Question about Joe Rodeo Pilot Collection Diamond Watch for Men
How do I change the band on my Joe Rodeo Watch
How do I remove links from my Joe rodeo diamond watch band
If the watch is made out of gold the rivet will have to be drilled out and re-solder after a the sizing, Best to have it done by a jeweler. If it is a steel watch it is held together with screws or friction pins. With friction pins the inside of the band will have arrows indicating the direction you have to push the pin in. Use a nail or other object with the same thickness as the pin to push it out in the direction indicated by the arrow on the inside of the band. I hope this was helpfull.
Feb 18, 2012 | Joe Rodeo Pilot Collection Diamond Watch...
How do i change watchband for casio bg169wh
Take the watch with the broken watchband and place it on the table. With a ruler, measure the width of the broken band at the point where it is attached to the watch. Now, measure the total length of the watchband when it is in one piece and fits around your wrist. There will be a crease on the band where it is normally buckled.
  • Step 2 Go to the local store and select a band that you like. You should make sure that the width of the band at the point of attachment to the watch is the same as the old band. Also make sure that the new band will be long enough and not too long to fit your wrist. Purchase the band and return home to change the band.
  • Step 3 Clear a spot to work and make sure that there is a small towel covering the table top so that you can see anything that may drop or pop out during the process of changing the band.
  • Step 4 Use a magnifying glass to look at the point where one side of the band is attached to the watch. You will see a small pin connecting the band to the watch on either side of the band. Carefully use the jeweler's screwdriver to depress the spring loaded pin from the watch to the band and release it from the watch. When the tension on the spring pin is released it may pop out of the band and you will want to take care not to lose it. Repeat this process with the other half of the band.
  • Step 5 Take the new band and slip the spring pins into the small holes on the end of the band where it will attach to the watch. Working with one end at a time, slip one side into the pin hole in the watch body.
  • Step 6 Use the jeweler's screwdriver to depress the other side of the spring pin and guide it into the pin hole in the other side of the watch body. Repeat this process with the other half of the watchband and other spring pin. You now have a new band for your broken one.
  • Jun 20, 2009 | Casio BabyG BG169WH3V (Size: ) Watch for...
    Need new band. Where can I buy one? Thank you.
    Any local retail store like Wal-Mart, Target, K-Mart. Just go to the Jewelry Counter find the band spinner measure the length of where the band is held with the watch.  Find your new band.  Usually everyone place have descent bands.  Ask employer there really helpful as well. Good Luck.
    May 25, 2009 | Pulsar PF3347 Wrist Watch
    How to fasten a Skagen watch?
    Hi there. Insert the mesh strap inside the hole and secure with the hook and clip fastening with a foldover security clasp.
    Hope this one helps.
    May 16, 2009 | Skagen Slimline Mesh 358SGS Wrist Watch
    Band too large
    cant say about this watch . but normally if you look along the edge of the strap you will see bent over pieces if you lift 1 of these you will see a little pin its shaped like a straight U and will pull out. the band will split do the same on the other side then do it again a few links along and the reverse the whole procedure to re assemble . it might be easier to remove the spring bar at 1 end . if this helps please rate joe
    Dec 05, 2008 | Bulova Watch
    Need bands
    try the gossip web site or google it you mite get some on ebay. hope this helps joe
    Nov 20, 2008 | gossip Rectangle Case Leather Strap Watch
    Change casio g shock resin watch band
    It can be done and not too difficult i think but look out that the leather band ain't too wide for the band orginal place,
    make sure you keep all original parts in case of toruble
    Post a photo if you can after the change will be nice to see the change
    Tom
    Nov 10, 2008 | Casio G-Shock GW500A-1V Wrist Watch
    Casio Wave CeptorModeule #2735
    I drilled a coupleof very small holes in the plastic part of the case and also in the watch band where it attaches to the case. I mixed strong epoxy glue (two part) and held the two pieces together with clamps over night. That was 6 months ago and it is still holding. The holes helped squeeze the glue into the joint. Good Luck!
    Joe
    Nov 08, 2008 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
    Replace rubber watch band
    if it a spring bar you can compress the bar with a small pen knife and it should then pop out. if this helps please rate joe
    Nov 06, 2008 | Seiko Divers Automatic watch
    Size of watch band
    Go to a local jewelery store and buy a new band for it. You will find one you like. Joe
    Sep 19, 2007 | Fossil ES9764 Wrist Watch
    Joe Rodeo Pilot Collection Diamond Watch for Men Logo
    15 people viewed this question
    Top Joe Rodeo Watches Experts
    Jimmy Accardi
    Are you a Joe Rodeo Watch Expert? Answer questions, earn points and help others
