Question about ASUS R503u-rh21
Will not boot up
Turns on, but will not let you boot up. Says automatic repair in progress.
On a 1994 nissian patfinder passenger front axel makes clunking noise when turning
From your description, you probably have a bad CV joint (constantly velocity). This allows you to turn the vehicle and allows for sispension travel,BUT, The front liveline is operating at obscure angles as well as pulling the vehicle which is why the CV joint is there. There is one on the outer side of the axle just before the hub and one just before the diffrential on each side. If the rubber boot is torn, the grease gets out and the bearing will get dry. You will hear the noise at first, only as you turn and it will get progressively worse. Most of my customers describe the problem as a "cracking" noise as they make turns. The outer joint would be my best guess. The cheapest and least frustrating way to do the repair would be , to buy a remaunfactured drive axle shaft. If the boot is torn on the other side, I would suggest doing them at the same time. Note you will notice the noise usually when you make tighter turns and it will get progressively worse!
Jul 30, 2014 | 1994 Nissan Pathfinder
How to repair bad sector of hard disk in a laptop
click start right click on my computer you should see your drive usually C: select properties click tools check now tick both boxes automatically fix files and scan for and attempt recovery on any bad sectors
then select check now, start should schedule this task when restart
it will only schedule on restart if its the Primary hard drive with an operating system on it
do not do anything while the chkdsk utility is in progress any input may damage your computer
automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now start
you might tick one box then return after its finished the first repair then return and tick the second box you should not do anything while the chkdsk utility is in progress any input may damage this drive
I found that you get best results by ticking one box then returning after it has finished then tick the other box
hope it helps
Oct 17, 2012 | Samsung Computers & Internet
Scan says boot sector of hard drive damaged, hard drive cluster less thamn 500ms, bad sectors in hard drive. Are these repairable and how.Model dv6910us
you could run the chkdsk utility
click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive another way of running the chkdsk utility
click start control panel administrive tools,computer management ,disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now,start should schedule this task when restart
then defragment your hard drive
hope this helps
Apr 14, 2011 | HEWLETT-PACKARD Computers & Internet
Do i need to reformat my asus laptop n61j series
im not sure what problems you are having with you laptop but i would try this before formating your laptop if you format your laptop you will need to install another operating system
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
or
During the boot process tap the f8 button three times this will boot into safe mode where the only things
working will be your mouse and keyboard enabling you to attempt to repair your computer
once you have your laptop running
you could run the check disk utility
click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive then defragment your hard drive or
do not do anything while the chkdsk utility is in progress any input will damage your computer
dont forget to vote
hope this helps
Feb 07, 2011 | ASUS Computers & Internet
How do i reset a password with out my sd card?
Here are the steps:
1. Place your Windows XP CD in your cd-rom and start your computer (it's assumed here that your XP CD is bootable - as it should be - and that you have your bios set to boot from CD)
2. Keep your eye on the screen messages for booting to your cd Typically, it will be "Press any key to boot from cd"
3. Once you get in, the first screen will indicate that Setup is inspecting your system and loading files.
4. When you get to the Welcome to Setup screen, press ENTER to Setup Windows now
5. The Licensing Agreement comes next - Press F8 to accept it.
6. The next screen is the Setup screen which gives you the option to do a Repair.
It should read something like "If one of the following Windows XP installations is damaged, Setup can try to repair it"
Use the up and down arrow keys to select your XP installation (if you only have one, it should already be selected) and press R to begin the Repair process.
7. Let the Repair run. Setup will now check your disks and then start copying files which can take several minutes.
8. Shortly after the Copying Files stage, you will be required to reboot. (this will happen automatically - you will see a progress bar stating "Your computer will reboot in 15 seconds"
9. During the reboot, do not make the mistake of "pressing any key" to boot from the CD again! Setup will resume automatically with the standard billboard screens and you will notice Installing Windows is highlighted.
10. Keep your eye on the lower left hand side of the screen and when you see the Installing Devices progress bar, press SHIFT + F10. This is the security hole! A command console will now open up giving you the potential for wide access to your system.
11. At the prompt, type NUSRMGR.CPL and press Enter. Voila! You have just gained graphical access to your User Accounts in the Control Panel.
12. Now simply pick the account you need to change and remove or change your password as you prefer. If you want to log on without having to enter your new password, you can type control userpasswords2 at the prompt and choose to log on without being asked for password. After you've made your changes close the windows, exit the command box and continue on with the Repair (have your Product key handy).
13. Once the Repair is done, you will be able to log on with your new password (or without a password if you chose not to use one or if you chose not to be asked for a password). Your programs and personalized settings should remain intact.
Sep 22, 2010 | Computers & Internet
Forgot my password on laptop
Here are the steps:
FORGET USER ACCOUNT PASSWORD ACER 3680
This works with XP, never tried with VISTA but system should have the same loopholes in it.
1. Place your Windows CD in your cd-rom and start your computer (it’s assumed here that your CD is bootable – as it should be - and that you have your bios set to boot from CD)
2. Keep your eye on the screen messages for booting to your cd Typically, it will be “Press any key to boot from cd”
It should read something like “If one of the following Windows XP installations is damaged, Setup can try to repair it”
8. Shortly after the Copying Files stage, you will be required to reboot. (this will happen automatically – you will see a progress bar stating “Your computer will reboot in 15 seconds”
9. During the reboot, do not make the mistake of “pressing any key” to boot from the CD again! Setup will resume automatically with the standard billboard screens and you will notice Installing Windows is highlighted.
12. Now simply pick the account you need to change and remove or change your password as you prefer. If you want to log on without having to enter your new password, you can type control userpasswords2 at the prompt and choose to log on without being asked for password. After you’ve made your changes close the windows, exit the command box and continue on with the Repair (have your Product key handy).
Feb 24, 2009 | Acer Aspire 3680 Laptop
Forgote my password
1. Place your Windows XP CD in your cd-rom and start your computer (it’s assumed here that your XP CD is bootable – as it should be - and that you have your bios set to boot from CD)
Jan 31, 2009 | Microsoft Windows XP Professional With...
Locked out
Jan 20, 2009 | Dell Inspiron XPS M140 Notebook
Boot/Startup repair problem
Microsoft updates do it again!!!
while the PC is booting up his F8 repeatedly, if it lets you into the sub menu boot into safe mode and perform a system restore, take the computer back to before you did the updates, if this works and your computer is restored, turn the automatic updates off
kind regards and please don't forget to vote
Dec 12, 2008 | Acer Aspire 6920 Notebook PC
ASUS R503u-rh21 Logo
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
