Question about Singer 3116 Simple
Small oven on double oven Kenmore range quit working
The small oven in my double oven Kenmore Elite quit working after using it a few months. There weren't any prior problems - just one day it didn't heat up as usual. The control knob lights up when turned on but the oven won't heat. I have done all the troubleshooting recommended by the manual and anything else I could find online. The large oven works fine.
This is a Kenmore Elite electric, Model 665.95272500. It is not under warranty.
  • 128 Answers
Sounds like the sensor switch needs to be replaced.
Posted on May 21, 2009
Can I only use the small bobbins supplied and if so where can I get further supplies
The bobbins depend on your machine make & model. Use the bobbins that came with your machine. Not sure what you mean by "small" bobbins. There are quite a few bobbin sizes but bobbins are usually specific to your machine. Singer #15 bobbins are common and readily available at most sewing shops but definitely will not work on all machines. Some bobbins are only a millimeter difference in size but will most likely cause problems with your machine. Just because they may fit in your machine, doesn't mean you will get the best result, if not broken, tangled thread, etc. Sometimes, those bobbins will get stuck in the bobbin case making it difficult to remove. If you want to order more accessories, search for:
Make Model accessories
Mar 12, 2018 | Sewing Machines
Thread disappears up into the machine and out of the needle when using automatic thread cutter
  • It may be that there are quite a few thread ends in the mechanism. Remove the needle plate and pick out any detritus you may find. The cutter normally clamps down on the cut end to stop the issue you describe.
  • You are advised in the manual to use the thread cutter on threads of #30 or thicker, so it might not grip the thread once it is cut if you have thinner threads than the mechanism can cope with (or the threads are slippery)
  • If you are piecing patchwork I'd advise having a little heap of small scraps next to the machine. Then you can run onto a small scrap at the end of each seam and start the next seam without having to cut the threads each time. You work like making a string of flags and cut them off later.
Mar 13, 2015 | Janome 7700 QCP Sewing and Quilting...
Code Lo
Betcha there is a small battery inside that helps maintain the computer's ROM. Since this is a sears machine call Sears/Kenmore parts and see what they can offer you in the way of help.
Oct 02, 2012 | Kenmore 19110 Computerized Sewing Machine
My kenmore model 3851516000 got stuck in reverse, upon starting to take it apart a small piece came flying out. Am quite savy and would like to fix myself but can't seem to find any interior drawings of my...
Go to searspartsdirect.com for Sears and put your model #in and they usually have a blow up diagram of the sewing machines. Try that, it should help you. If, you like my suggest, please rate me.
Sep 15, 2010 | Kenmore Sewing Machines
Want to know how to replace the fuse
If you have an on board fuse it will be very small and near where the plug goes in the machine but unless you can get to it without stripping the machine don't even try, remember that it is quite easy to blow the boards from static from your body.
Jul 03, 2010 | Kenmore 19233 Computerized Sewing Machine
The bottom thread is clumping up and the fabric isn't feeding through smoothly
Clean area where bobbin is. use a small clean paint brush and then if that doesn't work try making small adjustments with upper tension
Aug 06, 2009 | Kenmore Sewing Machines
Sears Kenmore Model # 5186 Problem with stitch length
I had same problem. Took the dial off and turned by hand.
Aug 05, 2008 | Sewing Machines
Jamming
This generic tension setting guide will walk you through attaining the correct balance of tension for any machine.
Ensure that all is clean and free of lint jams....now for tension troubleshooting .......
This solution is for tension problems...if you cannot form any sort of stitch, the issue is quite different, so please let me know if you need a different problem solved.....
It is quite long, but just work through each section in order.
The "knotting up" can reveal a lot. If you have loose threads on one side or the other, the tension on the opposite side will be the culprit.
QUICK SUMMARY FIRST:
Ensure sharp new needle,
Thread guides and Bobbin are Clean & Clear of lint
Set Top Tesion to 4 ....then....
Balance Bobbin to suit.
TOP THREAD TENSION:
If the looping threads are on the underside as you sew, it is the top tension. Top tension ought to be between 4 & 6 (this variation to allow for the different weights of fabric in your
projects).
IS YOUR NEEDLE SHARP ?
If you are using a needle that has seen quite a deal of work, or you suspect it may be blunt, change it for a new one !
TOP TENSION & GUIDES:
Make sure that when you thread the machine the presser foot is up so the thread goes between the discs and not to one side, top tension between 4 and 6, and that you have threaded through all the guides, including the last one, usually on the needle arm, just above the needle clamp.
It may be there is lint trapped between the discs, this will keep them slightly apart and reduce the actual tension, sometimes dramatically.
