, or menu etc?
Nov 03, 2012 | Sony KP-57WS510 57" Rear Projection HDTV
Sony kp-57ws510 timer/stand by light blinks 6 times. no picture or sound. Whats wrong?
the best moment to starting is the VIDEO DETECTOR,+Audio i-f and by splitting your can troubleshooting and fix it. see the b.diagram attached.
Oct 01, 2012 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony KP-57WS510 red light blinking 5x
Try connecting the TV directly to a different wall outlet and check. If the issue persists, try power resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. If the issue persists, then the TV requires service.
Jul 19, 2010 | Sony Televison & Video
Try to turn on, it turns off right away and the stand by light flashes 6 times
Hi
Thanks for using FixYa. Standby/Timer light blinking 6 Times means no Horizontal (H STOP), no raster, and so the set goes to the blinking self-diagnosis function immediately. You’ll need to open the back off the TV and check C515 & 516 and the jungle IC, IC206. Also check +5 line is overloaded (A, B boards), +5 line is shorted (A, B boards). Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 03, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
Tv turns on for 5 seconds no picture and shuts off.. red light blinks 8 times
hello. problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code. Check IC406 audio amp, PS401, and 402. On some projection models of Sony TV sets, this code means that T8005 (flyback transformer), or the associative components in the high voltage circuits are defective on the D board.
shaun
Nov 05, 2009 | Sony KP-57WS510 57" Rear Projection HDTV
Sony KP-41T65
is there a cadence to the blinking timer light?
Jul 17, 2009 | Sony KP-41T65 41" Rear Projection...
Red light flash timer stand by
Please count standby light blinks and let me know.
There would be pause of 3 seconds in blinks.
Also confirm is it Sony KP-57HW40 model?
Feb 10, 2009 | Sony KP-57HW40 57" Rear Projection...
Timer Standby light flashing No pitcher
Sony
Model # KP-53HS10
Serial # 9718217
MFG 2000
Plugged in TV. Timer Standby Light just flashes continusly. No Picture and No Sound.
Apr 02, 2008 | Sony KP-51WS500 51" Rear Projection...
Blinking
Can you do this? Take the back off and look next to the transformer (has large red wires coming out) and have someone turn on the set and if you see a glowing device next to the transformer then the High voltage splitter is bad and if no glow then transformer is bad. This is for information purposes only. Changing these parts is for the trained only and could cost on average $300 parts and labor depending on the repairman and location you are living.
Dec 31, 2007 | Sony KP-57WS510 57" Rear Projection HDTV
Sony KP-57WS510 57" Rear Projection HDTV Logo
47 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