If tensions appear correct, and the thread is definitely in the channel between the discs, but still too loose and looping, try raising presser foot and remove your thread.
Now, with a 2" (50mm) wide strip piece of fabric 8 - 10" (20 - 25cm) moistened with methylated or denatured spirit, gently insert the fabric strip and clean between the discs with
a see saw / to and fro action.
In the worst cases, gentle use of a needle to pick & remove the jam may be necessary, but be very gentle and make sure the tension is set at Zero and the presser foot is raised, (to
disengage tension plates).... do not gouge or score the plates, they need a polished surface to work correctly.
BOBBIN TENSION:
Far less common, but if the loose threads are on the top, it is bobbin tension that is loose, it too may have lint in the spring and be giving a "false" tension.
I would not recommend fiddling with bobbin tension without good reason, it may end up with missing small screws and spring pieces, however, you can take the needle plate off to clean
the hook race area (where bobbin case sits)
...this is just good housekeeping, my wife does this every time she replaces the bobbin....
just take it out and clean the bobbin case and the fixed metal hook race with a small brush to remove lint. If there is a significant amount of lint, use a vacuum and small brush to get the worst.
Then wipe all this area with a cloth or cotton bud (Q tip) moistened (not soaked) with methylated spirit, especially if there appears to be fine dirty deposits....oil and lint combine to conspire against you.
If it seems likely that you ......really ....do .....actually .....need .....to adjust the bobbin case, first check there is no lint trapped in the metal spring where the thread is tensioned.
TOP LOADER:
Drop-in Bobbin case will look similar to this image with the tension screw in the middle of the metalwork....
4c76dc1.jpg ...the other screw at one end is holding it all together, so beware....it is not a tragedy to undo the whole lot and clean it, but very gingerly and lay the bits out in sequence and orientation, or you risk tearing your hair out !
FRONT LOADER:
....this is a bobbin case from a front loading machine and works in a very similar fashion to the top loader with drop in bobbin, again, if you dismantle it, take care so you can put it all
back properly.
165ca5c.jpg FINISHING UP
GETTING THE BALANCE RIGHT:
When you are certain there's no trapped lint in top tension or bobbin, set the top tension to 4 and the bobbin tension to a point where you just begin to feel resistance.
Try using good quality thread of contrasting colours so you can more easily spot the changes.
Set your zigzag to one width less than maximum (eg. 5 of 6 ...or... 4 of 5 etc) and sew a sample for a few inches and check the result.... adjust the bobbin tension screw very little at
a time, perhaps 1/16 of a turn.
You may find you are playing with this balance for some little while and if you are putting the needleplate on and off each time begin to think it cannot be correct to do this.....BUT....it is,
and eventually, you do get a "feel" for the correct tension and then it happens quite quickly.....as a user you won't be doing it very often unless there is lint built up (or are there small hands at work around the house !?!?!)
OTHER ISSUES:
If you live near the ocean as we do, salt air can play havoc with metalwork inside and out, so to help minimise this, keep a few small packets of dessicant (silica gel) in your machine
case....no case ? then make some sort of cover !
Same applies in any damp or humid environment, keep your machine dry and dust free.
Budget for a proper full service every couple of years (more often if heavily used) and if you don't use your machine for a few years, be aware that old oil will dry out and combining with
dust and form a "clag" like glue (another reason for some sort of cover, even a teatowel !)
FINALLY, A WORD ON THREAD:
If it is worth spending the time, energy and money on making something that you would like to give lasting enjoyment......use quality thread, .......it may seem to cost a little more at the
time, but the results, ease of use and added longevity will be worth the extra, and as a bonus, your tension troubles may be fewer and further between, because there is a more consistant diameter with good thread, and less compensating to be done by your tension plates and less thread breaks !
If you want any more help with this, just post back here, or, drop a line through the "Contact Us" page at www.bargainbox.com.au
Don't forget to mention the problem and your Fixya name !
Jun 13, 2008 | Kenmore 19365 Computerized Sewing Machine
Sewing machine
When in doubt, read the instructions !!
Your manual will probably have fairly specific guidance, but,....
just ensure the button holder and the stop guide are in the correct location.........if you find that it is just zigzagging on and on and not stopping, the culprit will be the small arm that stops the distance movement and tells the machine to do the tack stitch before changing direction and is on the wrong side of the stopper.....it drove me mad for a while too a few months ago, coz it "looked' right.......so double check that position.....even place the arm on the other side of the stopper and do a test.
Apr 13, 2008 | Kenmore 15212 Mechanical Sewing Machine
Singer 3116 Simple Logo
175 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
